Luke 42242 Posted October 22, 2019 Posted October 22, 2019 Hi that means it's time to download and install it again to get the latest.
FrostByte 5453 Posted October 22, 2019 Posted October 22, 2019 Hi guys. I download the Emby app onto a USB to install on to a Samsung TV. Managed to get that to work fine but the TV keeps telling me that a newer version is available on emby.media ? Any ideas. With the beta releases a new version is posted for download every month on the 1st for testing. If you don't update then you will start getting that reminder.
SeanS 2 Posted October 22, 2019 Posted October 22, 2019 Stupid question ? Where is the latest download because I thought I had the latest one
FrostByte 5453 Posted October 22, 2019 Posted October 22, 2019 Stupid question ? Where is the latest download because I thought I had the latest one Same place https://emby.media/community/index.php?/topic/74969-samsung-tizen-smarttv-2015-present-beta-app-install-from-usb/ What version do you have? It should be 1.0.68
SeanS 2 Posted October 22, 2019 Posted October 22, 2019 Thanks, I just checked and looks like 1.0.64 Do I need to uninstall and then reinstall from the USB ?
FrostByte 5453 Posted October 22, 2019 Posted October 22, 2019 It kind of depends. Most models you need to delete the old version first before installing a newer version, but some models can just be updated. If you stick you usb in the TV and nothing happens then you will need to delete the old version first, then stick the usb drive in the TV
SeanS 2 Posted October 22, 2019 Posted October 22, 2019 All working thanks, 1 I had to uninstall, 2 others it did upgrade. Thanks for your help. This is what I love about Emby is the community 1
