Luke 42235 Posted May 9, 2020 Posted May 9, 2020 For those testing this build, just fyi of some updates: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=881601 Thanks. 1
Marc_G 95 Posted May 11, 2020 Posted May 11, 2020 Great to see this moving along. I will run some tests this week. Sent from my ONEPLUS A6013 using Tapatalk
carguyshu 0 Posted May 17, 2020 Posted May 17, 2020 i have the overlay problem as well running on a windows 7 64 bit machine. it did it when i was using the built in intel video. i just installed a 1660 ti video card and its still doing it. i tried the version 12 and it fixes that issue, but when playing a bluray it causes frames to drop like crazy. i get no frame drops on version 11. everything is fully up to date and i've tried restarting both the program as well as the machine. is my best option going back to version 6 or doing the copy paste of the code mentioned a couple of pages back?
Luke 42235 Posted May 18, 2020 Posted May 18, 2020 i have the overlay problem as well running on a windows 7 64 bit machine. it did it when i was using the built in intel video. i just installed a 1660 ti video card and its still doing it. i tried the version 12 and it fixes that issue, but when playing a bluray it causes frames to drop like crazy. i get no frame drops on version 11. everything is fully up to date and i've tried restarting both the program as well as the machine. is my best option going back to version 6 or doing the copy paste of the code mentioned a couple of pages back? Does it still drop frames selecting a different hardware decoder?
sooty234 266 Posted May 18, 2020 Posted May 18, 2020 Hardware acceleration is broken in the test build. Only the copy modes work. Auto, defaults to dxva2-copy.
farsite 5 Posted May 18, 2020 Posted May 18, 2020 Hardware acceleration is broken in the test build. Only the copy modes work. Auto, defaults to dxva2-copy. Don't have bluray hooked up to computer but can confirm that ET12 is playing hi def video (1920*1080 @24 fps) using libmpv with no acceleration : dva2-copy
sooty234 266 Posted May 18, 2020 Posted May 18, 2020 Don't have bluray hooked up to computer but can confirm that ET12 is playing hi def video (1920*1080 @24 fps) using libmpv with no acceleration : dva2-copy dxva2-copy is acceleration, but not what it's supposed to be. And you're on Win 7 so d3d isn't supported. You could try nvdec copyback.
farsite 5 Posted May 18, 2020 Posted May 18, 2020 mind fart .... forgot about Win 7 - on Win 10 it used gpu renderer & d3d11va acceleration Win 7 nvdec copyback also worked - sorry about that
Raptor6L 29 Posted May 28, 2020 Posted May 28, 2020 Tested 3.0.12 on my laptop and the OSD came back. Excellent!!! Good work Devs! This is a problem that's been around for a long time now, and it's taken a while to get there but it looks like you all have gotten on top of if now. Great to see this wasn't just forgotten about. Looking forward to the official 3.0.12 release!
brentsw3 2 Posted May 30, 2020 Posted May 30, 2020 (edited) If somebody is interested I made little fix for this issue.. Find "main.js" (from electronapp folder) and replace with code below: (function () { var electron = require('electron'); var app = electron.app; // Module to control application life. var BrowserWindow = electron.BrowserWindow; // Module to create native browser window. var BrowserView = electron.BrowserView; // Module to create native browser window. // Keep a global reference of the window object, if you don't, the window will // be closed automatically when the JavaScript object is garbage collected. var mainWindow = null; var playerWindow = null; var hasAppLoaded = false; var enableDevTools = false; var enableDevToolsOnStartup = false; var initialShowEventsComplete = false; var previousBounds; var cecProcess; // Quit when all windows are closed. app.on('window-all-closed', function () { // On OS X it is common for applications and their menu bar // to stay active until the user quits explicitly with Cmd + Q if (process.platform != 'darwin') { app.quit(); } }); function getWebContents() { var win = mainWindow; if (win) { return