metsuke 27 Posted November 29, 2021 Posted November 29, 2021 Is the concept the same for nvidia cards? Will a separate sys tree be required to copy into the jail?
metsuke 27 Posted November 30, 2021 Posted November 30, 2021 50 minutes ago, Duffyx said: Yes, its the same concept. Thanks, I'm not entirely sure then how to know what directories from /sys I need to copy into the jail. Do we know the method by which the Intel /sys directories were found?
Duffyx 25 Posted November 30, 2021 Author Posted November 30, 2021 Just copy the tarball as layed out. The files are not actually used by anything that matters, its just faking a GPU for ffdetect to pick up. It might work by changing some numbers around to get an "nvidia gpu" to show up. Although tbh I don't know what the state of nvidia is on FreeBSD, nvenc seems a far shot, maybe VAAPI.
bbartlomiej 8 Posted December 28, 2021 Posted December 28, 2021 I'm a bit stuck. I used to have it working for a while but now even though vainfo and ffdetect show everything they should, symling is there, /sys is extracted - I don't see anything in transcoding tab in the dashboard root@emby:/usr/local/lib/emby-server/bin # su -m emby -c "./ffdetect -hide_banner -show_program_version -loglevel 99 -show_error -show_log 99 vaencdec -print_format json" ffdetect version 4.3.0-emby_2021_02_27 Copyright (c) 2018-2021 softworkz for Emby LLC built with FreeBSD clang version 10.0.1 (git@github.com:llvm/llvm-project.git llvmorg-10.0.1-0-gef32c611aa2) configuration: --cc=clang --prefix=/usr/home/embybuilder/x64_freebsd12/ffmpeg-x64_freebsd12/staging --disable-alsa --disable-debug --disable-doc --disable-ffplay --disable-libpulse --disable-vdpau --disable-xlib --enable-chromaprint --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libaribb24 --enable-libass --enable-libdav1d --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libzvbi --enable-pic --enable-version3 --enable-libx265 --enable-vaapi --enable-opencl --arch=x86_64 --enable-shared --disable-static --pkg-config=pkg-config --pkg-config-flags=--static --extra-libs='-lm -lstdc++ -pthread' WARNING: library configuration mismatch avutil configuration: --prefix=/usr/local --mandir=/usr/local/man --datadir=/usr/local/share/ffmpeg --pkgconfigdir=/usr/local/libdata/pkgconfig --disable-static --disable-libcelt --enable-shared --enable-pic --enable-gpl --enable-avresample --cc=cc --cxx=c++ --disable-alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --enable-libaom --disable-libaribb24 --enable-asm --enable-libass --disable-libbs2b --disable-libcaca --disable-libcdio --disable-libcodec2 --enable-libdav1d --disable-libdavs2 --disable-libdc1394 --disable-debug --enable-htmlpages --enable-libdrm --disable-libfdk-aac --disable-libflite --enable-fontconfig --enable-libfreetype --enable-frei0r --disable-libfribidi --disable-gcrypt --disable-libglslang --disable-libgme --enable-gmp --enable-gnutls --enable-version3 --disable-libgsm --enable-iconv --disable-libilbc --disable-libjack --disable-libklvanc --disable-libkvazaar --disable-ladspa --enable-libmp3lame --disable-liblensfun --disable-libbluray --disable-librsvg --disable-librtmp --enable-libxml2 --disable-lto --disable-lv2 --disable-mbedtls --disable-libmfx --disable-libmodplug --disable-libmysofa --disable-nonfree --disable-openal --disable-opencl --disable-opengl --disable-libopenh264 --disable-libopenjpeg --disable-libopenmpt --disable-openssl --disable-libopenvino --enable-optimizations --enable-libopus --disable-pocketsphinx --disable-libpulse --disable-librabbitmq --disable-librav1e --disable-librist --enable-runtime-cpudetect --disable-librubberband --disable-sdl2 --disable-libsmbclient --disable-libsnappy --disable-sndio --disable-libsoxr --disable-libspeex --disable-libsrt --disable-libssh --disable-libtensorflow --disable-libtesseract --enable-libtheora --disable-libtwolame --disable-libuavs3d --enable-libv4l2 --enable-vaapi --disable-vapoursynth --enable-vdpau --disable-libvidstab --enable-libvmaf --enable-libvorbis --disable-libvo-amrwbenc --enable-libvpx --disable-vulkan --disable-libwebp --enable-libx264 --enable-libx265 --disable-libxavs2 --enable-libxcb --enable-libxvid --disable-outdev=xv --disable-libzimg --disable-libzmq --disable-libzvbi libavutil 56. 36.100 / 56. 70.100 { "ProgramVersion": { "Version": "4.3.0-emby_2021_02_27", "Copyright": "Copyright (c) 2018-2021 softworkz for Emby Llc", "Compiler": "FreeBSD clang version 10.0.1 (git@github.com:llvm/llvm-project.git llvmorg-10.0.1-0-gef32c611aa2)", "Configuration": "--cc=clang --prefix=/usr/home/embybuilder/x64_freebsd12/ffmpeg-x64_freebsd12/staging --disable-alsa --disable-debug --disable-doc --disable-ffplay --disable-libpulse --disable-vdpau --disable-xlib --enable-chromaprint --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libaribb24 --enable-libass --enable-libdav1d --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libzvbi --enable-pic --enable-version3 --enable-libx265 --enable-vaapi --enable-opencl --arch=x86_64 --enable-shared --disable-static --pkg-config=pkg-config --pkg-config-flags=--static --extra-libs='-lm -lstdc++ -pthread'" }, "Devices": [ Begin GetVaAdapterInfo Found 1 device entries Check device at index 0: /sys/bus/pci/devices/pci0000_00/class Adding adapter '/sys/bus/pci/devices/pci0000_00' - VendorId: 4660 DeviceId: 4369 - Subsystem: V: 6900, D: 4352 GetDeviceName - Start find_record: no record found adapter '/sys/bus/pci/devices/pci0000_00' - VendorName: (null) GetDeviceName - Start find_record: no record found adapter '/sys/bus/pci/devices/pci0000_00' - DeviceName: (null) GetDeviceName - Start find_record: found: Red Hat, Inc. adapter '/sys/bus/pci/devices/pci0000_00' - Subsystem VendorName: Red Hat, Inc. GetDeviceName - Start find_record: no record found find_record: no record found adapter '/sys/bus/pci/devices/pci0000_00' - Subsystem DeviceName: (null) Begin get_nodes Found 2 drm entries Found drm node '/dev/dri/card0' Found drm node '/dev/dri/render0' End GetVaAdapterInfo { "DeviceIndex": 0, "DeviceInfo": { "SubsytemVendorName": "Red Hat, Inc.", "VendorId": 4660, "DeviceId": 4369, "SubsytemVendorId": 6900, "SubsytemDeviceId": 4352, "DevPath": "/sys/bus/pci/devices/pci0000_00", "DrmCard": "/dev/dri/card0", "DrmRender": "/dev/dri/render0", "IsEnabled": 1, /dev/dri/render0: VA-API version: 1.13 (libva 1.12.0) "IsBootVga": 1, "ApiVersionMajor": 1, /dev/dri/render0: Driver version: Intel i965 driver for Intel(R) Haswell Desktop - 2.4.1 "ApiVersionMinor": 13, "Driver": "Intel i965 driver for Intel(R) Haswell Desktop - 2.4.1" }, "Decoders": [ { "CodecName": "MPEG2VIDEO", "CodecProfile": "MPEG2_SIMPLE", "CodecId": 2, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "MPEG2VIDEO", "CodecProfile": "MPEG2_MAIN", "CodecId": 2, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "H264", "CodecProfile": "H264_CONSTRAINED_BASELINE", "CodecId": 27, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 17, "DecSliceMode": 1 }, { "CodecName": "H264", "CodecProfile": "H264_MAIN", "CodecId": 27, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 17, "DecSliceMode": 1 }, { "CodecName": "H264", "CodecProfile": "H264_HIGH", "CodecId": 27, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 17, "DecSliceMode": 1 }, { "CodecName": "WMV3", "CodecProfile": "VC1_SIMPLE", "CodecId": 71, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "VC1", "CodecProfile": "VC1_SIMPLE", "CodecId": 70, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "WMV3", "CodecProfile": "VC1_MAIN", "CodecId": 71, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "VC1", "CodecProfile": "VC1_MAIN", "CodecId": 70, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "WMV3", "CodecProfile": "VC1_COMPLEX", "CodecId": 71, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "WMV3", "CodecProfile": "VC1_ADVANCED", "CodecId": 71, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "VC1", "CodecProfile": "VC1_COMPLEX", "CodecId": 70, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "VC1", "CodecProfile": "VC1_ADVANCED", "CodecId": 70, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 }, { "CodecName": "MJPEG", "CodecProfile": "MJPEG_HUFFMAN_BASELINE_DCT", "CodecId": 7, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "GRAY8 YUV411P YUV422P YUV440P YUV444P ", "RTFormat": 31, "DecSliceMode": 1 }, { "Number": 12, "Message": "Failed to query entrypoints for profile UNKNOWN: the requested VAProfile is not supported" }, { "CodecName": "VP9", "CodecProfile": "VP9_0", "CodecId": 167, "MaxWidth": 4096, "MaxHeight": 4096, "ColorFormats": "NV12 ", "RTFormat": 1, "DecSliceMode": 1 } ], "Encoders": [ { "CodecName": "MPEG2VIDEO", "CodecProfile": "MPEG2_SIMPLE", "CodecId": 2, "MaxWidth": 4096, "MaxHeight": 4096, "MinWidth": 32, "MinHeight": 32, "ColorFormats": "NV12 YUV420P YUV420P ", "RTFormat": 1, "RateControl": 16, "EncPackedHeaders": 11, "EncMaxRefFrames": 65537, "EncQualityRange": 1, "EncROI": 0 }, { "CodecName": "MPEG2VIDEO", "CodecProfile": "MPEG2_MAIN", "CodecId": 2, "MaxWidth": 4096, "MaxHeight": 4096, "MinWidth": 32, "MinHeight": 32, "ColorFormats": "NV12 YUV420P YUV420P ", "RTFormat": 1, "RateControl": 16, "EncPackedHeaders": 11, "EncMaxRefFrames": 65537, "EncQualityRange": 1, "EncROI": 0 }, { "CodecName": "H264", "CodecProfile": "H264_CONSTRAINED_BASELINE", "CodecId": 27, "MaxWidth": 4096, "MaxHeight": 4096, "MinWidth": 32, "MinHeight": 32, "ColorFormats": "NV12 YUV420P YUV420P ", "RTFormat": 1, "RateControl": 22, "EncPackedHeaders": 31, "EncMaxRefFrames": 65537, "EncMaxSlices": 32, "EncSliceStructure": 2, "EncQualityRange": 2, "EncROI": 2147484168, "EncRateControlExt": 2147483907 }, { "CodecName": "H264", "CodecProfile": "H264_MAIN", "CodecId": 27, "MaxWidth": 4096, "MaxHeight": 4096, "MinWidth": 32, "MinHeight": 32, "ColorFormats": "NV12 YUV420P YUV420P ", "RTFormat": 1, "RateControl": 22, "EncPackedHeaders": 31, "EncMaxRefFrames": 65537, "EncMaxSlices": 32, "EncSliceStructure": 2, "EncQualityRange": 2, "EncROI": 2147484168, "EncRateControlExt": 2147483907 }, { "CodecName": "H264", "CodecProfile": "H264_HIGH", "CodecId": 27, "MaxWidth": 4096, "MaxHeight": 4096, "MinWidth": 32, "MinHeight": 32, "ColorFormats": "NV12 YUV420P YUV420P ", "RTFormat": 1, "RateControl": 22, "EncPackedHeaders": 31, "EncMaxRefFrames": 65537, "EncMaxSlices": 32, "EncSliceStructure": 2, "EncQualityRange": 2, "EncROI": 2147484168, "EncRateControlExt": 2147483907 }, { "Number": 12, "Message": "Failed to query entrypoints for profile UNKNOWN: the requested VAProfile is not supported" } ], "Filters": [ { "FilterId": 1, "FilterName": "Noise reduction filter", "Properties": [ { "ParamIndex": 0, "MinValue": "0.000", "MaxValue": "1.000", "DefaultValue": "0.500", "Step": "0.031" } ], "IsSupported": 1 }, { "FilterId": 2, "FilterName": "Deinterlacing