Luke 42245 Posted January 19, 2019 Posted January 19, 2019 Thanks, we'll look at it in the other topic.
revengineer 142 Posted January 19, 2019 Author Posted January 19, 2019 I am linking this thread https://emby.media/community/index.php?/topic/64791-android-app-no-longer-scrolls/, which has evolved into debugging this issue. I am glad this is more widespread so there may eventually be a fix. Unfortunately, devs have been silent on this issue. I assume it's due to the v4 server release. For a long time, I just used v2 of the Android app to get around the sync issues, but they no longer work with the server v4.
jamvids 39 Posted February 14, 2019 Posted February 14, 2019 If anyone is still reading this, I have just got an android car stereo. I put an sd card in (only 32gb, which is the sucky limit). I can confirm that it does work with sync, but stupidly slow, and the card tested a write speed of 55mbps. The same playlist synced to internal memory in minutes, it was going to take hours to SD. It is an octa core rockchip model running Android 8.0. Sent from my G8141 using Tapatalk
Luke 42245 Posted August 17, 2019 Posted August 17, 2019 There are improvements in the app's beta channel if you'd like to help test those out: https://emby.media/community/index.php?/topic/76604-android-mobile-3069-new-download-manager/ Thanks.
