Nitro_Zeus 11 Posted August 22, 2019 Posted August 22, 2019 (edited) Hello. I will refer to a previous post: https://emby.media/community/index.php?/topic/54586-security-101-secure-connections/ I'm considering using Emby for my home videos so i can watch them on my appel TV, Mobile and Laptop out of my home. But how secure is the connection. I have a ESXI server and planning on using Emby on a Debain. (Is win10 better?) And then connect outside the home to watch my movies, can you tell me how good the encryption is ont this connection? Sorry if this alrdy been solved, i cannot find such post. thanks Edited August 22, 2019 by Nitro_Zeus
mastrmind11 722 Posted August 22, 2019 Posted August 22, 2019 its not encrypted unless you choose to use https. If you use https, it's as encrypted as any other SSL connection.
Happy2Play 9806 Posted August 22, 2019 Posted August 22, 2019 As secure as your setup is. https://emby.media/community/index.php?/topic/60192-https-is-emby-secure/ 1
Nitro_Zeus 11 Posted August 23, 2019 Author Posted August 23, 2019 Okay so what i can read, the best is Win10 adn thats what i'm going with. secound thing. Should i be using reverse Proxy to encrypt/hide my communication on the big WWW. As far as i can read, people seem to go with that, but also SSL Certificate. to get https i need ssl certificate right?
Nitro_Zeus 11 Posted August 26, 2019 Author Posted August 26, 2019 Okay thanks Any good Youtube videos on SSL certificate on Win10 machine
WilhelmStroker 107 Posted August 26, 2019 Posted August 26, 2019 https://mythofechelon.co.uk/blog/2017/01/01/lets-encrypt-emby-server-and-windows Is a good walkthrough.
Nitro_Zeus 11 Posted August 26, 2019 Author Posted August 26, 2019 (edited) aight thanks, One last thing, i'm having trouble with my subtitles. it wont even show up? I have the local on my server, but there is no option on the video to choose subtitles? I'm missing the CC button? See picture here https://gyazo.com/452b99a5c61f9610110a731e2ad44781 Edited August 26, 2019 by Nitro_Zeus
Solution Luke 42217 Posted August 26, 2019 Solution Posted August 26, 2019 aight thanks, One last thing, i'm having trouble with my subtitles. it wont even show up? I have the local on my server, but there is no option on the video to choose subtitles? I'm missing the CC button? See picture here https://gyazo.com/452b99a5c61f9610110a731e2ad44781 First thing I would do is compare your subtitle file names to our subtitle naming guide: https://github.com/MediaBrowser/Wiki/wiki/Subtitles 1
Nitro_Zeus 11 Posted August 26, 2019 Author Posted August 26, 2019 i alrdy did, but nothing happends. There is no option choosing diffrent subtitles while playing the video?
Luke 42217 Posted August 26, 2019 Posted August 26, 2019 i alrdy did, but nothing happends. There is no option choosing diffrent subtitles while playing the video? You already did what and nothing happens? How are you subtitle files named? Can you please go over an example? thanks.
Nitro_Zeus 11 Posted August 28, 2019 Author Posted August 28, 2019 I linked to gyzo where you can see i tried to diffrent kinds of subs And the CC button is'sn there when i play a movie? is there a setting that will help this? i mean a setting like "always use local subs" Do i have to use the Force subs? https://gyazo.com/45...10a731e2ad44781
Luke 42217 Posted August 28, 2019 Posted August 28, 2019 We always use local subs. Did you compare your subtitle file naming to our supported naming conventions? https://github.com/MediaBrowser/Wiki/wiki/Subtitles
Nitro_Zeus 11 Posted August 28, 2019 Author Posted August 28, 2019 I looked at the subs again, and found out the file name of the movie was not named like showed XD I just looked at the Subs, and how they could look like, thanks again
Nitro_Zeus 11 Posted August 29, 2019 Author Posted August 29, 2019 Yep. Before my movies was named fx: Pulp Fiction 1080p (1990) and the subs just Danish.srt and English.srt so i changed it to: Pulp Fiction.mp4 and subs: Pulp Fiction.Engelsk.srt and Pulp FIction.Danish.srt And it works perfect, thanks again
Nitro_Zeus 11 Posted August 30, 2019 Author Posted August 30, 2019 (edited) https://mythofechelon.co.uk/blog/2017/01/01/lets-encrypt-emby-server-and-windows Is a good walkthrough. About the guide/link to setup Emby server SSL certificate. the post is from 2017 and he says this Emby Server version 3.2.15.0 and older only: The installer for OpenSSL. Does that affect me in any way? Just wanted to ask before i begin the journey to SSL Edited August 30, 2019 by Nitro_Zeus
Nitro_Zeus 11 Posted September 6, 2019 Author Posted September 6, 2019 (edited) Hey again guys, i'm in this situation now where i need a little help. i have my SSL.pfx and SSL.pem file. but how do i decode it, and wich file do i need to upload to my Emby Server Localhost? the guides i found was not easy XD. see below, i cannot do that? and also very bad explenation on what each file is and the process in it? hope anybody can help Execute command ""<path to file openssl.exe>" pkcs12 -in "<path to password-protected PFX file>" -nodes -out "<path to folder containing PFX file>\temp.pem"". 11. Enter password for the PFX file. 12. Execute command ""<path to file openssl.exe>" pkcs12 -export -in "<path to PEM file>" -out "<path for passwordless PFX file>"". 13. Enter no passwords (just press Return twice). Edited September 6, 2019 by Nitro_Zeus
Luke 42217 Posted September 7, 2019 Posted September 7, 2019 i have my SSL.pfx and SSL.pem file. but how do i decode it, and wich file do i need to upload to my Emby Server Localhost? Hi there, the help text on the Advanced settings screen of the server will tell you the format that it should be in. Does this answer your question?
Nitro_Zeus 11 Posted September 7, 2019 Author Posted September 7, 2019 ehm? not guite XD Custom ssl certificate path: search Path to a PKCS #12 file containing a certificate and private key to enable TLS support on a custom domain. Ist tnat .pfx or .pem and do u know a good guide to decode it? or something
Luke 42217 Posted September 7, 2019 Posted September 7, 2019 Ok sorry i thought we mentioned pfx. Pfx is what most people use. I don't know what you mean by decoding. You just enter the path to the certificate , as well as the certificate password, and that's it.
Nitro_Zeus 11 Posted September 7, 2019 Author Posted September 7, 2019 u sure? okat then, but then i restart the Emby server, and i do not get the certificate i right corner lige the guide shows here: https://gyazo.com/3629ced8de309001c072d20d5c36130a
