reddragon1nz 0 Posted May 9, 2014 Posted May 9, 2014 Hi everyone. Loving Media Browser 3 Especially Live Tv Only issue, Nothing has any images/meta images What other information do you need so I can get some help with this. Never any pics but im media centre I have pics in the guide. Thanks
krustyreturns 191 Posted May 9, 2014 Posted May 9, 2014 Assuming this is serverwmc you are running for livetv. Is everything else working, in particular the playback of recorded tv shows, from the same client that is having this image problem?
snazy2000 344 Posted May 10, 2014 Posted May 10, 2014 I get the same issue and everything else works fine. Sent from my HTC One using Tapatalk
krustyreturns 191 Posted May 10, 2014 Posted May 10, 2014 If either you are running serverwmc, post the serverwmc log after mbs loads the database.
reddragon1nz 0 Posted May 11, 2014 Author Posted May 11, 2014 2014/05/12 10:30:36.936 ServerWMC started at 12/05/2014 10:30:36 a.m.2014/05/12 10:30:36.936 Assembly version: 1.0.0.29, build: 11352014/05/12 10:30:36.936 Config file version: 632014/05/12 10:30:36.938 Click-once deployment: False2014/05/12 10:30:36.938 Server MachineName: MEDIACENTRE2014/05/12 10:30:36.939 OS: Windows 8 64-bit2014/05/12 10:30:36.940 OS Version: 6.2.9200.02014/05/12 10:30:37.992 Processor: Intel® Core i7-2600K CPU @ 3.40GHz2014/05/12 10:30:38.002 Graphics: Intel® HD Graphics 30002014/05/12 10:30:38.002 -----------------------------------------2014/05/12 10:30:38.002 Non-default Config Settings -------------2014/05/12 10:30:38.023 ForcedRadioChannelRanges: System.Collections.Generic.Dictionary`2[system.Double,System.Double] >>Default: -null-2014/05/12 10:30:38.023 ListenPort: 9090 >>Default: 90802014/05/12 10:30:38.025 -----------------------------------------2014/05/12 10:30:38.030 MainWindow> Starting InitializeWorker2014/05/12 10:30:38.051 RecService> Starting ------------------2014/05/12 10:30:38.054 EPG> loading...2014/05/12 10:30:38.055 EPG> opening store2014/05/12 10:30:38.089 EPG> TV store opened OK2014/05/12 10:30:38.093 EnumerateRecorders> Tuner Devices and TuningSpaces found:2014/05/12 10:30:38.111 EnumerateRecorders> 0 Content Recorder HardwareBaseId: {78a47285-378f-11e3-8251-806e6f6e6963}2014/05/12 10:30:38.112 EnumerateRecorders> HardwareId: {78a47285-378f-11e3-8251-806e6f6e6963}102014/05/12 10:30:38.137 EnumerateRecorders> count: 0 Device name: Hauppauge WinTV 88x DVB-T Tuner/Demod #1, TuningSpace: DVB-T2014/05/12 10:30:38.137 EnumerateRecorders> count: 1 Device name: Hauppauge WinTV 88x Tuner #2, TuningSpace: FM Radio2014/05/12 10:30:38.137 EnumerateRecorders> 1 Content Recorder HardwareBaseId: {78a47286-378f-11e3-8251-806e6f6e6963}2014/05/12 10:30:38.137 EnumerateRecorders> HardwareId: {78a47286-378f-11e3-8251-806e6f6e6963}102014/05/12 10:30:38.138 EnumerateRecorders> count: 0 Device name: Hauppauge WinTV 88x DVB-T Tuner/Demod #2, TuningSpace: DVB-T2014/05/12 10:30:38.138 EnumerateRecorders> count: 1 Device name: Hauppauge WinTV 88x Tuner #1, TuningSpace: FM Radio2014/05/12 10:30:38.138 EnumerateRecorders> done2014/05/12 10:30:38.147 GetLineUpsAndChannels> started2014/05/12 10:30:38.259 GetLineUpsAndChannels> Total LineUps: 1, Total channels imported: 232014/05/12 10:30:38.259 GetLineUpsAndChannels> Channels found in database: 442014/05/12 10:30:38.259 GetLineUpsAndChannels> Ignored Channels> Blocked in WMC: 14, User hidden: 02014/05/12 10:30:38.259 GetLineUpsAndChannels> Strange Channels> Null space: 0, Out-of-range(ignored): 7, Radio: 02014/05/12 10:30:38.259 GetLineUpsAndChannels> Protected Channels> encrypted: 0, DRM: 02014/05/12 10:30:38.259 GetLineUpsAndChannels> Edited Channels> Callsigns: 0, Numbers: 162014/05/12 10:30:38.259 GetLineUpsAndChannels> Channel Groups