ng4ever 40 Posted October 8, 2019 Posted October 8, 2019 (edited) Samsung S4 phone.I know it is old.If your wondering why I am using such a old phone it is because I am using it for testing only.Anyway Plex seems to work fine but Emby just tries to open at first then i just get a blank screen the whole time. It is really weird.Emby kinda worked at least to go to the server part or the home screen before I factory reset. Though it would always get jaggy or corrupted video when playing something before I factory reset. Main reason why I factory reset is to try to fix that. Edited October 8, 2019 by ng4ever
Dibbes 515 Posted October 8, 2019 Posted October 8, 2019 Emby needs at least Marshmellow to run and the S4 has Lollipop as latest official version, so with the stock firmware, no, it won't work. I have not been able to get it to work on Lineage and two or three other unofficial ROMs. The server will just not start at all... 1
Luke 42244 Posted October 8, 2019 Posted October 8, 2019 Why not try the emby web app? http://app.emby.media 1
ng4ever 40 Posted October 8, 2019 Author Posted October 8, 2019 Why not try the emby web app? http://app.emby.media Good idea but it still makes no sense why the Emby app use to work. I was hoping to have the same test environment as well by using the same Emby app but it is ok. That should work for now.
ng4ever 40 Posted October 8, 2019 Author Posted October 8, 2019 What version of android does it run? Android 5.0.1 I believe let me double check one sec.
Luke 42244 Posted October 8, 2019 Posted October 8, 2019 That is supported. What version of the app are you running? 1
ng4ever 40 Posted October 8, 2019 Author Posted October 8, 2019 That is supported. What version of the app are you running? Emby version 3.0.82
ng4ever 40 Posted October 8, 2019 Author Posted October 8, 2019 Do you need a video to see what the Emby Mobile app is doing ?
ng4ever 40 Posted October 8, 2019 Author Posted October 8, 2019 I found out from this thread https://emby.media/community/index.php?/topic/60752-tablets-not-working-after-update/ I am only running android web view version 37 could that be a problem ? Although I can't update it
Luke 42244 Posted October 9, 2019 Posted October 9, 2019 That could be a problem, yes. Can't you sideload the webview apk?
ng4ever 40 Posted October 9, 2019 Author Posted October 9, 2019 That could be a problem, yes. Can't you sideload the webview apk? How do I sideload the webview apk ? Where?
Luke 42244 Posted October 9, 2019 Posted October 9, 2019 Here's how to sideload apps: https://www.digitaltrends.com/mobile/how-to-sideload-an-apk/ And you can probably get a newer apk from here: https://www.apkmirror.com/apk/google-inc/android-system-webview/
ng4ever 40 Posted October 9, 2019 Author Posted October 9, 2019 Here's how to sideload apps: https://www.digitaltrends.com/mobile/how-to-sideload-an-apk/ And you can probably get a newer apk from here: https://www.apkmirror.com/apk/google-inc/android-system-webview/ It worked thanks! I can see the Emby server now through the app. Now onto the next problem!
ng4ever 40 Posted October 9, 2019 Author Posted October 9, 2019 Ok video plays but it is all corrupted and blinks. Anyway to fix this ? Thanks.
Luke 42244 Posted October 10, 2019 Posted October 10, 2019 Hi, can you please try this version and let me know how it compares: https://www.dropbox.com/s/vhejrc5j5b0h2fr/MediaBrowser.Mobile-google-armeabi-v7a-release.apk?dl=0 Thanks.
ng4ever 40 Posted October 10, 2019 Author Posted October 10, 2019 (edited) Hi, can you please try this version and let me know how it compares: https://www.dropbox.com/s/vhejrc5j5b0h2fr/MediaBrowser.Mobile-google-armeabi-v7a-release.apk?dl=0 Thanks. No difference. Edited October 10, 2019 by ng4ever
