Brudertac 18 Posted July 30, 2019 Posted July 30, 2019 Hi there, with the actual official App and also with the Beta the Sync Feature is Broken. I can create a Sync Job (e.g. Series) but it never starts the Download. In earlier Versions this happens too, but there i was able to start the Download with "save the Sync Job again". In actual Version and Beta i also cannot Download a single Episode using the Download Button. Just nothing happens... Is this a known Problem? best regards Brudertac
Brudertac 18 Posted July 30, 2019 Author Posted July 30, 2019 (edited) 4.2.0.40 on Synology DSM. With this Download do not work at all. With the earlier Version (4.1.1.0) it worked one time when i hit the Save Button from the SyncJob in the Android App. Edited July 30, 2019 by Brudertac
Luke 42245 Posted July 30, 2019 Posted July 30, 2019 4.2.0.40 on Synology DSM. With this Download do not work at all. With the earlier Version (4.1.1.0) it worked one time when i hit the Save Button from the SyncJob in the Android App. Let's look at an example. Please see how to report a problem. thanks !
groenator 13 Posted July 31, 2019 Posted July 31, 2019 I get the same problem when the storage is configured to sdcard. If I choose android internal storage sync works fine. Why am I not able to download/sync videos to sdcard?
Luke 42245 Posted August 1, 2019 Posted August 1, 2019 I get the same problem when the storage is configured to sdcard. If I choose android internal storage sync works fine. Why am I not able to download/sync videos to sdcard? There is an issue with external SD cards that we are looking into. Thanks.
Luke 42245 Posted August 17, 2019 Posted August 17, 2019 There are improvements in the app's beta channel if you'd like to help test those out: https://emby.media/community/index.php?/topic/76604-android-mobile-3069-new-download-manager/ Thanks.
