FrostByte 5453 Posted April 30, 2020 Posted April 30, 2020 Where do you get the USB version? Is there a changelog? Sent from my SM-G960U1 using Tapatalk https://emby.media/community/index.php?/topic/74969-samsung-tizen-smarttv-2015-present-beta-app-install-from-usb/ Release notes have not been updated yet
Sammy 791 Posted April 30, 2020 Posted April 30, 2020 Cool. Now to find a USB stick to sacrifice at FAT16.. 1
psxlover 32 Posted April 30, 2020 Posted April 30, 2020 @@Sammy I've been using an NTFS formatted usb stick without issues. Just try the first one you find. 2
FrostByte 5453 Posted April 30, 2020 Posted April 30, 2020 I think it's specific to the year of your tv and what it supports. They all support fat16 so that was just the easiest to with since others reported having problems with other formats
shocker 135 Posted April 30, 2020 Posted April 30, 2020 @@Luke Can you please let me know if the LiveTV security bug ( https://emby.media/community/index.php?/topic/83806-livetv-permission-bug-on-samsung-tv-app/ ) has been fixed on 1.0.78?
Sammy 791 Posted April 30, 2020 Posted April 30, 2020 It's a 2017 UN40M5300A. So YES! According to the manual it supports NTFS but I suppose I need to dig up a USB 2.0 thumb drive. 1
Bruny07 0 Posted April 30, 2020 Posted April 30, 2020 (edited) So I've uninstalled the old .77 and installed the .78 from usb and now I can't login (invalid user or password). 2020-04-30 22:16:37.124 Info HttpServer: HTTP Response 401 to 185.xxx.xxx.xxx. Time: 1ms. http://xxxxx:8096/emby/Users/authenticatebyname 2020-04-30 22:16:55.707 Info HttpServer: HTTP GET http://xxxxx:8096/emby/Users/authenticatebyname. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 5.0) AppleWebKit/537.36 (KHTML, like Gecko) Version/5.0 TV Safari/537.36 2020-04-30 22:16:55.707 Error HttpServer: Access token is invalid or expired. Edit: Downgraded back to .77 and I was able to login Edited May 1, 2020 by Bruny07
Sammy 791 Posted May 3, 2020 Posted May 3, 2020 I didn't get a chance to use the beta version yet but the stable version .77 seems to work, albeit sloow.. Will Tizen ever get time shifting / seeking or CC's in LiveTV or is this just too hard to implement?
Luke 42239 Posted May 3, 2020 Author Posted May 3, 2020 So I've uninstalled the old .77 and installed the .78 from usb and now I can't login (invalid user or password). 2020-04-30 22:16:37.124 Info HttpServer: HTTP Response 401 to 185.xxx.xxx.xxx. Time: 1ms. http://xxxxx:8096/emby/Users/authenticatebyname 2020-04-30 22:16:55.707 Info HttpServer: HTTP GET http://xxxxx:8096/emby/Users/authenticatebyname. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 5.0) AppleWebKit/537.36 (KHTML, like Gecko) Version/5.0 TV Safari/537.36 2020-04-30 22:16:55.707 Error HttpServer: Access token is invalid or expired. Edit: Downgraded back to .77 and I was able to login Hi, what version of emby server are you running?
