Newbie2010 0 Posted January 30, 2019 Posted January 30, 2019 Big Newbie to emby and roku. I have a question. I have looked but couldnt find an answer on the forums. The few I did find the technial stuff I couldnt understand. I have windows 10, the cheapest cox cable plan 10bps, night hawk router. I am sitting my movies on a WD external HD. I have emby on my desk top with about 5 movies on it. Works great on my laptop, android phone,and my smart tv in the living room with roku built in. Where i am having payback/quality issues is in my bedroom. It's an older tv but has hdmi ports,i have a dvd/bluray player that works great on it. I bought the cheapest roku stick and hooked it up to the tv,netflix plays fine with good quality. I installed the emby app and it loads but the movies are bad quality and image breaks up, if i lower the quality in settings it will play back without skipping but quality is unwatchable. I was going to go buy a new smart tv with roku built in and see if that helps but thought there might be a cheaper fix. THANKS LOVE EMBY WILL BE PURCHASING THE LIFE TIME SUBSCRIPTION IF I CAN GET THIS RESOLVED.
Luke 42216 Posted January 31, 2019 Posted January 31, 2019 Hi there, we'll respond to you here: https://emby.media/community/index.php?/topic/69274-play-back-quality-on-roku/ Thanks !