found: 12014/05/12 10:30:38.259 GetLineUpsAndChannels> Ignored Channel Groups> Blocked in WMC: 0, Empty groups: 02014/05/12 10:30:38.259 GetLineUpsAndChannels> done2014/05/12 10:30:38.259 EPG> loading done2014/05/12 10:30:38.522 StartRecordingLibraryWatcher> recording library watcher started2014/05/12 10:30:38.834 RecService> EventScheduler started2014/05/12 10:30:38.834 RecService> tuner priming turned off2014/05/12 10:30:38.835 LoadGenreDict> 'GenreDict.xml' loaded OK2014/05/12 10:30:38.839 CheckChannelIcons> Channel icons processed: 212014/05/12 10:30:38.839 RecService> -------------(DONE)----------------2014/05/12 10:30:38.843 HandleFolders ------------------------------------2014/05/12 10:30:38.845 --- Share detail for 'E:\Recorded TV\':2014/05/12 10:30:38.847 > shared with: Everyone | FullControl | ContainerInherit, ObjectInherit | None | Allow2014/05/12 10:30:38.848 > shared with: NT AUTHORITY\Authenticated Users | DeleteSubdirectoriesAndFiles, Modify, Synchronize | ContainerInherit, ObjectInherit | None | Allow2014/05/12 10:30:38.848 > shared with: S-1-5-80-2913099195-3001839937-1914692661-1563395363-459793767 | DeleteSubdirectoriesAndFiles, Modify, Synchronize | ContainerInherit, ObjectInherit | None | Allow2014/05/12 10:30:38.848 > shared with: NT SERVICE\ehSched | DeleteSubdirectoriesAndFiles, Modify, Synchronize | ContainerInherit, ObjectInherit | None | Allow2014/05/12 10:30:38.848 > shared with: NT SERVICE\ehRecvr | DeleteSubdirectoriesAndFiles, Modify, Synchronize | ContainerInherit, ObjectInherit | None | Allow2014/05/12 10:30:38.848 > shared with: BUILTIN\Administrators | FullControl | None | None | Allow2014/05/12 10:30:38.848 > shared with: BUILTIN\Administrators | 268435456 | ContainerInherit, ObjectInherit | InheritOnly | Allow2014/05/12 10:30:38.848 > shared with: NT AUTHORITY\SYSTEM | FullControl | None | None | Allow2014/05/12 10:30:38.848 > shared with: NT AUTHORITY\SYSTEM | 268435456 | ContainerInherit, ObjectInherit | InheritOnly | Allow2014/05/12 10:30:38.848 > shared with: NT AUTHORITY\Authenticated Users | Modify, Synchronize | None | None | Allow2014/05/12 10:30:38.848 > shared with: NT AUTHORITY\Authenticated Users | -536805376 | ContainerInherit, ObjectInherit | InheritOnly | Allow2014/05/12 10:30:38.848 > shared with: BUILTIN\Users | ReadAndExecute, Synchronize | None | None | Allow2014/05/12 10:30:38.848 > shared with: BUILTIN\Users | -1610612736 | ContainerInherit, ObjectInherit | InheritOnly | Allow2014/05/12 10:30:38.848 ----2014/05/12 10:30:38.850 Local WMC 'RecTV' folder: 'E:\Recorded TV\', ShareStatus: OK2014/05/12 10:30:38.851 Format: NTFS2014/05/12 10:30:38.851 Stored Network 'Recorded tv' path:2014/05/12 10:30:38.851 > Samba: smb://MEDIACENTRE/Recorded TV2014/05/12 10:30:38.869 > UNC: \\MEDIACENTRE\Recorded TV, ShareStatus: OK2014/05/12 10:30:38.871 HandleFolders -------------(DONE)----------------2014/05/12 10:30:39.011 SocketServer> starting up SocketServer2014/05/12 10:30:39.011 SocketServer> permission to access sockets granted2014/05/12 10:30:39.013 SocketServer> socket object created2014/05/12 10:30:39.016 SocketServer> started on port: 90902014/05/12 10:30:39.016 Worker::Init> MaintenanceTimer created2014/05/12 10:30:39.016 InitializeWorker> successfully started: True2014/05/12 10:30:39.016 MaintenanceTimer> callback at 10:30 a.m.2014/05/12 10:30:39.060 MaintenanceTimer> callback - complete2014/05/12 10:30:39.099 MainWindow::Window_Loaded> not running as service, checking folder status.2014/05/12 10:30:39.100 MainWindow::Window_Loaded> Done2014/05/12 10:30:44.501 Client: 'MediaBrowser^' addon Version: 1.0.0.29, Client OS: windows 6.2.9200.02014/05/12 10:30:44.501 Client: 'MediaBrowser^' running remotely: False2014/05/12 