Detail4687 4 Posted May 10, 2019 Posted May 10, 2019 Yes that would be fine. Also for those who may have missed it, you can also use the web app over localhost, or our android mobile app, or iOS app. Same problem here, and "web app over localhost" doesn't work either. Android does. In the locahost the chromecasts (I have 3 on my local network) don't show up.
Luke 42241 Posted May 10, 2019 Posted May 10, 2019 Same problem here, and "web app over localhost" doesn't work either. Android does. In the locahost the chromecasts (I have 3 on my local network) don't show up. Hi there, web app over localhost works just fine. "Same problem here doesn't apply", because no one here has reported that.
Detail4687 4 Posted May 11, 2019 Posted May 11, 2019 Hi there, web app over localhost works just fine. "Same problem here doesn't apply", because no one here has reported that. ?!?!?!? This whole thread is about the problem. I, too, am enjoying this issue. Anyway, localhost viw web app is not working just fine for mre.
Luke 42241 Posted May 12, 2019 Posted May 12, 2019 Hi, it's right in your screenshot. Don't you see Chromecast in the middle of the list?
Detail4687 4 Posted May 12, 2019 Posted May 12, 2019 Hi, it's right in your screenshot. Don't you see Chromecast in the middle of the list? No, that's not it. Compare the three chromecasts to the right with my list. None are there.
Detail4687 4 Posted May 22, 2019 Posted May 22, 2019 In re-installed Plex just for a test, and my Chromecast devices show up (Plex in Chrome on the same LAN).
Luke 42241 Posted May 22, 2019 Posted May 22, 2019 When you click Chromecast in the middle, then it launches the native google cast picker and you see the same list as you would see if clicked the cast button in the browser. That's how you do it in the web app. 1
Detail4687 4 Posted May 23, 2019 Posted May 23, 2019 When you click Chromecast in the middle, then it launches the native google cast picker and you see the same list as you would see if clicked the cast button in the browser. That's how you do it in the web app. that did it. My apologies. Such as simple solution. Thank you Luke!
Jemison 0 Posted January 3, 2020 Posted January 3, 2020 Hi all, I just discovered this post - but recently my chromecast cast stopped functioning - the play button does nothing, although the Remote Control dialog is available - just nothing is received by the cc device. I had already configured my emby server with a self-signed CA issued certificate. The CA certificate is trusted on my chrome clients (Windows, android) - and up until about Sept/Oct - I had no problems casting from any device with chrome via https (8920). Emby Server configuration has remote server name defined that matches the certificate subject name, and I added my local subnet as both local and remote whitelisted. In addition I used an online tool (can't locate it atm) to confirm the certificate would pass Google's validity tests - so that I don't get the annoying certificate is untrusted indicator in chrome. For about a year I've been casting no problems, but it stopped. I'm on emby version 4.3.1 on debian buster - and unfortunately I haven't been able to pinpoint exactly what happened prior to my losing the ability to play. Oddly enough, I can cast from a non-local web-browser pointing to the http (8096) instance on the server. Any suggestions where to look to solve this?
Luke 42241 Posted January 3, 2020 Posted January 3, 2020 Hi all, I just discovered this post - but recently my chromecast cast stopped functioning - the play button does nothing, although the Remote Control dialog is available - just nothing is received by the cc device. I had already configured my emby server with a self-signed CA issued certificate. The CA certificate is trusted on my chrome clients (Windows, android) - and up until about Sept/Oct - I had no problems casting from any device with chrome via https (8920). Emby Server configuration has remote server name defined that matches the certificate subject name, and I added my local subnet as both local and remote whitelisted. In addition I used an online tool (can't locate it atm) to confirm the certificate would pass Google's validity tests - so that I don't get the annoying certificate is untrusted indicator in chrome. For about a year I've been casting no problems, but it stopped. I'm on emby version 4.3.1 on debian buster - and unfortunately I haven't been able to pinpoint exactly what happened prior to my losing the ability to play. Oddly enough, I can cast from a non-local web-browser pointing to the http (8096) instance on the server. Any suggestions where to look to solve this? What kind of certificate? Your Chromecast receiver is probably rejecting the SSL cert. Either that or it's not able to resolve the domain name attached to it.
craigmac99 1 Posted January 5, 2020 Posted January 5, 2020 What kind of certificate? Your Chromecast receiver is probably rejecting the SSL cert. Either that or it's not able to resolve the domain name attached to it. I am also having this issue and it started after i upgraded to 4.3.1, no issue before hand. im using a self signed cert and the domain name is resolvable on my local network so should be by the Chromecast as well. The only change was the upgrade to 4.3.1 so i feel it has to be related. how can i check if the CC is rejecting the cert? is there a debug log i can enable and retrieve from the Chromecast?