win.webContents; } return null; } function onWindowMoved() { sendJavascript('window.dispatchEvent(new CustomEvent("move", {}));'); } var currentWindowState = 'Normal'; var restoreWindowState; function setWindowState(state) { restoreWindowState = null; var previousState = currentWindowState; if (state == 'Maximized') { state = 'Fullscreen'; } if (state == 'Minimized') { restoreWindowState = previousState; mainWindow.minimize(); playerWindow.minimize(); } else if (state == 'Fullscreen') { if (previousState == "Minimized") { mainWindow.restore(); playerWindow.restore(); } mainWindow.setFullScreen(true); playerWindow.setFullScreen(true); } else { if (previousState == "Minimized") { mainWindow.restore(); playerWindow.restore(); } else if (previousState == "Fullscreen") { mainWindow.setFullScreen(false); playerWindow.setFullScreen(false); } else if (previousState == "Maximized") { mainWindow.unmaximize(); playerWindow.unmaximize(); } } } function onWindowStateChanged(state) { currentWindowState = state; sendJavascript('document.windowState="' + state + '";document.dispatchEvent(new CustomEvent("windowstatechanged", {detail:{windowState:"' + state + '"}}));'); } function onMinimize() { onWindowStateChanged('Minimized'); } function onRestore() { var restoreState = restoreWindowState; restoreWindowState = null; if (restoreState && restoreState != 'Normal' && restoreState != 'Minimized') { setWindowState(restoreState); } else { onWindowStateChanged('Normal'); } } function onMaximize() { onWindowStateChanged('Maximized'); } function onEnterFullscreen() { onWindowStateChanged('Fullscreen'); if (initialShowEventsComplete) { mainWindow.setAlwaysOnTop(true); mainWindow.focus(); mainWindow.setMovable(false); //mainWindow.setResizable(false); } } function onLeaveFullscreen() { onWindowStateChanged('Normal'); if (initialShowEventsComplete) { mainWindow.setAlwaysOnTop(false); mainWindow.setMovable(true); //mainWindow.setResizable(true); } } function onUnMaximize() { onWindowStateChanged('Normal'); } var customFileProtocol = 'electronfile'; function addPathIntercepts() { var protocol = electron.protocol; var path = require('path'); protocol.registerFileProtocol(customFileProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customFileProtocol.length + 3); url = __dirname + '/' + url; url = url.split('?')[0]; callback({ path: path.normalize(url) }); }); //protocol.interceptHttpProtocol('https', function (request, callback) { // alert(request.url); // callback({ 'url': request.url, 'referrer': request.referrer, session: null }); //}); } function sleepSystem() { var sleepMode = require('sleep-mode'); sleepMode(function (err, stderr, stdout) { }); } function restartSystem() { } function shutdownSystem() { var powerOff = require('power-off'); powerOff(function (err, stderr, stdout) { }); } var windowStateOnLoad; function registerAppHost() { var protocol = electron.protocol; var customProtocol = 'electronapphost'; protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3); var parts = url.split('?'); var command = parts[0]; switch (command) { case 'windowstate-Normal': setWindowState('Normal'); break; case 'windowstate-Maximized': setWindowState('Maximized'); break; case 'windowstate-Fullscreen': setWindowState('Fullscreen'); break; case 'windowstate-Minimized': setWindowState('Minimized'); break; case 'exit': closeWindow(mainWindow); break; case 'sleep': sleepSystem(); break; case 'shutdown': shutdownSystem(); break; case 'restart': restartSystem(); break; case 'openurl': electron.shell.openExternal(url.substring(url.indexOf('url=') + 4)); break; case 'shellstart': var options = require('querystring').parse(parts[1]); startProcess(options, callback); return; case 'shellclose': closeProcess(require('querystring').parse(parts[1]).id, callback); return; case 'video-on': mainWindow.setResizable(false); break; case 'video-off': mainWindow.setResizable(true); break; case 'loaded': if (windowStateOnLoad) { setWindowState(windowStateOnLoad); } mainWindow.focus(); hasAppLoaded = true; onLoaded(); break; } callback(""); }); } function onLoaded() { //var globalShortcut = electron.globalShortcut; //globalShortcut.register('mediastop', function () { // sendCommand('stop'); //}); //globalShortcut.register('mediaplaypause', function () { //}); sendJavascript('window.PlayerWindowId="' + getWindowId(mainWindow) + '";'); } var processes = {}; function startProcess(options, callback) { var pid; var args = (options.arguments || '').split('|||'); try { var process = require('child_process').execFile(options.path, args, {}, function (error, stdout, stderr) { if (error) { console.log('Process closed with error: ' + error); } processes[pid] = null; var script = 'onChildProcessClosed("' + pid + '", ' + (error ? 