darbos 0 Posted January 11, 2019 Posted January 11, 2019 Hi I just came over from Plex and have a issues I am hoping someone can help with. I have emby running in a vm on ubuntu, everyhting works great both inside my network and outside my network, I have a nginx reverse proxy setup. I spend alot of time at another house I have and have a weird issue, I can watch emby on my phone no problem but if I hit the cast button I dont get any devices to cast too. I know weird, sounds like a google problem...but I can try and cast something else and everything shows up normal. I have good wifi and am connected, its all unifi. I also have been trying this on the stable version but upgraded today to the beta 4.0 to see if that helped but I am still seeing the issue. If someone could please help or point me in a direction to start looking I would very much appreciate it! **Hunting around the forums I see logs requested alot, I am not sure if posting on the forum without scrubbung them is ok?
Luke 42216 Posted January 11, 2019 Posted January 11, 2019 Hi, what device are you trying to cast from, and using what app?
darbos 0 Posted January 11, 2019 Author Posted January 11, 2019 Hi, I am trying to cast from iphonex. The emby or from the browser. (emby server)
Luke 42216 Posted January 11, 2019 Posted January 11, 2019 Ok, it's not supported in Safari. Can you try our iOS app instead? https://emby.media/emby-for-ios.html
darbos 0 Posted January 11, 2019 Author Posted January 11, 2019 yea i have tried from both the app and browser, i was trying the app first then tested the browser
Luke 42216 Posted January 11, 2019 Posted January 11, 2019 Hmm, well we use the google cast sdk to detect the devices. what if you install Chrome on your ubuntu vm, and then use the web app there. Does it see your chromecasts?
darbos 0 Posted January 11, 2019 Author Posted January 11, 2019 i use ubuntu server, theres no gui. I know its strange, I looked through them emby logs I see the connecting and request but nothing about a chromecast (i dont know if I should or not but was just looking for something odd)
Luke 42216 Posted January 11, 2019 Posted January 11, 2019 You won't see anything in the emby logs because it is direct from browser to chromecast device, or from ios app to chromecast device. Do you possibly have another device you can try with?
darbos 0 Posted January 11, 2019 Author Posted January 11, 2019 Yea, Ill be back there tomorrow and do some more digging. Thanks for helping, Ill post back here tomorrow and let you know what I find.
Luke 42216 Posted January 11, 2019 Posted January 11, 2019 Great, thanks. Just be aware that if you use a browser, it must be Chrome.
darbos 0 Posted January 11, 2019 Author Posted January 11, 2019 OK I did not know that, thanks for the heads up.