10:30:44.502 Client: 'MediaBrowser^' path to Rec Folder: 'E:\Recorded TV\'2014/05/12 10:30:44.506 Received client request: MediaBrowser^@MEDIACENTRE@|GetServerVersion2014/05/12 10:30:44.506 Finished request GetServerVersion in 0.00s2014/05/12 10:30:44.507 Received client request: MediaBrowser^@MEDIACENTRE@|GetChannels2014/05/12 10:30:44.561 Finished request GetChannels in 0.05s2014/05/12 10:30:44.587 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46234|1399843844|14004486442014/05/12 10:30:44.627 Finished request GetEntries in 0.04s2014/05/12 10:30:44.655 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46243|1399843844|14004486442014/05/12 10:30:44.683 Finished request GetEntries in 0.03s2014/05/12 10:30:44.702 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46182|1399843844|14004486442014/05/12 10:30:44.740 Finished request GetEntries in 0.04s2014/05/12 10:30:44.769 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46191|1399843844|14004486442014/05/12 10:30:44.812 Finished request GetEntries in 0.04s2014/05/12 10:30:44.832 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|45986|1399843844|14004486442014/05/12 10:30:44.856 Finished request GetEntries in 0.02s2014/05/12 10:30:44.869 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46252|1399843844|14004486442014/05/12 10:30:44.885 Finished request GetEntries in 0.02s2014/05/12 10:30:44.898 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46261|1399843844|14004486442014/05/12 10:30:44.922 Finished request GetEntries in 0.02s2014/05/12 10:30:44.935 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46200|1399843844|14004486442014/05/12 10:30:44.972 Finished request GetEntries in 0.04s2014/05/12 10:30:44.990 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46209|1399843844|14004486442014/05/12 10:30:45.005 Finished request GetEntries in 0.02s2014/05/12 10:30:45.017 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46013|1399843845|14004486452014/05/12 10:30:45.047 Finished request GetEntries in 0.03s2014/05/12 10:30:45.063 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46031|1399843845|14004486452014/05/12 10:30:45.078 Finished request GetEntries in 0.02s2014/05/12 10:30:45.086 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46094|1399843845|14004486452014/05/12 10:30:45.111 Finished request GetEntries in 0.02s2014/05/12 10:30:45.132 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46225|1399843845|14004486452014/05/12 10:30:45.156 Finished request GetEntries in 0.02s2014/05/12 10:30:45.170 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|45959|1399843845|14004486452014/05/12 10:30:45.203 Finished request GetEntries in 0.03s2014/05/12 10:30:45.226 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46218|1399843845|14004486452014/05/12 10:30:45.268 Finished request GetEntries in 0.04s2014/05/12 10:30:45.295 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46137|1399843845|14004486452014/05/12 10:30:45.308 Finished request GetEntries in 0.01s2014/05/12 10:30:45.323 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|45977|1399843845|14004486452014/05/12 10:30:45.326 Finished request GetEntries in 0.00s2014/05/12 10:30:45.330 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46049|1399843845|14004486452014/05/12 10:30:45.345 Finished request GetEntries in 0.02s2014/05/12 10:30:45.353 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46004|1399843845|14004486452014/05/12 10:30:45.372 Finished request GetEntries in 0.02s2014/05/12 10:30:45.387 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46022|1399843845|14004486452014/05/12 10:30:45.414 Finished request GetEntries in 0.03s2014/05/12 10:30:45.436 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|45950|1399843845|14004486452014/05/12 