'true' : 'false') + ');'; sendJavascript(script); }); pid = process.pid.toString(); processes[pid] = process; callback(pid); } catch (err) { alert('Error launching process: ' + err); } } function closeProcess(id, callback) { var process = processes[id]; if (process) { process.kill(); } callback(""); } function registerFileSystem() { var protocol = electron.protocol; var customProtocol = 'electronfs'; protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3).split('?')[0]; var fs = require('fs'); switch (url) { case 'fileexists': case 'directoryexists': var path = request.url.split('=')[1]; fs.access(path, (err) => { if (err) { console.error('fs access result for path: ' + err); callback('false'); } else { callback('true'); } }); break; default: callback(""); break; } }); } function registerServerdiscovery() { var protocol = electron.protocol; var customProtocol = 'electronserverdiscovery'; var serverdiscovery = require('./serverdiscovery/serverdiscovery-native'); protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3).split('?')[0]; switch (url) { case 'findservers': var timeoutMs = request.url.split('=')[1]; serverdiscovery.findServers(timeoutMs, callback); break; default: callback(""); break; } }); } function registerWakeOnLan() { var protocol = electron.protocol; var customProtocol = 'electronwakeonlan'; var wakeonlan = require('./wakeonlan/wakeonlan-native'); protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3).split('?')[0]; switch (url) { case 'wakeserver': var mac = request.url.split('=')[1].split('&')[0]; var options = { port: request.url.split('=')[2] }; wakeonlan.wake(mac, options, callback); break; default: callback(""); break; } }); } function alert(text) { electron.dialog.showMessageBox(mainWindow, { message: text.toString(), buttons: ['ok'] }); } function replaceAll(str, find, replace) { return str.split(find).join(replace); } function getAppBaseUrl() { var url = 'https://tv.emby.media'; //url = 'http://localhost:8088'; return url; } function getAppUrl() { var url = getAppBaseUrl() + '/index.html?autostart=false'; //url += '?v=' + new Date().getTime(); return url; } var startInfoJson; function loadStartInfo() { return new Promise(function (resolve, reject) { var os = require("os"); var path = require('path'); var fs = require('fs'); var topDirectory = path.normalize(__dirname); var pluginDirectory = path.normalize(__dirname + '/plugins'); var scriptsDirectory = path.normalize(__dirname + '/scripts'); fs.readdir(pluginDirectory, function (err, pluginFiles) { fs.readdir(scriptsDirectory, function (err, scriptFiles) { pluginFiles = pluginFiles || []; scriptFiles = scriptFiles || []; var startInfo = { paths: { apphost: customFileProtocol + '://apphost', shell: customFileProtocol + '://shell', wakeonlan: customFileProtocol + '://wakeonlan/wakeonlan', serverdiscovery: customFileProtocol + '://serverdiscovery/serverdiscovery', fullscreenmanager: 'file://' + replaceAll(path.normalize(topDirectory + '/fullscreenmanager.js'), '\\', '/'), filesystem: customFileProtocol + '://filesystem' }, name: app.getName(), version: app.getVersion(), deviceName: os.hostname(), deviceId: os.hostname(), supportsTransparentWindow: supportsTransparentWindow(), plugins: pluginFiles.filter(function (f) { return f.indexOf('.js') != -1; }).map(function (f) { return 'file://' + replaceAll(path.normalize(pluginDirectory + '/' + f), '\\', '/'); }), scripts: scriptFiles.map(function (f) { return 'file://' + replaceAll(path.normalize(scriptsDirectory + '/' + f), '\\', '/'); }) }; startInfoJson = JSON.stringify(startInfo); resolve(); }); }); }); } function setStartInfo() { var script = 'function startWhenReady(){if (self.Emby && self.Emby.App){self.appStartInfo=' + startInfoJson + ';Emby.App.start(appStartInfo);} else {setTimeout(startWhenReady, 50);}} startWhenReady();'; sendJavascript(script); //sendJavascript('var appStartInfo=' + startInfoJson + ';'); } function sendCommand(cmd) { var script = "require(['inputmanager'], function(inputmanager){inputmanager.trigger('" + cmd + "');});"; sendJavascript(script); } function sendJavascript(script) { // Add some null checks to handle attempts to send JS when the process is closing or has closed try { var web = getWebContents(); if (web) { web.executeJavaScript(script); } } catch (err) { console.log('error sending javascript: ' + err); } } function onAppCommand(e, cmd) { //switch (command_id) { // case APPCOMMAND_BROWSER_BACKWARD : return "browser-backward"; // case APPCOMMAND_BROWSER_FORWARD : return "browser-forward"; // case APPCOMMAND_BROWSER_REFRESH : return "browser-refresh"; // case APPCOMMAND_BROWSER_STOP : return "browser-stop"; // case APPCOMMAND_BROWSER_SEARCH : return "browser-search"; // case APPCOMMAND_BROWSER_FAVORITES : return "browser-favorites"; // case APPCOMMAND_BROWSER_HOME : return "browser-home"; // case APPCOMMAND_VOLUME_MUTE : return "volume-mute"; // case APPCOMMAND_VOLUME_DOWN : return "volume-down"; // case APPCOMMAND_VOLUME_UP : return "volume-up"; // case APPCOMMAND_MEDIA_NEXTTRACK : return "media-nexttrack"; // case APPCOMMAND_MEDIA_PREVIOUSTRACK : return "media-previoustrack"; // case APPCOMMAND_MEDIA_STOP : return "media-stop"; // case APPCOMMAND_MEDIA_PLAY_PAUSE : return "media-play-pause"; // case APPCOMMAND_LAUNCH_MAIL : return "launch-mail"; // case APPCOMMAND_LAUNCH_MEDIA_SELECT : return "launch-media-select"; // case APPCOMMAND_LAUNCH_APP1 : return "launch-app1"; // case APPCOMMAND_LAUNCH_APP2 : return "launch-app2"; // case APPCOMMAND_BASS_DOWN : return "bass-down"; // case APPCOMMAND_BASS_BOOST : return "bass-boost"; // case APPCOMMAND_BASS_UP : return "bass-up"; // case APPCOMMAND_TREBLE_DOWN : return "treble-down"; // case APPCOMMAND_TREBLE_UP : return "treble-up"; // case APPCOMMAND_MICROPHONE_VOLUME_MUTE : return "microphone-volume-mute"; // case APPCOMMAND_MICROPHONE_VOLUME_DOWN : return "microphone-volume-down"; // case APPCOMMAND_MICROPHONE_VOLUME_UP : return "microphone-volume-up"; // case APPCOMMAND_HELP : return "help"; // case APPCOMMAND_FIND : return "find"; // case APPCOMMAND_NEW : return "new"; // case APPCOMMAND_OPEN : return "open"; // case APPCOMMAND_CLOSE : return "close"; // case APPCOMMAND_SAVE : return "save"; // case APPCOMMAND_PRINT : return "print"; // case APPCOMMAND_UNDO : return "undo"; // case APPCOMMAND_REDO : return "redo"; // case APPCOMMAND_COPY : return "copy"; // case APPCOMMAND_CUT : return "cut"; // case APPCOMMAND_PASTE : return "paste"; // case APPCOMMAND_REPLY_TO_MAIL : return "reply-to-mail"; // case APPCOMMAND_FORWARD_MAIL : return "forward-mail"; // case APPCOMMAND_SEND_MAIL : return "send-mail"; // case APPCOMMAND_SPELL_CHECK : return "spell-check"; // case APPCOMMAND_MIC_ON_OFF_TOGGLE : return "mic-on-off-toggle"; // case APPCOMMAND_CORRECTION_LIST : return "correction-list"; // case APPCOMMAND_MEDIA_PLAY : return "media-play"; // case APPCOMMAND_MEDIA_PAUSE : return "media-pause"; // case APPCOMMAND_MEDIA_RECORD : return "media-record"; // case APPCOMMAND_MEDIA_FAST_FORWARD : return "media-fast-forward"; // case APPCOMMAND_MEDIA_REWIND : return "media-rewind"; // case APPCOMMAND_MEDIA_CHANNEL_UP : return "media-channel-up"; // case APPCOMMAND_MEDIA_CHANNEL_DOWN : return "media-channel-down"; // case APPCOMMAND_DELETE : return "delete"; // case APPCOMMAND_DICTATE_OR_COMMAND_CONTROL_TOGGLE: // return "dictate-or-command-control-toggle"; // default: // return "unknown"; if (cmd != 'Unknown') { //alert(cmd); } switch (cmd) { case 'browser-backward': sendCommand("back"); break; case 'browser-forward': if (getWebContents().canGoForward()) { getWebContents().goForward(); } break; case 'browser-stop': sendCommand("stop"); break; case 'browser-search': sendCommand("search"); break; case 