PrincessClevage 175 Posted October 7, 2019 Posted October 7, 2019 (edited) When ever I play a new video file ET volume always returns to 100% even if I just turned it to 50% in the previously place video. Audio pass through is not enabled for these video/audio types and ET client controls the volume level. This even occurs when playing a tv series and finishing one episode then auto starting next episode volume is 100% Edited October 7, 2019 by PrincessClevage
Luke 42241 Posted October 7, 2019 Posted October 7, 2019 Hi, can you try this test version and see how that compares: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/ Thanks.
PrincessClevage 175 Posted October 7, 2019 Author Posted October 7, 2019 Still the same symptoms and is 100% reproducible. Are you able to reproduce this issue?
Luke 42241 Posted October 15, 2019 Posted October 15, 2019 I put a fix for this in the test version: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=796940 Please try it out. Thanks.
PrincessClevage 175 Posted October 15, 2019 Author Posted October 15, 2019 I put a fix for this in the test version: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=796940 Please try it out. Thanks. Works and volume osd is back also.Thanks Luke
PrincessClevage 175 Posted October 18, 2019 Author Posted October 18, 2019 Thanks for the feedback.The test ET won’t launch with no internet access. We currently have an internet outage and When I click to launch ET it just remains minimised on the task bar no matter what I do.
PrincessClevage 175 Posted October 26, 2019 Author Posted October 26, 2019 (edited) Thanks for reporting. We'll take a look. Edited October 27, 2019 by PrincessClevage
Luke 42241 Posted October 26, 2019 Posted October 26, 2019 Haven't seen that. Seems to be just fine here, but let's keep an eye out for it.
PrincessClevage 175 Posted October 26, 2019 Author Posted October 26, 2019 (edited) Has the volume fix made it to stable ET version? I would like to get back to stable edition Edited October 26, 2019 by PrincessClevage
