heula 192 Posted January 17, 2019 Posted January 17, 2019 (edited) I'm using TVMosaic for recording at this moment but maybe I will switch back to recording with Emby. So I have setup 2 serie recordings yesterday for testing and the first recording failed immediately. The second recording went well. The recording of Goede tijden, Slechte tijden failed and was just 127 mb and 3 minutes. What is the reason this recording failed? Thanks. Emby Server 16-1-2019.txt Edited January 17, 2019 by heula
Luke 42244 Posted January 17, 2019 Posted January 17, 2019 For some reason it wasn't able to get write access: 2019-01-16 12:06:46.493 Error App: Error recording to /volume4/Tv-opnamen/TVMosaic/Utopia/Utopia 2019_01_16_12_00_00.ts *** Error Report *** Version: 4.0.0.2 Command line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.14.0.177 (tarball Wed Nov 7 21:44:53 UTC 2018) Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.0.0.2 System.IO.IOException: System.IO.IOException: Sharing violation on path /volume4/Tv-opnamen/TVMosaic/Utopia/Utopia 2019_01_16_12_00_00.ts @@solabc16 this is something that i think the netcore may will help with.
heula 192 Posted January 17, 2019 Author Posted January 17, 2019 (edited) I said the second recording went well. It went well with recording from begin to end but when I watched the recording it was not well at all. The same issue as I mentioned some time ago. I already forgot but I had tried it before when I got my Nas system. See this topic The recordings made with TVMosaic are recorded to the same folder (on my NAS)and do not have these issues. I hope this can also be improved. Thanks. Edited January 17, 2019 by heula
solabc16 379 Posted January 17, 2019 Posted January 17, 2019 Hello @@heula Is this on your DS418? Best - James
solabc16 379 Posted January 17, 2019 Posted January 17, 2019 ...and a second question (@heula), do you have anything else monitoring or using those file paths? Best - James
heula 192 Posted January 17, 2019 Author Posted January 17, 2019 ...and a second question (@heula), do you have anything else monitoring or using those file paths? Best - James No just TVMosaic and Emby using that folder for recordings. Converted and copied recordings (to another folder) are being processed by my own created batch fiile for organizing. I have now a batch file processing these copied recordings so the date is set different so it will be recognizable for organizing. That is done by Sickchill.
heula 192 Posted January 17, 2019 Author Posted January 17, 2019 Hello @@heula Is this on your DS418? Best - James Yes, recordings take place on my DS418.
solabc16 379 Posted January 17, 2019 Posted January 17, 2019 Hello Can anybody account for / explain these two entries in the log... 2019-01-16 12:06:46.386 Info App: Beginning recording. Will record for 63.22688985 minutes. 2019-01-16 12:06:46.386 Info App: Writing file to path: /volume4/Tv-opnamen/TVMosaic/Utopia/Utopia 2019_01_16_12_00_00.ts <------------------------ 2019-01-16 12:06:46.409 Info MediaSourceManager: Live tv media info probe took 15.549213 seconds 2019-01-16 12:06:46.410 Info MediaSourceManager: Live stream opened: ...and... 2019-01-16 12:06:46.411 Info App: Beginning recording. Will record for 63.2264781833333 minutes. 2019-01-16 12:06:46.411 Info App: Writing file to path: /volume4/Tv-opnamen/TVMosaic/Utopia/Utopia 2019_01_16_12_00_00.ts <------------------------ 2019-01-16 12:06:46.493 Error App: Error recording to /volume4/Tv-opnamen/TVMosaic/Utopia/Utopia 2019_01_16_12_00_00.ts *** Error Report *** Version: 4.0.0.2 The system appears to be trying to write to the same file twice, so the error seems reasonable and expected. Best - James
heula 192 Posted January 17, 2019 Author Posted January 17, 2019 Tonights (test) recording does miss pieces. Like the recording stops for a few seconds and than continues. For now I keep using TVMosaic because it is more stable than recording with Emby at this point. Emby has a better app functionality but it's all about the recordings in the end. Where did the dvblink plugin go? Thanks and hoping for recording improvements so one day I can use Emby for everything including good recordings. Server log 17-01-2019.txt
