xp-1000 1 Posted December 20, 2018 Posted December 20, 2018 hello, I use emby 3.5.3.0 (I am not sure the problem occurs since this version or even before) on linux with netcore version. when I try to change position when I watch a video from the web interface, ffmpeg exit. I attach the log and I am available to debug and provide more information if you need. Thanks in advance for your help, it is very disturbing because if you begin to watch a video you need to watch it until the end ^^ emby.log
Luke 42246 Posted December 20, 2018 Posted December 20, 2018 Hi there, are you experiencing a problem?
xp-1000 1 Posted December 20, 2018 Author Posted December 20, 2018 hello, yeah I would prefer if I can change position during video playing without crash the video ^^ it worked fine before when I want forward in a video, just have to move the position cursor, there was a little pause then the video play again at its new position. now the player just freeze when I try to change position (tested on lot of different kind of videos) and the cursor go back to beginning (without action). I presume I have a specific problem to my install because such a big bug would have already been reported else but I did not change anything recently except upgrading from 3.4.1 to 3.5.3.
xp-1000 1 Posted December 20, 2018 Author Posted December 20, 2018 Hmm I also changed from mono version to netcore version but again I am pretty sure if there is this bug in netcore version it would be already reported. So I understood it probably depends on my own config and not emby itself but I will be grateful if you can help me to find the cause. I am available to provide you all information you need
Luke 42246 Posted December 20, 2018 Posted December 20, 2018 Hi there, can you please attach the complete emby server log, and the ffmpeg log? Thanks !
xp-1000 1 Posted December 22, 2018 Author Posted December 22, 2018 (edited) hello thanks.here is full clean logs. from the ui point of view, it is simple : when you move the cursor emby player controls work (the interface is not frozen, I can click on top left "back" arrow for instance) but the video just stops (the image stays the last one before move the cursor). from the server point of view, in addition of provided log, emby itself does not crash and have a "normal" usage of resources. tested on firefox and chromium and both have the probleme but emby for kodi works, I can move in videos without any problem Edited December 22, 2018 by xp-1000
Luke 42246 Posted December 23, 2018 Posted December 23, 2018 Would you mind attaching again? There seems to be a problem with the attachment. Thanks !
xp-1000 1 Posted December 23, 2018 Author Posted December 23, 2018 Hello @@Luke, I uploaded the zip file containing logs here : https://ufile.io/rgcn1 thanks for your help I will investigate further today from my side.
Luke 42246 Posted December 23, 2018 Posted December 23, 2018 @@softworkz what do you make of this? it looks like some kind of I/O stall on the initial seek?
softworkz 5133 Posted December 26, 2018 Posted December 26, 2018 @@xp-1000 @@Luke If such seek errors are limited to specific video files, then we should look at those videos and check whether they might have some corrupt index entries (depending on the container format). But if you see that behavior for all videos, then it's most likely a system setup problem. For further investigation, you should copy one of the videos to a local folder create a new movie library for that folder wait for library scan completion play that file from the local library and try to seek If that is working, we should look at the way you've mounted /mnt/kiwisdatacenter What kind of mount is this? Network? Which protocol? My primary suspicion would be that either the mounting provider or the mounting target implementation does not support direct seeking.