filter", "Properties": [ { "DeinterlacingType": 1 }, { "DeinterlacingType": 3 }, { "DeinterlacingType": 4 } ], "IsSupported": 1 }, { "FilterId": 3, "FilterName": "Sharpening filter", "Properties": [ { "ParamIndex": 0, "MinValue": "0.000", "MaxValue": "1.000", "DefaultValue": "0.500", "Step": "0.031" } ], "IsSupported": 1 }, { "FilterId": 4, "FilterName": "Color balance parameters", "Properties": [ { "ColorBalanceType": 1, "MinValue": "-180.000", "MaxValue": "180.000", "DefaultValue": "0.000", "Step": "1.000" }, { "ColorBalanceType": 2, "MinValue": "0.000", "MaxValue": "10.000", "DefaultValue": "1.000", "Step": "0.100" }, { "ColorBalanceType": 3, "MinValue": "-100.000", "MaxValue": "100.000", "DefaultValue": "0.000", "Step": "1.000" }, { "ColorBalanceType": 4, "MinValue": "0.000", "MaxValue": "10.000", "DefaultValue": "1.000", "Step": "0.100" } ], "IsSupported": 1 }, { "FilterId": 5, "FilterName": "Skin Tone Enhancement", "IsSupported": 0 } ] } ], "Log": [ { "Level": 48, "Category": 0, "Message": "Begin GetVaAdapterInfo" }, { "Level": 40, "Category": 0, "Message": "Found 1 device entries" }, { "Level": 56, "Category": 0, "Message": "Check device at index 0: /sys/bus/pci/devices/pci0000_00/class" }, { "Level": 56, "Category": 0, "Message": "Adding adapter '/sys/bus/pci/devices/pci0000_00' - VendorId: 4660 DeviceId: 4369 - Subsystem: V: 6900, D: 4352" }, { "Level": 56, "Category": 0, "Message": "GetDeviceName - Start" }, { "Level": 56, "Category": 0, "Message": "find_record: no record found" }, { "Level": 56, "Category": 0, "Message": " adapter '/sys/bus/pci/devices/pci0000_00' - VendorName: (null)" }, { "Level": 56, "Category": 0, "Message": "GetDeviceName - Start" }, { "Level": 56, "Category": 0, "Message": "find_record: no record found" }, { "Level": 56, "Category": 0, "Message": " adapter '/sys/bus/pci/devices/pci0000_00' - DeviceName: (null)" }, { "Level": 56, "Category": 0, "Message": "GetDeviceName - Start" }, { "Level": 56, "Category": 0, "Message": "find_record: found: Red Hat, Inc." }, { "Level": 56, "Category": 0, "Message": " adapter '/sys/bus/pci/devices/pci0000_00' - Subsystem VendorName: Red Hat, Inc." }, { "Level": 56, "Category": 0, "Message": "GetDeviceName - Start" }, { "Level": 56, "Category": 0, "Message": "find_record: no record found" }, { "Level": 56, "Category": 0, "Message": "find_record: no record found" }, { "Level": 56, "Category": 0, "Message": " adapter '/sys/bus/pci/devices/pci0000_00' - Subsystem DeviceName: (null)" }, { "Level": 48, "Category": 0, "Message": "Begin get_nodes" }, { "Level": 48, "Category": 0, "Message": "Found 2 drm entries" }, { "Level": 56, "Category": 0, "Message": "Found drm node '/dev/dri/card0'" }, { "Level": 56, "Category": 0, "Message": "Found drm node '/dev/dri/render0'" }, { "Level": 48, "Category": 0, "Message": "End GetVaAdapterInfo" }, { "Level": 40, "Category": 0, "Message": "/dev/dri/render0: VA-API version: 1.13 (libva 1.12.0)" }, { "Level": 40, "Category": 0, "Message": "/dev/dri/render0: Driver version: Intel i965 driver for Intel(R) Haswell Desktop - 2.4.1" } ] } root@emby:/usr/local/lib/emby-server/bin # su -m emby -c "./ffdetect -hide_banner -show_program_version -loglevel 99 -show_error -show_log 99 vaencdec -print_format json" root@emby:/usr/local/lib/emby-server/bin # kldstat Id Refs Address Size Name 1 90 0xffffffff80200000 25b08c8 kernel 2 1 0xffffffff827b1000 2253c0 if_qlxgbe.ko 3 1 0xffffffff829d7000 65ab48 openzfs.ko 4 1 0xffffffff83033000 332c8 if_bnxt.ko 5 1 0xffffffff83067000 19e88 if_atlantic.ko 6 1 0xffffffff83081000 11c70 ipmi.ko 7 2 0xffffffff83093000 