Happy2Play 9814 Posted October 21, 2019 Posted October 21, 2019 Okay, so: 1. All the season posters I had in place before moving to the beta are still there. Some on my local drive, some on network drive 1, some for seasons with episodes on both drives. 2. Posters on network drive 1 for seasons on network drive 1 work. 3. Posters on the local drive for seasons spread across the local drive and network drive 2 do not work. 4. Posters on the local drive for seasons spread across the local drive and network drive 1 don't work either. 5. Posters on network drive 1 for seasons spread across network drive 1 and network drive 2 also don't work. So it seems if episodes in the season are spread across multiple drives, the poster doesn't display, but this only applies to posters added after I moved to the beta. I haven't been applying them through the UI, just placing a "poster.jpg" in the season's folder. So the structure in Series/season folder spread across multiple locations?
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 I'm not sure I understand the question.
Happy2Play 9814 Posted October 21, 2019 Posted October 21, 2019 Trying to figure out your folder structure.
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 Right, but what specifically are you asking? The series is spread across three drives (one local, two network). It's sporting events, from several different compilation DVDs - some are "X team's best games", others are "finals matches involving Y team from year Z", etc. They're split onto drives based on which set they were sourced from, not which year the games occurred, so some seasons are also split across multiple drives.
Happy2Play 9814 Posted October 21, 2019 Posted October 21, 2019 What is the folder structure? The specific layout of the Series. Do really know how to ask it any differently.
Luke 42287 Posted October 21, 2019 Posted October 21, 2019 Here. 1992, 1993, 1994, and 1995 have no poster. And @@Happy2Play you're able to reproduce?
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 It's laid out like a TV series. AFL Season 1969 AFL - s1969e2301 - 1969 Grand Final.mkv Season 1970 AFL - s1970e2301 - 1970 Grand Final.mkv etc. Some seasons exist only on one drive, others exist on multiple drives.
Happy2Play 9814 Posted October 21, 2019 Posted October 21, 2019 It's laid out like a TV series. AFL Season 1969 AFL - s1969e2301 - 1969 Grand Final.mkv Season 1970 AFL - s1970e2301 - 1970 Grand Final.mkv etc. Some seasons exist only on one drive, others exist on multiple drives. So no matter the drive the same Series and season structure exist when there is a episode on different drives?
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 Season folders only exist if games from that season are on that drive, but otherwise yes, it's the same structure.
Happy2Play 9814 Posted October 21, 2019 Posted October 21, 2019 So is there a season image in every season folder or only one if you have a season spread across multiple drives?
crusher11 1153 Posted October 21, 2019 Author Posted October 21, 2019 Only one. My NFL collection is structured the same way, but I finished setting all the images up before moving to the beta and they still work.
Happy2Play 9814 Posted October 23, 2019 Posted October 23, 2019 Honestly have no idea but I think I can some what recreate the issue issue with a series spread across multiple drives the season image appears to have to be in a specific folder/location. My guess would be images need to be within the first season folder of the first drive the season is seen on. Library TV Shows - Multiple disk Assigned folders Disk 1 Disk 2 Disk 3 Disk 4 Disabled all image downloading Disk 1 Series A - Series poster Season 1 - Season poster Season 2 Disk 2 Series A Season 1 Season 2 - Season poster Disk 3 Series A Season 3 - Season poster Season 4 Disk 4 Series A Season 3 Season 4 - Season poster Season images appear for season 1 and 3, season 2 uses series image and season 4 has no season image. @@Luke Does this make since? 4.2.1.0 and 4.3.0.15 acted the same.
crusher11 1153 Posted October 23, 2019 Author Posted October 23, 2019 It was working for me on the last stable. One thing I did find on the stable though was that there had to be at least one episode in the folder that contained the poster, so I couldn't keep all my posters on one drive regardless of where episodes were. I also had to put the series poster, background and logo on all drives. Season posters did work from any drive though, as long as there was also at least one episode there.
Happy2Play 9814 Posted October 23, 2019 Posted October 23, 2019 I left that out but there are 6 or 7 episodes in each the season folders. I guess as another note i manually placed all images in the folders. I can test applying them via the UI but am almost certain it would work properly.
crusher11 1153 Posted October 23, 2019 Author Posted October 23, 2019 Putting a "poster.jpg" in the season folder is how I've been doing it anyway, I haven't been using the UI.
Ivanm42 1 Posted October 30, 2019 Posted October 30, 2019 (edited) I have The Simpsons S01-S11 and when i it "shuffle" 90% of the time it will launch the same episodes in the same exact order. Edited October 30, 2019 by Ivanm42
daedalus 434 Posted October 30, 2019 Posted October 30, 2019 I have The Simpsons S01-S11 and when i it "shuffle" 90% of the time it will launch the same episodes in the same exact order. this thread turned out to be more about shuffle problems on split up seasons across drives general issue is here -> https://emby.media/community/index.php?/topic/46869-what-dictates-shufflerandom-play/
Ivanm42 1 Posted October 30, 2019 Posted October 30, 2019 this thread turned out to be more about shuffle problems on split up seasons across drives general issue is here -> https://emby.media/community/index.php?/topic/46869-what-dictates-shufflerandom-play/ Thx
crusher11 1153 Posted October 31, 2019 Author Posted October 31, 2019 The issue at the moment is getting the season posters to show up, rather than the shuffling.
Luke 42287 Posted November 5, 2019 Posted November 5, 2019 @@Happy2Play were you able to reproduce the season poster image issue?
Happy2Play 9814 Posted November 5, 2019 Posted November 5, 2019 @@Happy2Play were you able to reproduce the season poster image issue? Post 63
Luke 42287 Posted November 6, 2019 Posted November 6, 2019 Ok yes that's not a new thing. It's something we can look at in a future update. Thanks.
