Razzi 0 Posted February 22, 2019 Posted February 22, 2019 Hello, I have alot of trouble with the installation, googled alot but since development seem to be very fast most information is outdated. Emby is not in my QNAP App Store so I used the package on the Website https://emby.media/nas-server.html for the QNAP , only the x41 variant seemed to work, although I never found an Info which x I need. What I have tried: - After installation I click on the app to open and it tries to connect to https://<server>:8920/ Chrome says ERR_CONNECTION_REFUSED Since on the QNAP Installation page they write a different port I also tried 8096. Same Problem - A curl directly on the NAS curl -v http://localhost:8096 (or other port) outputs connection refused. - The Emby Log under the installation folder has 0 bytes - so it is empty as never touched... - ps -ef | grep emby shows no result - ./emby-server.sh start => outputs ./emby-server.sh: line 20: kill: (12025) - No such process, after removing the PID File it shows no message but is still not really started, PID File is recreated Versions Used : 4.0.2.0 and Beta 4.1.0.8. I dont want to switch to Plex since Emby seems to be just nicer for me But Plex has an App directly in the App store :/ Can I provide any more Infos ? What else can I try? Thanks in advance Razzi
Luke 42241 Posted February 22, 2019 Posted February 22, 2019 We are currently going through the process of submitting to QNAP, so stay tuned.
Luke 42241 Posted April 17, 2019 Posted April 17, 2019 We're working on it. It's just slow moving getting responses from QNAP. Thanks.
shakra2005 0 Posted May 9, 2019 Posted May 9, 2019 i have open a call too and this is the answer:Da es sich bei Ihrem Emby Server um eine 3 Party Software handelt, können wir Ihnen leider nicht weiterhelfen da wir nicht die Konfiguration von dieser Software kennen und uns ebenfalls nicht um diese kümmern.Since your Emby server is a 3 party software, unfortunately we can not help you because we do not know the configuration of this software and we do not take care of it either.
shakra2005 0 Posted July 12, 2019 Posted July 12, 2019 (edited) hii have a 831x QTS 4.4.1.0978 After starting i see no process in the console and no listening port Edited July 12, 2019 by shakra2005
Luke 42241 Posted July 13, 2019 Posted July 13, 2019 hi i have a 831x QTS 4.4.1.0978 After starting i see no process in the console and no listening port Hi, what version of emby ever have you installed? How did you install it? Thanks.
shakra2005 0 Posted July 14, 2019 Posted July 14, 2019 I have 4.1.1 I have Download ist from emby I have installed through appcenter with Click on the plus tab and added the file After Starting bi Process is Running
Luke 42241 Posted July 22, 2019 Posted July 22, 2019 I have 4.1.1 I have Download ist from emby I have installed through appcenter with Click on the plus tab and added the file After Starting bi Process is Running @@shakra2005 are you still having an issue?
Luke 42241 Posted July 24, 2019 Posted July 24, 2019 We're finally starting to get some responses from QNAP, so hopefully in the near future we'll be in their AppCenter and you can just install from there. Will that resolve your issue?
reallyill 0 Posted September 21, 2020 Posted September 21, 2020 (edited) Since this is over a year old was any resolution ever found? Edited September 22, 2020 by reallyill
Luke 42241 Posted September 29, 2020 Posted September 29, 2020 On 9/21/2020 at 4:31 PM, reallyill said: Since this is over a year old was any resolution ever found? @reallyill have you tried Emby Server 4.5.1?