2ef0 smbus.ko 8 1 0xffffffff83096000 100fb0 ispfw.ko 9 1 0xffffffff83611000 537420 vmm.ko 10 1 0xffffffff83b49000 afc nmdm.ko 11 1 0xffffffff83b4a000 2ea dtraceall.ko 12 9 0xffffffff83b4b000 75a8 opensolaris.ko 13 9 0xffffffff83b53000 3be70 dtrace.ko 14 1 0xffffffff83b8f000 5f8 dtmalloc.ko 15 1 0xffffffff83b90000 18c0 dtnfscl.ko 16 1 0xffffffff83b92000 1fa1 fbt.ko 17 1 0xffffffff83b94000 547c0 fasttrap.ko 18 1 0xffffffff83be9000 b98 sdt.ko 19 1 0xffffffff83bea000 70f4 systrace.ko 20 1 0xffffffff83bf2000 707c systrace_freebsd32.ko 21 1 0xffffffff83bfa000 f8c profile.ko 22 1 0xffffffff83bfb000 4718 geom_multipath.ko 23 1 0xffffffff83c00000 12bf6c i915kms.ko 24 1 0xffffffff83d2c000 75e10 drm.ko 25 3 0xffffffff83da2000 13f30 linuxkpi_gplv2.ko 26 2 0xffffffff83db6000 6d0 debugfs.ko 27 1 0xffffffff83db7000 acf mac_ntpd.ko root@emby:/usr/local/lib/emby-server/bin # vainfo error: XDG_RUNTIME_DIR not set in the environment. error: can't connect to X server! libva info: VA-API version 1.13.0 libva info: Trying to open /usr/local/lib/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_1_13 libva error: /usr/local/lib/dri/iHD_drv_video.so init failed libva info: va_openDriver() returns 1 libva info: Trying to open /usr/local/lib/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_12 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.13 (libva 2.13.0) vainfo: Driver version: Intel i965 driver for Intel(R) Haswell Desktop - 2.4.1 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD root@emby:/usr/local/lib/emby-server/bin # ls -l /dev/dri total 0 lrwxr-xr-x 1 root wheel 8 Dec 21 18:04 card0 -> ../drm/0 lrwxr-xr-x 1 root wheel 5 Dec 21 18:04 render0 -> card0 lrwxr-xr-x 1 root wheel 10 Dec 21 18:04 renderD128 -> ../drm/128 Any suggestions?
softworkz 5133 Posted December 29, 2021 Posted December 29, 2021 Could you post the hw detection log created by Emby server?
bbartlomiej 8 Posted December 30, 2021 Posted December 30, 2021 (edited) Yes, see attached. It seams to begin with the same information as the output of my ffdetect command in previous post. It's a clean log taken just now after cleaning logs and restarting emby-server. This is stable package in a jail under TrueNAS. All the workarounds from this thread applied: devfs passthrough, symling from render0 to card0, modules loaded and visible inside jail (as is /dev/dri/* stuff). hardware_detection-63776452224.txt Edited December 30, 2021 by bbartlomiej
softworkz 5133 Posted December 30, 2021 Posted December 30, 2021 Thanks. The detection looks OK. We need to find out why the detected hwaccels aren't used. Could you please also post the server log? Please follow these instructions: Stop the server locate the program data folder there's a sub-folder cache in the cache folder, delete the ffmpeg folder Start the server Wait 30s Post the server log Thanks
bbartlomiej 8 Posted December 30, 2021 Posted December 30, 2021 See attached. Attaching hardware_detection log again after cleanup and restart. embyserver.txt hardware_detection-63776501645.txt
softworkz 5133 Posted December 31, 2021 Posted December 31, 2021 @bbartlomiej - thanks for the logs. I was able to identify the cause of the error. It will be fixed in the next beta! Thanks again, sw
bbartlomiej 8 Posted December 31, 2021 Posted December 31, 2021 @softworkz wow thatnks! Just FYI, with current beta 4.7.0.18 the transcoding doesn't work at all for me - even software. Simply the video doesn't start at all. I tried that last week with LG TV emby client (without premiere back then). That was the main reason I rolled back to stable.