'browser-favorites': sendCommand("favorites"); break; case 'browser-home': sendCommand("home"); break; case 'browser-refresh': sendCommand("refresh"); break; case 'find': sendCommand("search"); break; case 'volume-mute': sendCommand("togglemute"); break; case 'volume-down': sendCommand("volumedown"); break; case 'volume-up': sendCommand("volumeup"); break; case 'media-nexttrack': sendCommand("next"); break; case 'media-previoustrack': sendCommand("previous"); break; case 'media-stop': sendCommand("stop"); break; case 'media-play': sendCommand("play"); break; case 'media-pause': sendCommand("pause"); break; case 'media-record': sendCommand("record"); break; case 'media-fast-forward': sendCommand("fastforward"); break; case 'media-rewind': sendCommand("rewind"); break; case 'media-play-pause': sendCommand("playpause"); break; case 'media-channel-up': sendCommand("channelup"); break; case 'media-channel-down': sendCommand("channeldown"); break; case 'menu': sendCommand("menu"); break; case 'info': sendCommand("info"); break; } } function setCommandLineSwitches() { var isLinux = require('is-linux'); if (isLinux()) { app.commandLine.appendSwitch('enable-transparent-visuals'); app.disableHardwareAcceleration(); } else if (process.platform === 'win32') { //app.disableHardwareAcceleration(); app.commandLine.appendSwitch('high-dpi-support', 'true'); app.commandLine.appendSwitch('force-device-scale-factor', '1'); } } function supportsTransparentWindow() { return true; } function getWindowStateDataPath() { var path = require("path"); return path.join(app.getPath('userData'), "windowstate.json"); } function closeWindow(win) { try { win.close(); } catch (err) { console.log('Error closing window. It may have already been closed. ' + err); } } function onWindowClose() { if (hasAppLoaded) { var data = mainWindow.getBounds(); data.state = currentWindowState; var windowStatePath = getWindowStateDataPath(); require("fs").writeFileSync(windowStatePath, JSON.stringify(data)); } sendJavascript('AppCloseHelper.onClosing();'); // Unregister all shortcuts. electron.globalShortcut.unregisterAll(); closeWindow(playerWindow); if (cecProcess) { cecProcess.kill(); } //app.quit(); } function parseCommandLine() { var isWindows = require('is-windows'); var fs = require('fs'); var isRpi = require('detect-rpi'); var path = require('path'); var result = {}; var commandLineArguments = process.argv.slice(2); var index = 0; if (isWindows()) { result.userDataPath = commandLineArguments[index]; index++; } result.cecExePath = commandLineArguments[index] || 'cec-client'; index++; var mpvPathRpi = path.join(__dirname, 'bin', 'mpv'); if (isRpi() && fs.existsSync(mpvPathRpi)) { result.mpvPath = mpvPathRpi; } else { result.mpvPath = commandLineArguments[index]; } index++; return result; } var commandLineOptions = parseCommandLine(); var userDataPath = commandLineOptions.userDataPath; if (userDataPath) { app.setPath('userData', userDataPath); } function onCecCommand(cmd) { console.log("Command received: " + cmd); sendCommand(cmd); } /* CEC Module */ function initCec() { try { const cec = require('./cec/cec'); var cecExePath = commandLineOptions.cecExePath; // create the cec event const EventEmitter = require("events").EventEmitter; var cecEmitter = new EventEmitter(); var cecOpts = { cecExePath: cecExePath, cecEmitter: cecEmitter }; cecProcess = cec.init(cecOpts); cecEmitter.on("receive-cmd", onCecCommand); } catch (err) { console.log('error initializing cec: ' + err); } } function getWindowId(win) { var Long = require("long"); var os = require("os"); var handle = win.getNativeWindowHandle(); if (os.endianness() == "LE") { if (handle.length == 4) { handle.swap32(); } else if (handle.length == 8) { handle.swap64(); } else { console.log("Unknown Native Window Handle Format."); } } var longVal = Long.fromString(handle.toString('hex'), unsigned = true, radix = 16); return longVal.toString(); } function initPlaybackHandler(mpvPath) { var playbackhandler = require('./playbackhandler/playbackhandler'); playbackhandler.initialize(getWindowId(playerWindow), mpvPath); playbackhandler.registerMediaPlayerProtocol(electron.protocol, mainWindow); playbackhandler.setNotifyWebViewFn(sendJavascript); } setCommandLineSwitches(); var