Angelblue05 4132 Posted January 11, 2019 Posted January 11, 2019 @@effe.rnr Did you update to the latest nightly and downgraded? I'm trying to make sure the add-on is not accidentally creating the database 114.db
Guest Posted January 11, 2019 Posted January 11, 2019 no I just deleted the .db file I am currently running Kodi RC4 on NVidia Shield, Emby Server 4.0.0.1 and addon version 3.1.39a
Angelblue05 4132 Posted January 11, 2019 Posted January 11, 2019 Ok, thanks. I'll post a new build soon to fix the bugs.
VaporTrail 66 Posted January 12, 2019 Posted January 12, 2019 Ok, thanks. I'll post a new build soon to fix the bugs. Also on MBServer 4.0.0.1 and addon version 3.1.39a. Should I wait for a hotfix before trying anything drastic to get db sync working on my Firestick? 1
Guest Posted January 12, 2019 Posted January 12, 2019 Also on MBServer 4.0.0.1 and addon version 3.1.39a. Should I wait for a hotfix before trying anything drastic to get db sync working on my Firestick? just delete the MyVideos114.db file in .kodi/userdata/Database and restart Kodi and it should work again
Angelblue05 4132 Posted January 12, 2019 Posted January 12, 2019 Also on MBServer 4.0.0.1 and addon version 3.1.39a. Should I wait for a hotfix before trying anything drastic to get db sync working on my Firestick? Working on a fix right now, hopefully have a new release out in an hour or so. 1
Guest Posted January 12, 2019 Posted January 12, 2019 Can you give this build a try? yes. Database update worked!
Angelblue05 4132 Posted January 12, 2019 Posted January 12, 2019 3.1.40 should fix this. Let me know if it's not the case, thanks for helping test beta 1
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 3.1.40 should fix this. Let me know if it's not the case, thanks for helping test beta I'm on rc5 and 3.1.40 22:12:35.565 T:156668749040 NOTICE: EMBY.database -> ERROR:: Database: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/Database/MyVideos114.db missing 22:12:35.566 T:156492588272 NOTICE: EMBY.monitor -> --[ post capabilities/a11077ab222d4e5097171381eca8aacd ] 22:12:35.780 T:156668749040 NOTICE: EMBY.database -> [emby] 1 rows updated. 22:12:36.073 T:156668749040 NOTICE: Previous line repeats 2 times. 22:12:36.073 T:156668749040 NOTICE: EMBY.library -> --[ retrieve changes ] 2019-01-12T03:06:43z 22:12:36.143 T:156668749040 NOTICE: EMBY.library -> --<[ retrieve changes ] 22:12:44.180 T:156477932784 ERROR: GetDirectory - Error getting foster:/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/Database $ ls Addons27.db MyMusic72.db MyVideos115.db TV32.db Textures13.db-wal CDDB MyVideos112.db MyVideos115.db-shm Textures13.db ViewModes6.db Epg12.db MyVideos113.db MyVideos115.db-wal Textures13.db-shm emby.db
Angelblue05 4132 Posted January 12, 2019 Posted January 12, 2019 (edited) Ok so it's using MyVideos115.db? What is the issue? Should it be using 113? Edit:Please see https://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ Edited January 12, 2019 by Angelblue05
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 Ok so it's using MyVideos115.db? What is the issue? Should it be using 113? Edit:Please see https://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ I upgraded to rc5. I'm assuming that means it should be using 115.db... so why is 3.1.40a still looking for 114.db after the upgrade? I'll work on pulling a proper log 1
Angelblue05 4132 Posted January 12, 2019 Posted January 12, 2019 (edited) Ok I understand what you are saying. Looking into it, will likely push another update soon. Thanks. Edited January 12, 2019 by Angelblue05
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 Ok I understand what you are saying. Looking into it, will likely push another update soon. Thanks. Thanks for your help. Log attached in case you still need it kodi.log 1
Angelblue05 4132 Posted January 12, 2019 Posted January 12, 2019 @@marcmv1 Should be corrected with 3.1.41. Thanks for providing your log.
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 @@marcmv1 Should be corrected with 3.1.41. Thanks for providing your log. I'm up and running again. Thanks much for the quick turnaround!
djhifi 56 Posted January 12, 2019 Posted January 12, 2019 yes I don't understand. I get you are on rc4, but if you have 114.db on that same Kodi, can you delete it because it should still be using 113.db? Chiming in. I'm also not seeing auto updates. Just deleted the database from within kodi and started a new and fresh scan. Currently going on. I've got 114 as well as 113 and 12. What a mess I've been updating Kodi with nightlies, and Im currently on RC5. I'm supposed to delete all but 114, correct?
VaporTrail 66 Posted January 12, 2019 Posted January 12, 2019 Chiming in. I'm also not seeing auto updates. Just deleted the database from within kodi and started a new and fresh scan. Currently going on. I've got 114 as well as 113 and 12. What a mess I've been updating Kodi with nightlies, and Im currently on RC5. I'm supposed to delete all but 114, correct? My understanding is wait until Emby for Kodi 3.1.41a gets released. Once installed, it should fix auto updates on RC4/5 and not require deleting databases manually. Is that correct @@Angelblue05? 1
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 I have 3.1.42a and I'm getting updates now
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 OK I dug deeper because I still am getting errors for MyVideos114.db when I'm up to 115. /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/addon_data/plugin.video.emby/emby/objects/obj_map.json DO THIS AT YOUR OWN RISK AND MAKE A BACKUP!!!!!!!! Look at the file above. If you see references to db files that don't exist remove them. I have references to MyVideos112, 113 & 114. I removed them and added 115. No more kodi.log errors.
VaporTrail 66 Posted January 12, 2019 Posted January 12, 2019 I haven't touched any database files on my Firestick yet. Simply waiting for a newer version than 3.1.39a through auto-update. So far nothing, so no restored sync yet.
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 I got the latest via auto update. It's there 1
VaporTrail 66 Posted January 12, 2019 Posted January 12, 2019 (edited) I got the latest via auto update. It's there Your right, just had to update local addons in Embuary menu... restarting Emby for Kodi wasn't initiating the update. Now I'm on 3.1.42a & Kodi RC4, but there was a warning before sync my database may be wrong version. Do I still have to dig into Kodi's internals and delete stuff manually with this infernal remote? ...or perhaps upgrade Kodi to RC5? Edited January 12, 2019 by VaporTrail
djhifi 56 Posted January 12, 2019 Posted January 12, 2019 (edited) My understanding is wait until Emby for Kodi 3.1.41a gets released. Once installed, it should fix auto updates on RC4/5 and not require deleting databases manually. Is that correct @@Angelblue05? Indeed. I've just finished the scan and 114 has no size in MB's. I wonder why it's even there? Edited January 12, 2019 by djhifi
marcmv1 13 Posted January 12, 2019 Posted January 12, 2019 If you're on RC5 then your DB should be 115. Editing the file is simple. Adb pull. Edit. Push
VaporTrail 66 Posted January 12, 2019 Posted January 12, 2019 (edited) If you're on RC5 then your DB should be 115. Editing the file is simple. Adb pull. Edit. Push If 3.1.42a was built for RC5, wouldn't upgrading to RC5 fix the issue like it did for @@djhifi (albeit with an empty 114) w/o modifying core files? Edited January 12, 2019 by VaporTrail
