Sync Problems
Hi,
Emby Server = 4.0.1.0
Running Kodi 4.0.4 (2x Pi's and 1xnVidia Shield).
I had to reset local databses with the upgrade, which is all fine so can now play content.  I was getting the intro dialogue about installing Kodi Companion as I guess the method of syncing has changed - all good, installed that onto the server.
However my devices aren't syncing, even when I reboot the device i dont get the initial sync; I can go into Emby > Manage Libraries > Update Library - but this does an entire sync of everything?
Am i missing something obvious?
oh - i have gone into Movies - and clicked update but nothing seems to happen...
Angelblue05
What if you select Add libraries instead of Update libraries when you access Manage libraries?
Guest
