harshakavuri 0 Posted January 19, 2019 Posted January 19, 2019 Hi, I am having issues with real time monitoring on latest stable Emby server(4.0.0.2) on Xpenology loader 1.04b DS918+. I uploaded a movie and waited for more than half hour for it to pickup. If I run a manual scan of the library the movie gets picked up. The movie file was uploaded at around 3.39 - 3.42 pm and the log time was 4.19 pm. Any help on this please. Embyserverlog.txt
Luke 42242 Posted January 19, 2019 Posted January 19, 2019 Hi there, are your media files on the Synology? Did you check your settings for each library to ensure the realtime monitor is enabled?
harshakavuri 0 Posted January 19, 2019 Author Posted January 19, 2019 Yes the media files are on the same NAS and real-time monitoring is enabled on all the libraries. Sent from my iPhone using Tapatalk
Luke 42242 Posted January 19, 2019 Posted January 19, 2019 Can you enable debug logging under Logs in the server dashboard, restart the server, repeat the test, and then attach a new log file? Thanks !
harshakavuri 0 Posted January 19, 2019 Author Posted January 19, 2019 Enabled debug logging and uploaded couple of new movies 5 mins apart from each other Serverlog_debug.txt
Luke 42242 Posted January 20, 2019 Posted January 20, 2019 Unfortunately no events ever fired here. @@solabc16 is everything with mono configured properly to allow INotify to trigger events?
solabc16 379 Posted January 20, 2019 Posted January 20, 2019 Hello @@harshakavuri In general, we don't have any problems with the real time monitor with the current releases. However, we do sometime run into the default kernel limits, especially with large libraries. Can you give me some idea on the size of your library, in terms of the number of titles? Also, it would be helpful if you could run the Send Logs utility and post the reference number here : https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Best - James
harshakavuri 0 Posted January 20, 2019 Author Posted January 20, 2019 Hello @@solabc16 I have around 800 movies in my collection organised into 8 different libraries. I have uploaded a couple of movies and then triggered the Send Logs utility from SSH with name "sendlogs_HARSHAXpen_synology_apollolake_918+_20190120T143844UTC.tgz" Harsha
solabc16 379 Posted March 26, 2019 Posted March 26, 2019 (edited) Hello @@harshakavuri This issue is still being looked at, just linking in the following related threads at this time... https://emby.media/community/index.php?/topic/69684-emby-version-4-real-time-monitoring-is-not-working-synology-2413/ https://emby.media/community/index.php?/topic/71809-new-episodes-and-shows-not-automatically-found/ https://emby.media/community/index.php?/topic/63753-real-time-monitoring-on-synology/ ...will follow up further, once the next stable is released. Best - James Edited March 26, 2019 by solabc16
Luke 42242 Posted June 25, 2019 Posted June 25, 2019 Please see here for the solution: https://emby.media/community/index.php?/topic/69684-emby-version-4-real-time-monitoring-is-not-working-synology-241315-and-all-other/?p=754464 Thanks.
