ZiemaF 0 Posted January 7, 2019 Posted January 7, 2019 Hi, I can not run VAAPI on my server. My server is on an i5-8600K processor, OMV 0.4 4.1.17-1 installed. EMBY is placed on DOCKER EMBY works great except for VAAPI. Please help me how to run it. ffmpeg-transcode.txt embyserver.txt
Luke 42246 Posted January 7, 2019 Posted January 7, 2019 Hi, can you please describe the problem? thanks !
ZiemaF 0 Posted January 7, 2019 Author Posted January 7, 2019 GPU video transcoding in the Intel processor does not work. Generally emby works well, but the GPU transcoding does not work. I have the OpenMediaVault system installed on the server. Docker is running on the server. And on Docker is running EMBY. Installations I made according to https://hub.docker.com/r/emby/embyserver/ The user "emby" is created with id: 1000, and I added it to the "video" group (id: 44) All transcoding goes through all 6 processor cores. I do not know what I did wrong.
Luke 42246 Posted January 7, 2019 Posted January 7, 2019 Ok, this has all been revamped in the upcoming new release. I would try that once available. Thanks !
ZiemaF 0 Posted January 7, 2019 Author Posted January 7, 2019 When will it be? Do you think it's EMBY fault? I am afraid that I have set something wrong. :-)
Luke 42246 Posted January 7, 2019 Posted January 7, 2019 Soon. You can learn more about all of the great new development here: https://emby.media/community/index.php?/topic/64534-36058-hardware-acceleration-settings/ Thanks.
ZiemaF 0 Posted January 17, 2019 Author Posted January 17, 2019 Hi, I have a new version of EMBY 4.0.0.2 installed. I still have a problem with hardware transcoding. What can I do now?
matty87a 8 Posted January 17, 2019 Posted January 17, 2019 Did you specify the below in your docker run? --device /dev/dri/renderD128 My docker-compose file is below which works with Vaapi in case it helps (obviously the ports,mounts and uid/gid will be different) version: '2' services: emby: image: emby/embyserver:beta restart: unless-stopped environment: - PUID=112 - GID=114 - VIRTUAL_HOST=watch.domain.name - LETSENCRYPT_HOST=watch.domain.name - LETSENCRYPT_EMAIL=test@example.com - GIDLIST=44 - VIRTUAL_PORT=8096 ports: - "9096:8096" expose: - "8096" volumes: - emby_config:/config:rw - /media/:/media:rw devices: - /dev/dri/renderD128 volumes: emby_config: external: true networks: default: external: name: Backend
ZiemaF 0 Posted January 17, 2019 Author Posted January 17, 2019 I have everything well set up. What else do you suggest?
Luke 42246 Posted January 17, 2019 Posted January 17, 2019 Can you please attach the emby server and hardware detect log? thanks.
ZiemaF 0 Posted January 17, 2019 Author Posted January 17, 2019 The files you asked for are in the attachment. embyserver.txt hardware_detection.txt
Luke 42246 Posted January 17, 2019 Posted January 17, 2019 Docker is a bit more difficult and will require setup on your part, for example see @zeimaf's post #9. Did you also map the device, for example: --device=/dev/dri/card1:/dev/dri/card0 --device /dev/dri/renderD129:/dev/dri/renderD128 This is just an example and may not work for you.
ZiemaF 0 Posted January 18, 2019 Author Posted January 18, 2019 How do I check "vainfo" then return it to me (vainfo.jpg) Something is wrong Maybe somehow I need to install graphics card drivers (intel)
Luke 42246 Posted January 19, 2019 Posted January 19, 2019 Maybe somehow I need to install graphics card drivers (intel) Yes this is very possible. Can you do that?
ZiemaF 0 Posted February 12, 2019 Author Posted February 12, 2019 I managed to find out more about this problem. Debian 9 "stretch" does not have a driver for Intel's 8th generation "Coffee Lake" processors. i965-va-driver version (1.7.3-1) Only in Debian 10 "buster" is the driver for new Intel processors. i965-va-driver version (2.2.0 + dfsg1-2) OMV 4 is based on Debian 9. I added drivers for graphics from Debian 10 to Debian 9 (OMV). vainfo after installing drivers from Buster root@OMV:~# vainfo error: XDG_RUNTIME_DIR not set in the environment. error: can't connect to X server! libva info: VA-API version 1.4.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_4 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.4 (libva 2.2.0) vainfo: Driver version: Intel i965 driver for Intel(R) Coffee Lake - 2.3.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD It looks like everything is ok. But hardware transcode in EMBY still does not work. I attach the EMBA logs in the attachments. It is not easy to run EMBY on Docker on OMV embyserver-2019.02.11.txt hardware_detection-2019.02.11.txt
bigverm23 2 Posted February 14, 2019 Posted February 14, 2019 you might have already realized this but you need to install any graphics drivers, including VAAPI inside of Docker.
ZiemaF 0 Posted February 14, 2019 Author Posted February 14, 2019 I did not come up with this idea. Do you know how to install these gpu drivers in the docker? Wysłane z mojego LG-H870 przy użyciu Tapatalka
Luke 42246 Posted February 17, 2019 Posted February 17, 2019 our official docker already ships a vaapi driver. Perhaps the container isn't being granted access to the gpu?
ZiemaF 0 Posted February 17, 2019 Author Posted February 17, 2019 How can I check it? Wysłane z mojego LG-H870 przy użyciu Tapatalka
Luke 42246 Posted February 18, 2019 Posted February 18, 2019 Have you mapped the device properly? To do so, simply use --device=/dev/dri/card1:/dev/dri/card0 --device /dev/dri/renderD129:/dev/dri/renderD128 Of course, adapt the number avec cardX and renderDXYZ to match your system.
ZiemaF 0 Posted February 18, 2019 Author Posted February 18, 2019 Now I'm lost I had set in DEVICE /dev/dri/renderD128 Is this the wrong setting?
sephx 5 Posted February 25, 2019 Posted February 25, 2019 (edited) Not sure if you got this problem fixed. Others mentioned adding devices, nobody mentioned /dev/dri permissions? If use portainer to manage docker. Edit Emby, find Runtime & Resources Tab. Add Device - > /dev/dri Rebuild your container. Permissions so container can talk to igpu = chmod -R 777 /dev/dri (rebuilt on server boot, best to add in to compose/boot scripts) Hope that helps! Edited February 25, 2019 by sephx
ZiemaF 0 Posted February 26, 2019 Author Posted February 26, 2019 (edited) I found a message in the EMBY log: "Failed to open the drm device /dev/dri/renderD128" I also set the permissions for this directory. My user for Doker also has full permissions for this directory "Devices": [ { "DeviceIndex": 0, "DeviceInfo": { "VendorId": 32902, "DeviceId": 16018, "SubsytemVendorId": 5208, "SubsytemDeviceId": 53248, "DevPath": "/sys/bus/pci/devices/0000:00:02.0", "DrmCard": "/dev/dri/card0", "DrmRender": "/dev/dri/renderD128", "IsEnabled": 1, "IsBootVga": 1, "Error": { "Number": -1, "Message": "Failed to open the drm device /dev/dri/renderD128" } } } Edited February 26, 2019 by ZiemaF