windowShowCount = 0; function onWindowShow() { windowShowCount++; if (windowShowCount == 2) { //mainWindow.center(); mainWindow.focus(); initialShowEventsComplete = true; } var isRpi = require('detect-rpi'); if (isRpi()) { mainWindow.setFullScreen(true); } } //app.on('quit', function () { // closeWindow(mainWindow); //}); // This method will be called when Electron has finished // initialization and is ready to create browser windows. app.on('ready', function () { var isWindows = require('is-windows'); var windowStatePath = getWindowStateDataPath(); var previousWindowInfo; try { previousWindowInfo = JSON.parse(require("fs").readFileSync(windowStatePath, 'utf8')); } catch (e) { previousWindowInfo = {}; } var windowOptions = { transparent: true, //supportsTransparency, frame: false, resizable: true, title: 'Emby Theater', minWidth: 720, minHeight: 480, //alwaysOnTop: true, //skipTaskbar: isWindows() ? false : true, //show: false, backgroundColor: '#00000000', center: true, show: false, webPreferences: { webSecurity: false, webgl: false, nodeIntegration: false, nodeIntegrationInWorker: false, plugins: false, webaudio: true, java: false, allowDisplayingInsecureContent: true, allowRunningInsecureContent: true, experimentalFeatures: false, devTools: enableDevTools, enableRemoteModule: false, sandbox: false }, icon: __dirname + '/icon.ico' }; windowOptions.width = previousWindowInfo.width || 1280; windowOptions.height = previousWindowInfo.height || 720; if (previousWindowInfo.x != null && previousWindowInfo.y != null) { windowOptions.x = previousWindowInfo.x; windowOptions.y = previousWindowInfo.y; } playerWindow = new BrowserWindow(windowOptions); windowOptions.parent = playerWindow; // Create the browser window. loadStartInfo().then(function () { mainWindow = new BrowserWindow(windowOptions); if (enableDevToolsOnStartup) { mainWindow.openDevTools(); } getWebContents().on('dom-ready', setStartInfo); var url = getAppUrl(); windowStateOnLoad = previousWindowInfo.state; addPathIntercepts(); registerAppHost(); registerFileSystem(); registerServerdiscovery(); registerWakeOnLan(); // and load the index.html of the app. mainWindow.loadURL(url); mainWindow.setMenu(null); mainWindow.on('move', onWindowMoved); mainWindow.on('app-command', onAppCommand); mainWindow.on("close", onWindowClose); mainWindow.on("minimize", onMinimize); mainWindow.on("maximize", onMaximize); mainWindow.on("enter-full-screen", onEnterFullscreen); mainWindow.on("leave-full-screen", onLeaveFullscreen); mainWindow.on("restore", onRestore); mainWindow.on("unmaximize", onUnMaximize); playerWindow.on("show", onWindowShow); mainWindow.on("show", onWindowShow); playerWindow.show(); mainWindow.show(); initCec(); initPlaybackHandler(commandLineOptions.mpvPath); }); }); })(); Tested with latest Theater (beta). At least its working on my Windows 10 and Intel Graphics 4000.. Edited May 30, 2020 by brentsw3
brentsw3 2 Posted May 30, 2020 Posted May 30, 2020 I been getting super annoyed at your long a$$ post and everyone that keeps quoting it but hey, it frigging works so thanks mate!! 1
Pilot 0 Posted June 2, 2020 Posted June 2, 2020 So this is not the new app I've been mentioning, but just for a quick test, can you please try this build and let me know if you're able to see the video OSD? https://www.dropbox.com/s/e19u0c6m05g1drx/embytheater.zip?dl=0 Thanks. It works! After over a year of frustration due to the missing OSD, it's finally visible on my main HTPC again. Appreciate you finally figuring this out. System specs: Win 10 v1909, build 18363.836 i3-3225 @ 3.30GHz, 8GB RAM Intel HD Graphics 4000 (driver v10.18.10.5069)
nairnmonster 6 Posted June 8, 2020 Posted June 8, 2020 Luke, on 28 Apr 2020 - 8:54 PM, said: So this is not the new app I've been mentioning, but just for a quick test, can you please try this build and let me know if you're able to see the video OSD? https://www.dropbox....heater.zip?dl=0 Thanks. I just tried this and it worked for me. I tried 3.0.10 & 11. I'm on a Lenovo T420 stock with an SSD.
mentasm 43 Posted June 16, 2020 Posted June 16, 2020 How long until this fix will make it in to the main release? The standalone fix did work for me, but I'm still daily driving the old release for now.
brentsw3 2 Posted June 16, 2020 Posted June 16, 2020 How long until this fix will make it in to the main release? The standalone fix did work for me, but I'm still daily driving the old release for now.Well the main.js fix posted earlier, works on 3.0.11. I've applied the fix on 3 different machines now. Sent from my GM1910 using Tapatalk
sooty234 266 Posted June 16, 2020 Posted June 16, 2020 7 hours ago, brentsw3 said: Well the main.js fix posted earlier, works on 3.0.11. I've applied the fix on 3 different machines now. Sent from my GM1910 using Tapatalk It isn't a fix. It's a regression, and reintroduces the original problems. It won't work well for everyone. There is a possible half way 'fix' where there is an option to choose between libmpv and gpu rendering. But again, not a true fix, as libmpv with electron can't use direct hardware acceleration. There is a possibility of a side loadable version of the actual new app with the new UI, at some point. We're basically waiting for Microsoft to get their ass in gear.
brentsw3 2 Posted June 17, 2020 Posted June 17, 2020 19 hours ago, sooty234 said: It isn't a fix. It's a regression, and reintroduces the original problems. It won't work well for everyone. There is a possible half way 'fix' where there is an option to choose between libmpv and gpu rendering. But again, not a true fix, as libmpv with electron can't use direct hardware acceleration. There is a possibility of a side loadable version of the actual new app with the new UI, at some point. We're basically waiting for Microsoft to get their ass in gear. Quite possible, I don't consider myself a power user of Emby, well on a Windows platform. I mainly consume media on my iPad, where it works beautifully!! What I will say, not having OSD is a MAJOR obstacle to using Emby on Windows. Whatever original problems/regression you referring to might be deemed insignificant compared with a missing OSD.
heciruam 30 Posted July 7, 2020 Posted July 7, 2020 (edited) 3.0.11 fixed it for a day. Now the Overlay is missing again. Edit: OK I was an idiot and didn't realize that I now had two different installs. The 0.12 works for me too with the hd4000 igpu Edited July 23, 2020 by heciruam
Mobius 18 Posted July 9, 2020 Posted July 9, 2020 (edited) Hey Luke Had pretty much walked away from this given the time frame. Settled for 3.0.06 as a workaround. However just tried the Test (3.0.12). Has Fixed my overlay issue and all else seems to be working just fine. Many thanks! Machine that had the issue has a i7-3610QM with Nvidia Optimus running Win10 64bit. No problem when using either: Nvidia GT 630M or Intel HD Graphics 4000. Hope this finds you and your family in good health. Edited July 9, 2020 by Mobius Wanted to emphasis my thanks. 2
BuddahKat 17 Posted July 22, 2020 Posted July 22, 2020 Any idea when 3.0.12 will be released? Been waiting on this overlap fix for a long time
Luke 42235 Posted July 30, 2020 Posted July 30, 2020 On 7/22/2020 at 1:26 AM, BuddahKat said: Any idea when 3.0.12 will be released? Been waiting on this overlap fix for a long time We're working on it. I don't have an ETA yet though.
Spotta 6 Posted August 14, 2020 Posted August 14, 2020 Further observations with 3.0.12. I only get the volume overlay pop up to show the current volume when turning the volume down, turning it up it does not appear. Watching in progress recordings much quicker/reliable.
