kmed27 19 Posted October 8, 2019 Author Posted October 8, 2019 Already tried that, lots of times, plus it creates new ones wrong as well, which is how I found the problem and what probably caused the old ones to be reset incorrectly.
SamES 1082 Posted October 10, 2019 Posted October 10, 2019 Are all the 3D movies that have aspect ratio issues full-SBS or are some of the half-SBS?
SamES 1082 Posted October 12, 2019 Posted October 12, 2019 (edited) Could you please show me the output like this for a file with the flag set, and also the same file with the 3D flag cleared. I believe the server is taking the aspect ratio directly from the file VideoID : 1Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L4.1MultiView_Count : 2MultiView_Layout : Side by Side (left eye first)Format settings : CABAC / 4 Ref FramesFormat settings, CABAC : YesFormat settings, RefFrames : 4 framesCodec ID : V_MPEG4/ISO/AVCDuration : 2 h 34 minBit rate : 11.5 Mb/sWidth : 1 920 pixelsHeight : 1 008 pixelsDisplay aspect ratio : 1.905Frame rate mode : ConstantFrame rate : 23.976 (24000/1001) FPSColor space : YUVChroma subsampling : 4:2:0Bit depth : 8 bitsScan type : ProgressiveBits/(Pixel*Frame) : 0.248Stream size : 12.4 GiB (95%)Writing library : x264 core 152 r2851 ba24899Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=11504 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / frame-packing=3 / ip_ratio=1.40 / aq=3:0.80Default : YesForced : NoColor range : LimitedMatrix coefficients : BT.709 Edited October 12, 2019 by SamES
kmed27 19 Posted October 12, 2019 Author Posted October 12, 2019 (edited) Hi, No problem, here's the same movie with the flag cleared: VideoID : 1Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L4.1Format settings : CABAC / 4 Ref FramesFormat settings, CABAC : YesFormat settings, RefFrames : 4 framesCodec ID : V_MPEG4/ISO/AVCDuration : 2 h 34 minBit rate : 11.5 Mb/sWidth : 1 920 pixelsHeight : 1 008 pixelsDisplay aspect ratio : 1.905Frame rate mode : ConstantFrame rate : 23.976 (24000/1001) FPSColor space : YUVChroma subsampling : 4:2:0Bit depth : 8 bitsScan type : ProgressiveBits/(Pixel*Frame) : 0.248Stream size : 12.4 GiB (95%)Writing library : x264 core 152 r2851 ba24899Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=11504 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / frame-packing=3 / ip_ratio=1.40 / aq=3:0.80Default : YesForced : NoColor range : LimitedMatrix coefficients : BT.709 This is Emby Media Info: Media InfoVideo Title1080p H264CodecH264AVCYesProfileHighLevel41Resolution1920x1008Aspect ratio40:21AnamorphicNoInterlacedNoFramerate23.976Bitrate12,143 kbpsColour spacebt709Bit depth8 bitPixel formatyuv420pRef frames1NAL4 Hope this helps. Edited October 12, 2019 by kmed27
SamES 1082 Posted October 13, 2019 Posted October 13, 2019 Is the 3D flag set when you receive the files, or are you adding this flag? None of my 3D files have this flag, and when it's set ffprobe is reporting the aspect ratio incorrectly. If you remove this flag does the file still work correctly in 3D? I'm not convinced the flag should be set.
kmed27 19 Posted October 13, 2019 Author Posted October 13, 2019 Yes it is, I have not added the flag manually, as I say some of my older 3D that worked when I first watched them, stopped working when I tested them whilst looking into this, so I assumed something changed recently-ish? Yes they do as I said before, if I remove the flag then emby shows the aspect ratio correctly and it plays as expected. I still don't understand why Plex works with them all correctly with or without the flag and auto switches into the correct 3D mode.
SamES 1082 Posted October 13, 2019 Posted October 13, 2019 It's possible that Plex is calculating the aspect ratio instead of using the ratio reported by ffprobe as Emby does. Tonight I'll add some sample output and get Luke to review it for options 1
SamES 1082 Posted October 14, 2019 Posted October 14, 2019 @@Luke, when the Stereo 3D flag is set in the mkv video stream header, the display_aspect_ratio gets bumped from 16:9 to 32:9, but the sample_aspect_ratio also goes from 1:1 to 2:1. When the server determines the aspect ratio it's only looking at display_aspect_ratio and results in images being stretched. To be honest, I'm not certain that the file is correct as none of my 3D movies have the Stereo 3D flag set, but that doesn't mean this is incorrect. Should the server (or client) be trying to handle this? Stream #0:0: Video: h264 (High), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], SAR 2:1 DAR 32:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: stereo_mode : left_right Side data: stereo3d: side by side Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default) "streams": [ { "index": 0, "codec_name": "h264", "codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10", "profile": "High", "codec_type": "video", "codec_time_base": "1001/48000", "codec_tag_string": "[0][0][0][0]", "codec_tag": "0x0000", "width": 1920, "height": 1080, "coded_width": 1920, "coded_height": 1088, "has_b_frames": 1, "sample_aspect_ratio": "2:1", "display_aspect_ratio": "32:9", "pix_fmt": "yuv420p", "level": 41, "chroma_location": "left", "field_order": "progressive", "refs": 1, "is_avc": "true", "nal_length_size": "4", "r_frame_rate": "24000/1001", "avg_frame_rate": "24000/1001", "time_base": "1/1000", "start_pts": 0, "start_time": "0.000000", "bits_per_raw_sample": "8", "disposition": { "default": 1, "dub": 0, "original": 0, "comment": 0, "lyrics": 0, "karaoke": 0, "forced": 0, "hearing_impaired": 0, "visual_impaired": 0, "clean_effects": 0, "attached_pic": 0, "timed_thumbnails": 0 }, "tags": { "stereo_mode": "left_right" }, "side_data_list": [ { "side_data_type": "Stereo 3D", "type": "side by side", "inverted": 0 } 1
kmed27 19 Posted October 24, 2019 Author Posted October 24, 2019 Did you manage to do anything about the problem?
Luke 42216 Posted October 24, 2019 Posted October 24, 2019 We're looking into it. Thanks for reporting.
kmed27 19 Posted January 21, 2020 Author Posted January 21, 2020 (edited) Hi, Have you been able to fix this? I am finding that nearly all my older 3D movies (which I have watched in the past on Emby with no problem) are in the same situation. Also, I notice that there is a 1.0.70 and 71 tizen talked about but Samsung still shows the .69 version. Edited January 21, 2020 by kmed27
SamES 1082 Posted January 21, 2020 Posted January 21, 2020 Hi, Have you been able to fix this? I am finding that nearly all my older 3D movies (which I have watched in the past on Emby with no problem) are in the same situation. Also, I notice that there is a 1.0.70 and 71 tizen talked about but Samsung still shows the .69 version. Not yet. Latest beta release can be loaded here via USB https://emby.media/community/index.php?/topic/74969-samsung-tizen-smarttv-2015-present-beta-app-install-from-usb/