xp-1000 1 Posted December 26, 2018 Author Posted December 26, 2018 (edited) hello, thanks for your answer @@softworkz. It is a very simple and classic local mount point from a disk in xfs which has been used from 4 years without any problem and there was no changes recently at this level. I make more tests : - I did not tested enough videos (or rather not enough of different videos formats) but is works on some videos (so the problem does not impact the entire library) - videos which works and which does not work are on the same library / mount point - transcoding seems to present the problem on ALL videos contrary to direct play which works on some videos but present the same problem on other - all videos work (MKV, MP4) with transcoding or direct play if I play them from the start and not trying to move. - with emby for kodi it works on ALL videos (even with videos which present the problem from the webui) - according to these tests, it seems that all MKV videos have seek error and all MP4 videos don't have it (except when you select a specific quality instead of auto to force transcoding). I found one exception with a mp4 video which present the same problem than mkv but I suppose it could be a corrupted file (even if playing from the start works fine), here is its specifications : Vidéo Title480P H264 CodecH264 Étiquette du codecavc1 AVCYes ProfilHigh Niveau30 Résolution848x480 Ratio d'aspect original16:9 EntrelacéNo Images par seconde23.9759865 Débit1359 kbps Profondeur en Bit8 bit Format de pixelyuv420p Images de référence1 NAL4 Audio TitleUnd MP3 stereo Default Langueund CodecMP3 Étiquette du codecmp4a Répartitionstereo Chaînes2 ch Débit128 kbps Débit échantillon48000 Hz DéfautYes Conteneurmp4 So you were right @@softworkz but I put you on a bad track saying entire library present the problem (sorry I have a majority of mkv). I hope these information could be useful to help me to debug and I still available to make all tests you propose. I am suprised that all videos works with seeking from kodi but not from the webui but I think I will still try to downgrade ffmpeg even if it does not seems to be updated recently, for your information here is its version : ffmpeg version n4.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 8.2.1 (GCC) 20180831 configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libiec61883 --enable-libjack --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxml2 --enable-libxvid --enable-nvdec --enable-nvenc --enable-omx --enable-shared --enable-version3 libavutil 56. 22.100 / 56. 22.100 libavcodec 58. 35.100 / 58. 35.100 libavformat 58. 20.100 / 58. 20.100 libavdevice 58. 5.100 / 58. 5.100 libavfilter 7. 40.101 / 7. 40.101 libswscale 5. 3.100 / 5. 3.100 libswresample 3. 3.100 / 3. 3.100 libpostproc 55. 3.100 / 55. 3.100 Thanks again for your help Edited December 26, 2018 by xp-1000
xp-1000 1 Posted December 26, 2018 Author Posted December 26, 2018 I just downgraded ffmpeg (1:4.1-1 => 1:4.0.2-7) and now all is working fine (mkv, mp4, transcoding, direct playing ....)
Luke 42246 Posted December 26, 2018 Posted December 26, 2018 Thanks for the feedback. So this is arch linux?
xp-1000 1 Posted December 26, 2018 Author Posted December 26, 2018 Hello, I only downgraded ffmpeg package so I am afraid this is a problem with either new version of ffmpeg itself or emby compatibility with this version. I think the only fault of archlinux here is to be too updated compared to other distros. If I am right my downgrading is only a workaround and this problem will impact all other distros when they will use ffmpeg 4.1. Idealy, someone should test this version of ffmpeg on its installation (different from archlinux) to validate this assertion. I will be happy to help you in testing and troubleshooting if you need.
Luke 42246 Posted December 26, 2018 Posted December 26, 2018 No, it wont' impact other distros because we ship our own ffmpeg with all other distros. Thanks for the feedback.
softworkz 5133 Posted December 26, 2018 Posted December 26, 2018 If I am right my downgrading is only a workaround and this problem will impact all other distros when they will use ffmpeg 4.1. No, it's not a workaround. We're having our own version of ffmpeg that we're delivering and packaging, and this is the only one we're supporting.
softworkz 5133 Posted December 26, 2018 Posted December 26, 2018 That's almost been a chorus response :-)
Solution xp-1000 1 Posted December 27, 2018 Author Solution Posted December 27, 2018 hello, oh ok I did not know ffmpeg was packaged into the emby package for other distros my bad.And I thought emby package for archlinux was an "official" package maintained by emby team like for other distros. So now I know that, yes it should only impact archlinux (and other distros not supported officially by emby team). in my opinion you should add a note to the download page https://emby.media/linux-server.html to inform it is not an official package and you advice using an official one if we encounter problems. and so be carreful when you will want to upgrade your embeded ffmpeg version to 4.1 it will probably cause some problems (and this time for every linux users ^^ ) thanks for your help and your availability. 1
xp-1000 1 Posted December 27, 2018 Author Posted December 27, 2018 hmm, I am probably blinded but I don't see how mark the topic as "solved" (seems I cannot edit the title, only the first post)
