EmbyCon Problem
I'm in trouble. My library has 1856 movies but when I click to open the whole library it gives a timed out, I tried to reduce the number of results to 100, but in the movies there is no option to go between the pages. Can someone help me? I already installed the Kodi Companion plugin.
I do not know how to capture these logs, could you teach me?
I believe it is due to some problem in the server overload due to content import. I use the STRM file system and imported more than 500 complete series. Maybe the server was overloaded with so much information and could not process the entire load for KODI. It seems everything is normal now.
Anyway, could you teach me how to capture the log?
Guest
