Hoochee 12 Posted August 1, 2019 Posted August 1, 2019 Mobile: S6 Active App: v.3.0.68 Emby Server: v. 4.3.0.0 beta "Create a subfolder for each device" is checked The Android does not have a custom upload path option in the Device section; however, a folder was auto-created on my NAS for the device using the default Display name. There are about 1200 media files in the default Android Gallery and initially Emby sync'd only 935 files which I thought was an issue until I found that videos aren't currently supported (I assume the video count is the delta). Before I realized videos aren't supported I changed the Display Name of the device in the Devices section thinking I could get a fresh sync. A new folder of the new Device Name was auto-created on the NAS, but no re-sync. I snapped a new photo but it wasn't uploaded so I searched for the cause and found an old post from @@Luke where the sync interval was stated as 15 minutes. It's now been three days and no new photos have sync'd to the NAS. I followed the directions at https://emby.media/community/index.php?/topic/15638-how-to-report-an-android-problem/ to find a device log but on my device the referenced /files/ folder is empty. I found an old thread where @@Luke noted how to do a manual sync but my Android doesn't have the referenced device menus. TIA for any suggestions.
Luke 42244 Posted August 1, 2019 Posted August 1, 2019 Hi, this is being caused by recent changes to reduce communications between the app and server. It's something we'll need to take a look at. Thanks.
Luke 42244 Posted November 21, 2019 Posted November 21, 2019 We have new improvements to Camera Upload in beta if you'd like to help test them out: https://emby.media/community/index.php?/topic/79526-android-mobile-3088 Thanks.
Luke 42244 Posted October 2, 2020 Posted October 2, 2020 This will be in the next update to the android app, and two updates from now in the iOS app. You'll be able to select which folders you want to upload. Thanks.
Luke 42244 Posted November 13, 2020 Posted November 13, 2020 Emby for Android 3.1.59 has been released. Thanks.
lioil 0 Posted December 5, 2020 Posted December 5, 2020 On 8/1/2019 at 2:32 PM, Hoochee said: The Android does not have a custom upload path option in the Device section; Has the problem been solved? can you share your experience, thank you.
Luke 42244 Posted December 6, 2020 Posted December 6, 2020 On 12/5/2020 at 4:37 AM, lioil said: Has the problem been solved? can you share your experience, thank you. Please try the latest version of the app and server. Thanks.
lioil 0 Posted December 6, 2020 Posted December 6, 2020 1 hour ago, Luke said: Please try the latest version of the app and server. Thanks. emby app for anAndroid 3.1.64 emby server for windows 4.5.3
Luke 42244 Posted December 16, 2020 Posted December 16, 2020 On 12/6/2020 at 11:48 AM, lioil said: emby app for anAndroid 3.1.64 emby server for windows 4.5.3 Answered here:
