Luke 42239 Posted November 18, 2019 Posted November 18, 2019 Yes these changes will all be in the upcoming 4.3 stable release. Thanks.
warloxxjay 0 Posted February 3, 2020 Posted February 3, 2020 So I finally came around to install version 4.3.1.0. But sadly I can't get this to work. I modified the options.xml to say (while emby was off): <IgnoreFileExtensions>".dng",".cr2",".raw",".CR2"</IgnoreFileExtensions> booted up emby and did "Scan Library Files" but the files still show up. I also noticed that the setting vanishes/get cleared when I edit the library in the GUI. This looks like I experienced this bug. Or is it normal that "hidden settings" will get reset when using the gui? Also deleted that library and re-created it since the bug above mentioned that it only happened with old libraries, but that didn't help. I also tried different formats of entering the setting: <IgnoreFileExtensions>.dng,.cr2,.raw,.CR2</IgnoreFileExtensions> <IgnoreFileExtensions>".CR2"</IgnoreFileExtensions> <IgnoreFileExtensions><string>.dng</string><string>.cr2</string><string>.raw</string><string>.CR2</string></IgnoreFileExtensions> Although I did not restart the server every time (which also cleared the setting from the opention.xml again btw.) so I'm not sure if it would have been picked up the server as new settings when doing "Scan Library Files"
Luke 42239 Posted February 4, 2020 Posted February 4, 2020 Yes i can see how the values will be lost when using the UI. We'll look at that. I would have expected this to work though: <IgnoreFileExtensions><string>.dng</string><string>.cr2</string><string>.raw</string><string>.CR2</string></IgnoreFileExtensions> Make sure the server is off when you customize it.
warloxxjay 0 Posted February 4, 2020 Posted February 4, 2020 That actually worked. I guess when I tried it before the server was not off while setting it. I also checked if opening the library edit gui clears the setting. It did not. So everything works fine now. Tanks again for this feature
