usesembyalot 0 Posted February 18, 2019 Posted February 18, 2019 Hi I installed the LG app on my LG TV and customized the home screen from horizontal to vertical (or the other way around, I do not recall the name itself). I just know that I changed it from default. Now in the new layout I do not see customize Home screen button anymore. How do I customize the home screen now? I just want it all back to default layout. Uninstall and reinstall did not help/ thanks
usesembyalot 0 Posted February 18, 2019 Author Posted February 18, 2019 I found this post that helped me get back to default. It is pretty lame to have the button to customize an d after you customize, you loose the button. https://emby.media/community/index.php?/topic/64859-layout-of-home-screen-customize-home-screen-button/?p=644177
Luke 42234 Posted February 18, 2019 Posted February 18, 2019 Hi, this is resolved for the next update to the LG app. Thanks !
