Natilus13 14 Posted October 11, 2019 Posted October 11, 2019 So, I screwed up. First off, as a warning to all, don't try changing things when you are tired and a few glasses of wine in I don't know what I was thinking. I changed the port for external HTTPS connections from 8920 to 443. Restarted the server... and now I can't connect at all, on any port, on or off my network. I've been looking through the forums trying to find a solution, but have not had any luck. Hoping someone can help me out here. Thanks, N
Luke 42239 Posted October 11, 2019 Posted October 11, 2019 If you see in this topic the path to the logs: https://emby.media/community/index.php?/topic/78299-emby-and-mac/ You should be able to work your way up from that folder, locate the server's config/system.xml file and undo the changes. 1
Solution Natilus13 14 Posted October 12, 2019 Author Solution Posted October 12, 2019 Thanks @@Luke I was able to change things back, and all is good in the world again :-) 1