solabc16 379 Posted January 17, 2019 Posted January 17, 2019 (edited) Hello @@heula If possible, can you run the Send Logs utility - details here : https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs I'll need a bit more info to answer your question in post #9. Best - James Edited January 17, 2019 by solabc16
heula 192 Posted January 17, 2019 Author Posted January 17, 2019 * Upload completed successfully, please include this filename with your ticket... sendlogs_Heula-NAS_synology_rtd1296_ds418_20190117T214528UTC.tgz
solabc16 379 Posted January 17, 2019 Posted January 17, 2019 Thanks for the logs @@heula. At some point did the TV series somehow get configured to record twice - see post #8 above. I also came across this in the logs:- 2019-01-17 10:28:25.228 Info App: Loading live tv data from /var/packages/EmbyServer/target/var/data/livetv/seriestimers 2019-01-17 10:28:27.774 Info App: Creating recording timer for 067aefde07cf235d48d28c42d9c1690f, Goede Tijden, Slechte Tijden. Timer will fire in 576.537087083333 minutes 2019-01-17 10:28:28.252 Info App: Creating recording timer for 121426736979b608c7a441d1be240c9f, Goede Tijden, Slechte Tijden. Timer will fire in 2008.52913435 minutes 2019-01-17 10:28:28.475 Info App: Creating recording timer for af22f1cd6a8b58bcd11cbbc001b29ee9, Goede Tijden, Slechte Tijden. Timer will fire in 6328.52540588333 minutes 2019-01-17 10:28:28.799 Info App: Creating recording timer for acdbc456edc95c97b84442838c447844, Goede Tijden, Slechte Tijden. Timer will fire in 7768.52001051667 minutes 2019-01-17 10:28:29.303 Info App: Creating recording timer for 054e5ccd58c6529f13d1492fe3ccafa4, Goede Tijden, Slechte Tijden. Timer will fire in 9208.51161451667 minutes 2019-01-17 10:28:30.367 Info App: Creating recording timer for dea5cb07a5cd94eba047cccff051db2c, Steenrijk, Straatarm. Timer will fire in 9238.49388358333 minutes 2019-01-17 10:28:30.764 Info App: Creating recording timer for 121426736979b608c7a441d1be240c9f, Goede Tijden, Slechte Tijden. Timer will fire in 2008.48726773333 minutes 2019-01-17 10:28:30.871 Info App: Creating recording timer for 067aefde07cf235d48d28c42d9c1690f, Goede Tijden, Slechte Tijden. Timer will fire in 576.485483716667 minutes 2019-01-17 10:28:31.129 Info App: Creating recording timer for af22f1cd6a8b58bcd11cbbc001b29ee9, Goede Tijden, Slechte Tijden. Timer will fire in 6328.48117756667 minutes 2019-01-17 10:28:31.226 Info App: Creating recording timer for acdbc456edc95c97b84442838c447844, Goede Tijden, Slechte Tijden. Timer will fire in 7768.47956418333 minutes 2019-01-17 10:28:31.986 Info App: Creating recording timer for 054e5ccd58c6529f13d1492fe3ccafa4, Goede Tijden, Slechte Tijden. Timer will fire in 9208.46688521667 minutes 2019-01-17 10:28:32.106 Info App: Creating recording timer for dea5cb07a5cd94eba047cccff051db2c, Steenrijk, Straatarm. Timer will fire in 9238.46489531667 minutes I still need to look at this... Tonights (test) recording does miss pieces. Like the recording stops for a few seconds and than continues. Best - James 1
Carlo 4561 Posted January 18, 2019 Posted January 18, 2019 Are you running Emby on the NAS itself or a computer with the storage point set to the NAS? If it's on a computer you might want to try saving locally vs the NAS just to rule out any network issue.
Luke 42244 Posted January 22, 2019 Posted January 22, 2019 Where did the dvblink plugin go? It's still in the catalog. Are you not able to find it?
Luke 42244 Posted January 22, 2019 Posted January 22, 2019 I'm using TVMosaic for recording at this moment but maybe I will switch back to recording with Emby. So I have setup 2 serie recordings yesterday for testing and the first recording failed immediately. The second recording went well. The recording of Goede tijden, Slechte tijden failed and was just 127 mb and 3 minutes. What is the reason this recording failed? Thanks. There are actually multiple recordings in this log, and yes, it does look like there is an example of trying to record the same show from two different channels to the same file. So that can be looked at.
heula 192 Posted January 22, 2019 Author Posted January 22, 2019 It's still in the catalog. Are you not able to find it? Earlier it was not there. I see now that the plugin is there again. Thanks.