10:30:45.462 Finished request GetEntries in 0.03s2014/05/12 10:30:45.479 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46270|1399843845|14004486452014/05/12 10:30:45.480 warning: no entries found for channel: INFO CHANNEL, startTime: 11/05/2014 9:30:45 p.m., endTime: 18/05/2014 9:30:45 p.m., currentTime: 11/05/2014 10:30:45 p.m.2014/05/12 10:30:45.480 Finished request GetEntries in 0.00s2014/05/12 10:30:45.481 Received client request: MediaBrowser^@MEDIACENTRE@|GetEntries|46173|1399843845|14004486452014/05/12 10:30:45.481 warning: no entries found for channel: MHEG IC Test Channel, startTime: 11/05/2014 9:30:45 p.m., endTime: 18/05/2014 9:30:45 p.m., currentTime: 11/05/2014 10:30:45 p.m.2014/05/12 10:30:45.481 Finished request GetEntries in 0.00s2014/05/12 10:30:45.493 Received client request: MediaBrowser^@MEDIACENTRE@|GetRecordings2014/05/12 10:30:45.707 GetRecordings> Completed for client MediaBrowser^, results:2014/05/12 10:30:45.707 GetRecordings> Transfered: RecTV folder files: 561, watched files: 02014/05/12 10:30:45.707 GetRecordings> Ignored: local files: 0, temp files: 02014/05/12 10:30:45.707 GetRecordings> Weird files: no program: 0, no channel: 0, orphaned: 02014/05/12 10:30:45.707 GetRecordings> Misc: content protected: 0, icons: 166, instantRec: 0, metaDataReads: 02014/05/12 10:30:45.707 Finished request GetRecordings in 0.21s2014/05/12 10:30:50.440 Received client request: MediaBrowser^@MEDIACENTRE@|GetServerVersion2014/05/12 10:30:50.440 Finished request GetServerVersion in 0.00s2014/05/12 10:30:50.441 Received client request: MediaBrowser^@MEDIACENTRE@|GetTunerStatus2014/05/12 10:30:50.465 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #2, Id: 12e17d53-601c-43de-b874-05918f04aa0d, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:50.465 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #2, Id: 12e17d53-601c-43de-b874-05918f04aa0d, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:50.465 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #1, Id: 6b61fbc3-ceff-4b75-952c-221c01aea4f9, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:50.465 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #1, Id: 6b61fbc3-ceff-4b75-952c-221c01aea4f9, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:50.465 Finished request GetTunerStatus in 0.02s2014/05/12 10:30:51.026 Received client request: MediaBrowser^@MEDIACENTRE@|GetServerVersion2014/05/12 10:30:51.026 Finished request GetServerVersion in 0.00s2014/05/12 10:30:51.027 Received client request: MediaBrowser^@MEDIACENTRE@|GetTunerStatus2014/05/12 10:30:51.032 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #2, Id: 12e17d53-601c-43de-b874-05918f04aa0d, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:51.032 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #2, Id: 12e17d53-601c-43de-b874-05918f04aa0d, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:51.032 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #1, Id: 6b61fbc3-ceff-4b75-952c-221c01aea4f9, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:51.032 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #1, Id: 6b61fbc3-ceff-4b75-952c-221c01aea4f9, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:30:51.032 Finished request GetTunerStatus in 0.01s2014/05/12 10:31:00.373 Received client request: MediaBrowser^@MEDIACENTRE@|GetServerVersion2014/05/12 10:31:00.373 Finished request GetServerVersion in 0.00s2014/05/12 10:31:00.374 Received client request: MediaBrowser^@MEDIACENTRE@|GetTunerStatus2014/05/12 10:31:00.379 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #2, Id: 12e17d53-601c-43de-b874-05918f04aa0d, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:31:00.379 