Luke 42241 Posted January 5, 2020 Posted January 5, 2020 I am also having this issue and it started after i upgraded to 4.3.1, no issue before hand. im using a self signed cert and the domain name is resolvable on my local network so should be by the Chromecast as well. The only change was the upgrade to 4.3.1 so i feel it has to be related. how can i check if the CC is rejecting the cert? is there a debug log i can enable and retrieve from the Chromecast? There isn't really a way to get that specific error message other than testing the same address with plain http. So that's what you might want to start with. Re-configure your emby server for plain http, then use the android or iOS app to see if you can cast to your Chromecast.
craigmac99 1 Posted January 5, 2020 Posted January 5, 2020 There isn't really a way to get that specific error message other than testing the same address with plain http. So that's what you might want to start with. Re-configure your emby server for plain http, then use the android or iOS app to see if you can cast to your Chromecast. There is no issue with the Android app, this is what im using as work around for now, its only the web player. Video also plays just fine in the web player directly only the issue of nothing happening when you click play button when casting to the Chromecast app. Issue only started occurring after upgrade to 4.3.x, app loads up fine on the Chromecast from web player (full screen with logo) but nothing happens when you click any of the various play button. i can see in chrome network inspect console that the request is sent out as a GET when i click the play button with a 200OK response code, but nothing happens on the Chromecast: https://emby.hidden.local:8920/Users/5ee6b1e68284414599a7d13ce2fc4741/Items/21299 There appears to be well formed request and response headers as well so not sure what the issue might be here. Was working flawlessly untill i installed 4.3 im going to see if i can downgrade or setup a test with pre 4.3 code but don't have much time these days to build it unfortunately.
Luke 42241 Posted January 5, 2020 Posted January 5, 2020 Please try what i suggested using the android app to cast to chromecast. That's now you can narrow down a problem of general connectivity vs. a problem with the SSL certificate.
Jemison 0 Posted January 5, 2020 Posted January 5, 2020 Hi Luke, I can cast from http as well as from the android app. Just not from https. I used the site crt.sh/lintcert to verify that my self-signed certificate didn't contain validation errors, which is what I did originally months ago when I first switched to emby. I'm willing to install an older release of emby if you can provide guidance.
Jemison 0 Posted January 5, 2020 Posted January 5, 2020 Ok, so I created a new VM and installed release 4.2.0.40, created a new self-signed certificate that matched the new server - configured the networking settings - and voila - I can cast from chrome browser via https:8920!
Jemison 0 Posted January 6, 2020 Posted January 6, 2020 Works with release 4.2.1.0 too. I don't know how to install the minor 4.3 releases - but I can if it will help identify where it begins to fail - just need some howto guidance
Jemison 0 Posted January 9, 2020 Posted January 9, 2020 Hi again, From this thread, seems that the source isn't being made available for emby version 4.x . Is there anything else we can provide to demonstrate the error to help lead to a fix? Thanks
willvincent 3 Posted January 9, 2020 Posted January 9, 2020 Since I keep getting notifications, and I just updated my server version -- I'll add that I too am no loner able to cast to chromecast with my previously working self-signed cert after upgrade. I can still select chromecast, and choose the desired destination, but when I click play _nothing_ happens.. casting from android/ios still works as expected, going to revert to prior server version and see if it works again
willvincent 3 Posted January 9, 2020 Posted January 9, 2020 Confirmed. Reverting to 4.2.1 my self-signed cert works again as expected.4.3.x and 4.4.x are not behaving as expected. Though interestingly, 4.3 _was_ working yesterday before a system reboot today, after which it would not work, so I tried installing 4.4 and it too didn't work properly, revert to 4.2 works again.
bluelab1 0 Posted January 11, 2020 Posted January 11, 2020 I also updated my server version and am not able to cast to chromecast. It was ok with my self-signed cert before upgrade. Same case: I select chromecast as the destination, and it says "ready to cast as usual" but if I click play apparently nothing happens.. Same as before reported: casting from android works as expected. my 2 cents
Luke 42241 Posted January 12, 2020 Posted January 12, 2020 I also updated my server version and am not able to cast to chromecast. It was ok with my self-signed cert before upgrade. Same case: I select chromecast as the destination, and it says "ready to cast as usual" but if I click play apparently nothing happens.. Same as before reported: casting from android works as expected. my 2 cents What address is in your browser address bar at the time of testing?
Jemison 0 Posted January 12, 2020 Posted January 12, 2020 What address is in your browser address bar at the time of testing? My address is link and the hostname embysvr is resolvable on my network by my nameserver. The self-signed certificate has embysvr has the commonName as well as the subject alternate name so that it passes crt.sh/lintcert validation.