softworkz 5133 Posted December 31, 2021 Posted December 31, 2021 AFAIK, there's a known problem on FreeBSD which is also why there's no .19 yet. @Luke right?
softworkz 5133 Posted December 31, 2021 Posted December 31, 2021 Beta .19 is available for FreeBSD 13 now: https://emby.media/freebsd-server.html (this beta doesn't include the mentioned fix, though)
bbartlomiej 8 Posted January 4, 2022 Posted January 4, 2022 On 31/12/2021 at 22:26, softworkz said: Beta .19 is available for FreeBSD 13 now: https://emby.media/freebsd-server.html (this beta doesn't include the mentioned fix, though) Cool, is the fix planned for .20 then?
softworkz 5133 Posted January 4, 2022 Posted January 4, 2022 7 hours ago, bbartlomiej said: Cool, is the fix planned for .20 then? Yup, it's already committed for .20!
jamclucas 0 Posted January 7, 2022 Posted January 7, 2022 already waiting for the fix, im ussing truenas 12 but no hardware transcoding, my hardware is detected but not shown.
dcol 177 Posted January 7, 2022 Posted January 7, 2022 I gave up on porting Emby to TrueNAS Core v12 due to all the limitations a while ago. I will revisit when all these 'issues' are resolved and Hardware Acceleration is working OOB. It would be a great advantage since it would require one less computer.
Luke 42237 Posted January 14, 2022 Posted January 14, 2022 For those who run the beta builds, how does 4.7.0.20 compare?
bbartlomiej 8 Posted January 14, 2022 Posted January 14, 2022 1 hour ago, Luke said: For those who run the beta builds, how does 4.7.0.20 compare? As you promised indeed it's fixed. I can see the devices and I managed to do hw transcoding on one f my movies. I will do more testing as it seems it fails after few tries. Stay tuned. 1
Luke 42237 Posted January 14, 2022 Posted January 14, 2022 Just now, bbartlomiej said: As you promised indeed it's fixed. I can see the devices and I managed to do hw transcoding on one f my movies. I will do more testing as it seems it fails after few tries. Stay tuned. Thanks for the feedback !
softworkz 5133 Posted January 15, 2022 Posted January 15, 2022 @ all - please let us know whether it's working for you now! Thanks.
emnooo 0 Posted March 26, 2022 Posted March 26, 2022 tried to install emby 4.7.0.32 from port. it seems still not able to transcode media by default. the sys.xz is still need? I've not tried yet.
Luke 42237 Posted March 27, 2022 Posted March 27, 2022 On 3/26/2022 at 9:26 AM, emnooo said: The sys.xz is still need? I've not tried yet. Hi, what exactly do you mean?
bbartlomiej 8 Posted April 2, 2022 Posted April 2, 2022 As far as I know, you still need to unpac the sys.xz archive you can find in this thread to fool ffdetect to find your GPU. On another note: Is anybody successfully using Nvidia GPUs with Emby and FreeBSD to hardware transcode? And on top of that - would the steps be similar to run it in a jail? Just bought a Quadro P400 to help with transcoding. 1
Luke 42237 Posted April 3, 2022 Posted April 3, 2022 On 4/2/2022 at 4:11 PM, bbartlomiej said: As far as I know, you still need to unpac the sys.xz archive you can find in this thread to fool ffdetect to find your GPU. OK that is most likely still the same.