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #2, Id: 12e17d53-601c-43de-b874-05918f04aa0d, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:31:00.379 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #1, Id: 6b61fbc3-ceff-4b75-952c-221c01aea4f9, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:31:00.379 GetTunerStatus> Name: Hauppauge WinTV 88x Tuner #1, Id: 6b61fbc3-ceff-4b75-952c-221c01aea4f9, SourceType: FM Radio, Status: Available, ProgramName: , RecordId: , ChannelId: , Clients:2014/05/12 10:31:00.379 Finished request GetTunerStatus in 0.01s2014/05/12 10:31:02.819 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:31:02.895 Finished request GetTimers in 0.08s2014/05/12 10:31:02.911 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:31:02.952 Finished request GetTimers in 0.04s2014/05/12 10:31:06.952 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:31:06.994 Finished request GetTimers in 0.04s2014/05/12 10:31:08.630 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:31:08.698 Finished request GetTimers in 0.07s2014/05/12 10:31:11.071 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:31:11.131 Finished request GetTimers in 0.06s2014/05/12 10:31:15.842 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:31:15.884 Finished request GetTimers in 0.04s2014/05/12 10:31:20.088 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:31:20.154 Finished request GetTimers in 0.07s2014/05/12 10:32:22.552 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:32:22.604 Finished request GetTimers in 0.05s2014/05/12 10:32:22.619 Received client request: MediaBrowser^@MEDIACENTRE@|GetTimers2014/05/12 10:32:22.663 Finished request GetTimers in 0.04s
reddragon1nz 0 Posted May 11, 2014 Author Posted May 11, 2014 Please Note I am using http://sourceforge.net/projects/epgcollector/ to import all posters and meta data for my guide. Not sure if this makes any difference as I think it imports all that into mce anyways.
reddragon1nz 0 Posted May 12, 2014 Author Posted May 12, 2014 I have found some settings for debugin in server wmc 2014/05/12 20:31:32.234 GetEntries> GuidImage detail for: Ellen2014/05/12 20:31:32.234 GetEntries> > ImageUrl: file://C:\epg\TV Series\363042bf-0bf2-48af-bb72-42ee57c51a57.jpg2014/05/12 20:31:32.234 GetEntries> > AbsoluteUrl: file://C:\epg\TV Series\363042bf-0bf2-48af-bb72-42ee57c51a57.jpg2014/05/12 20:31:32.234 GetEntries> > ResolvedUrl: file://C:\epg\TV Series\363042bf-0bf2-48af-bb72-42ee57c51a57.jpg2014/05/12 20:31:32.234 GetEntries> > ImageBytes: null I believe this is the issue. (files being local)
krustyreturns 191 Posted May 12, 2014 Posted May 12, 2014 You're right, this looks like a problem with wmc not handling these local image paths that epgcollector creates. I will try to produce bug fix in serverwmc that hopefully you can test.
reddragon1nz 0 Posted May 12, 2014 Author Posted May 12, 2014 Hi Krustyreturns. Thanks for getting back to me quickly. Any eta on when you can return a bug fix to me? Appreciate your Help.
krustyreturns 191 Posted May 13, 2014 Posted May 13, 2014 I'll try to have something this week for you to test.
reddragon1nz 0 Posted May 13, 2014 Author Posted May 13, 2014 Thanks Krustyreturns. I appreciate your help
reddragon1nz 0 Posted May 15, 2014 Author Posted May 15, 2014 Ih Krustyreturns. How are you getting on with the bug fix? Thanks
krustyreturns 191 Posted May 15, 2014 Posted May 15, 2014 I just pm'd you a test build. Let me know how it goes.
reddragon1nz 0 Posted May 19, 2014 Author Posted May 19, 2014 Hi. This has resolved the issue. Thanks heaps for your quick response.
Luke 42243 Posted January 5, 2018 Posted January 5, 2018 @@reddragon1nz We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge Thanks.
