Nitro_Zeus 11 Posted September 7, 2019 Author Posted September 7, 2019 (edited) It all work now XD, it say https. and i opend port 8920 in my firewall, sooo is i working like it shold now? Edited September 7, 2019 by Nitro_Zeus
Nitro_Zeus 11 Posted September 7, 2019 Author Posted September 7, 2019 when i test my connection on port 8920 it says no ssl certificate but if change port 8920 in my firewall to 443 then it says save and all the good stuff, but then i cannot access the server on remote XD how does that work?
Luke 42217 Posted September 7, 2019 Posted September 7, 2019 These questions are specific to your personal environment and therefore will be difficult for us to answer. But when you had it on 8920 you could check the server log for and certificate related errors just to make sure the certificate loaded successfully.
Nitro_Zeus 11 Posted September 8, 2019 Author Posted September 8, 2019 i'll try that. One more thing XD. Does Emby not support Samsung 8 Series (65) serialnumberr: 0B5X3SLJC01476B i cannot find it in the App selection. I read that i can download it through a USB, but can you send me the correct download link then? i cant seem to find the right one @@FrostByte
FrostByte 5437 Posted September 8, 2019 Posted September 8, 2019 i'll try that. One more thing XD. Does Emby not support Samsung 8 Series (65) serialnumberr: 0B5X3SLJC01476B i cannot find it in the App selection. I read that i can download it through a USB, but can you send me the correct download link then? i cant seem to find the right one @@FrostByte What model is that? What country do you live in? Anyhow, instructions and link are in the thread below https://emby.media/community/index.php?/topic/74969-samsung-tizen-smarttv-2015-present-beta-app-install-from-usb/
Nitro_Zeus 11 Posted September 9, 2019 Author Posted September 9, 2019 Nice it worked with the installation .zip file i cannot find Emby on my LG TV? XD is there a place where i can find these installations for USB myself? i have this info on the tv: https://gyazo.com/f37bfca45d69b43b262dad053beb3e91
Nitro_Zeus 11 Posted September 10, 2019 Author Posted September 10, 2019 It's a old smart TV, but i do not know were to see if its a Netcast or WebOS TV?
Nitro_Zeus 11 Posted September 10, 2019 Author Posted September 10, 2019 (edited) you can see that above. I'm From Denmark if that matters Nice it worked with the installation .zip file i cannot find Emby on my LG TV? XD is there a place where i can find these installations for USB myself? i have this info on the tv: https://gyazo.com/f37bfca45d69b43b262dad053beb3e91 Edited September 10, 2019 by Nitro_Zeus
Nitro_Zeus 11 Posted September 10, 2019 Author Posted September 10, 2019 its a free online picture capture tool. "Gyazo is an open-source and free screenshot program for Windows, macOS, and Linux. The program allows users to create screenshots and upload them to the web, producing a unique URL to the screenshot. The program's name "Gyazo" is a pun on the Japanese word for "image""
Luke 42217 Posted September 10, 2019 Posted September 10, 2019 So you have WebOS version 3.0. Did you search for Emby in the LG store? It should be there.
Nitro_Zeus 11 Posted September 15, 2019 Author Posted September 15, 2019 i did, how do u know my WebOS? can i locate it by myself somehow? see screenshot here: https://gyazo.com/39f00487017f1bdd9d09c245a186f090 cannot find Emby
Luke 42217 Posted September 15, 2019 Posted September 15, 2019 i think you're looking in LG smart world. But you should be using the LG app store instead.
Nitro_Zeus 11 Posted September 19, 2019 Author Posted September 19, 2019 there is also nothing only web app see picture: https://gyazo.com/d45703e7cacf2b9356f6b4a5a606fed3
Luke 42217 Posted September 20, 2019 Posted September 20, 2019 Are you sure that's not an old netcast tv? @@SamES
Nitro_Zeus 11 Posted September 20, 2019 Author Posted September 20, 2019 The TV is 5 years old at minimum!
SamES 1083 Posted September 20, 2019 Posted September 20, 2019 In the TV settings there should be a section about this tv with the model number, or on the sticker on the back of the tv
Nitro_Zeus 11 Posted September 20, 2019 Author Posted September 20, 2019 (edited) In the TV settings there should be a section about this tv with the model number, or on the sticker on the back of the tv Picture from TV settings: https://gyazo.com/f3...62dad053beb3e91 Link to TV: https://www.lg.com/uk/tvs/lg-42LB570V Should i do a firmware update from the LG's homepage? download the zip file and just plug it into the tv Edited September 20, 2019 by Nitro_Zeus
fizzyade 132 Posted September 20, 2019 Posted September 20, 2019 It would be nice if certbot or acme.sh or something was supplied with Emby (license permitting) with options to get it up, even if it’s just to set the command line to it. (Advanced mode) Alternatively the ability to add a custom scheduled task, I.e execute this program at x o clock, with the return code from the task returning a value that indicates success, SuccessRestart, Failed. Success restart would restart Emby so the new cert is loaded (I assume you need to do this).
Nitro_Zeus 11 Posted September 20, 2019 Author Posted September 20, 2019 It would be nice if certbot or acme.sh or something was supplied with Emby (license permitting) with options to get it up, even if it’s just to set the command line to it. (Advanced mode) Alternatively the ability to add a custom scheduled task, I.e execute this program at x o clock, with the return code from the task returning a value that indicates success, SuccessRestart, Failed. Success restart would restart Emby so the new cert is loaded (I assume you need to do this). i understand 10% of what u just said haha XD
SamES 1083 Posted September 20, 2019 Posted September 20, 2019 Picture from TV settings: https://gyazo.com/f3...62dad053beb3e91 Link to TV: https://www.lg.com/uk/tvs/lg-42LB570V Should i do a firmware update from the LG's homepage? download the zip file and just plug it into the tv Thanks, that confirms this model has Netcast firmware, not webos, so unfortunately there is not an app available in the store for this yet.
Nitro_Zeus 11 Posted September 25, 2019 Author Posted September 25, 2019 Thanks, that confirms this model has Netcast firmware, not webos, so unfortunately there is not an app available in the store for this yet. i thought so. i recived this answear from LG support Good Afternoon Jonas, Thank you for your query in regards to the Emby Application. I have had a look into this for you and the Application Emby is available on the Web OS 4.0 and higher, which is the latest interface. Your unit is a Netcast 4.5 which means this app may not be available. This is something that we are not in control of as App developers do decided which apps they will to support and how they wish to format the Applications. This means the format is something that can only be supported on recent units, if you would like me to look into this further and raise it to our Head Office for any future arrangements with Emby to see what can be done. If you do wish to discuss this further please do not hesitate to contact us on 0344 847 5454 or alternatively you can also reply to this email by clicking on the wish to reply to this email button just below. Should you need to attach anything in your response, please click on the start a brand new enquiry button. If you do wish to respond to this email, please do so by clicking on the “Save” button on the response page. Kind Regards, Dayam LG Electronics UK Help Desk
