Libelle78 0 Posted March 17, 2019 Posted March 17, 2019 Hallo, funktioniert bei jemanden Wake on Lan auf einem FireTv Stick? bei mir nicht.... Jedoch weckt die Windows app, sowie meine Handy Android app den Windows HomeServer ohne probleme. Kann jemand helfen? Danke
ebr 16334 Posted March 19, 2019 Posted March 19, 2019 Hi. This should work provided the network is allowing the magic packets.
Libelle78 0 Posted March 19, 2019 Author Posted March 19, 2019 Hi,magic pakcets are no problem in my network.Windows, Librelec, Kodi on the FireTVStick, Libreelec, Android on my Mobilephone.Emby on Mobilephone, Emby on Windows 10 etc. just on Android TV, like FireTVStick and Nvidia Shield don´t wake up my Server. I start the emby app on FireTVStickI got a windwos with: cancel, wake, removei select wake but the Server don´t wake
Luke 42241 Posted March 19, 2019 Posted March 19, 2019 So you're able to wake the server using our mobile android app?
Libelle78 0 Posted March 20, 2019 Author Posted March 20, 2019 (edited) Yes, With my mobile Android App Works wake on lan. And with my firetv with androidTV don't work. But with my firetv with a other App like kodi it works. Sorry for my Bad english What The different between both apps Edited March 20, 2019 by Libelle78
ebr 16334 Posted March 20, 2019 Posted March 20, 2019 Okay, I just tested this again. I put my server machine to sleep. Then brought up the Android TV app and, when it timed out trying to connect to the server, I got a dialog telling me so and offering the option to wake the server (the default button). Pressed this button and my machine immediately woke up. What version is the server and on what OS/platform?
Libelle78 0 Posted March 20, 2019 Author Posted March 20, 2019 I have an Windows HomeServer WHS2011 with an Asus P8h67-m My Router is a Fritzbox 6490 Please help
ebr 16334 Posted March 20, 2019 Posted March 20, 2019 Can you please try the beta version on your Android TV device? NOT the Fire, it doesn't have a beta.
Libelle78 0 Posted March 21, 2019 Author Posted March 21, 2019 1.6.95g i get a message error trying to wake serser
ebr 16334 Posted March 21, 2019 Posted March 21, 2019 Well, that's quite interesting and explains why it wasn't working for you before. Can you please reproduce that error and then send a log from the app?
Libelle78 0 Posted March 21, 2019 Author Posted March 21, 2019 (edited) Hi, just in the Moment, i send the log my Emby User is Steffen which more infomations do you need? Edited March 21, 2019 by Libelle78
Libelle78 0 Posted March 22, 2019 Author Posted March 22, 2019 Hi,i tried, the server don't wake.I just sent another log
ebr 16334 Posted March 22, 2019 Posted March 22, 2019 We are sending out the wake attempt but we are having to send it on the default broadcast address of 255.255.255.255 because your server is not providing us with a specific one. I'm not sure why it isn't working for you.
Libelle78 0 Posted March 22, 2019 Author Posted March 22, 2019 (edited) maybe I can enter the mac address manually? Edited March 22, 2019 by Libelle78
ebr 16334 Posted March 22, 2019 Posted March 22, 2019 The mac address isn't the problem (I don't think). It is the broadcast IP address. Is your server on a different subnet from the app device?
Libelle78 0 Posted March 23, 2019 Author Posted March 23, 2019 (edited) My subset ist 255.255.255.0 for the completly network 192.168.1.xx for all device Does a other Log from a Android mobile Help? Edited March 23, 2019 by Libelle78
ebr 16334 Posted March 23, 2019 Posted March 23, 2019 Does a other Log from a Android mobile Help? Definitely worth taking a look at. Thanks.
Libelle78 0 Posted March 23, 2019 Author Posted March 23, 2019 how can i make a log in android mobile app
ebr 16334 Posted March 23, 2019 Posted March 23, 2019 I believe this is still accurate: How to report an Android problem
Luke 42241 Posted March 23, 2019 Posted March 23, 2019 The mobile app doesn't produce a log file anymore. What do you need that for?
Libelle78 0 Posted March 23, 2019 Author Posted March 23, 2019 (edited) i hope you can see, how the android app wake the my server and then you can see what the problem is with androidTV on my shield Edited March 23, 2019 by Libelle78
ebr 16334 Posted March 23, 2019 Posted March 23, 2019 The two apps are using the same code right now and I can see in the Android TV log that we did successfully send the wake command. The only thing I can think of at this point is network differences. Your mobile is obviously on wireless. How is the Shield connected to the network?