k0Lm. 32 Posted May 4, 2020 Posted May 4, 2020 (edited) Unfortunatly, after a year or 2, i still encounter the same bugs which makes Emby not preferred and still use Plex, but, i have it on the side to see if some stuff finally gets fixed and i can switch over.For some more information about Bruny07's issue, which i also encountered; Go to the user that has that issue, select tab Access, at the bottom mark option "Allow access from all devices".I don't know if that solves it for you but it did for mine, for some reason it lists the updated TV as a new device.Afterwards the "new" device will be listed and you can use that to revert the settings. Edit: Oh and for one server update there also was a password error, dont know the version but it was a pretty recent one. It worked fine for all other devices but the samsung TV got logged out and errored when logging back in. After removing the password and reapplying the same password it worked. Hope it helps. So I've uninstalled the old .77 and installed the .78 from usb and now I can't login (invalid user or password). 2020-04-30 22:16:37.124 Info HttpServer: HTTP Response 401 to 185.xxx.xxx.xxx. Time: 1ms. http://xxxxx:8096/emby/Users/authenticatebyname 2020-04-30 22:16:55.707 Info HttpServer: HTTP GET http://xxxxx:8096/emby/Users/authenticatebyname. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 5.0) AppleWebKit/537.36 (KHTML, like Gecko) Version/5.0 TV Safari/537.36 2020-04-30 22:16:55.707 Error HttpServer: Access token is invalid or expired. Edit: Downgraded back to .77 and I was able to login Edited May 4, 2020 by k0Lm.
Sammy 791 Posted May 7, 2020 Posted May 7, 2020 I finally got a chance to install this beta. It shows up as a "white" app rather than the standard "Chocolate" app. Still now time shifting (other than pause) and no CC's in LiveTV. Will that ever be possible? This is my only SmartTV BTW and it is in the guest bedroom so not too much of a deal; everything else is hooked into AndroidTV.
EZEd 60 Posted May 7, 2020 Posted May 7, 2020 While we're asking about things possibly coming to the Samsung TV app, I'll throw this one in again... now that Android TV and Roku have a functional version of being able to play music and photo slideshows simultaneously, will the Samsung TV app ever get this capability or is it physically impossible with their hardware? Currently Samsung TV app can't do this. If you start one and then try to start the other, the former immediately stops. They can't be made to play together simultaneously in any measure. This is a feature that I've been waiting on since I got my TV. It appears to work on all the other clients except this one. The Plex client on Samsung TV is also able to do it, so evidently the Samsung hardware allows it somehow, but I guess maybe the server side is doing more of the work in that case than the client. If the Samsung TV app will never have the capability it's not a problem, I can use one of the other clients (Android or Roku) it's just not preferred. Also if the capability is not coming to Samsung TV app, I can stop looking for it and asking about it. Just wondering?
Luke 42239 Posted July 22, 2020 Author Posted July 22, 2020 1.0.81 is available for USB installation. It has a number of subtitle related improvements that can be found in the release notes topic. Thanks. 1
Sammy 791 Posted July 22, 2020 Posted July 22, 2020 31 minutes ago, Luke said: 1.0.81 is available for USB installation. It has a number of subtitle related improvements that can be found in the release notes topic. Thanks. Closed Captions for LiveTV yet?
Luke 42239 Posted July 22, 2020 Author Posted July 22, 2020 4 minutes ago, Sammy said: Closed Captions for LiveTV yet? No, the changes were related to subtitle files. 1
Luke 42239 Posted September 11, 2020 Author Posted September 11, 2020 1.0.84 is up for USB download. Thanks guys.
psxlover 32 Posted September 11, 2020 Posted September 11, 2020 5 hours ago, Luke said: 1.0.84 is up for USB download. Thanks guys. Perhaps you could post new versions in the changelog thread as replies, in addition to updating the changelog in the first post. That would trigger e-mails to whoever follows the thread. Of course posting here would be good enough, if it is consistent
Luke 42239 Posted September 11, 2020 Author Posted September 11, 2020 Yes not a bad idea. Thanks for the feedback.
voe 0 Posted September 14, 2020 Posted September 14, 2020 How can I rewind a video? version 1.0.84 UE55NU7470, remote controller
serpi 82 Posted September 14, 2020 Posted September 14, 2020 1 hour ago, voe said: How can I rewind a video? version 1.0.84 UE55NU7470, remote controller Click left. You might have to do this a lot of times, there is no real rewind You might also be able to select a chapter from the info details screen. Ciao, Alfred
FrostByte 5453 Posted September 14, 2020 Posted September 14, 2020 1 hour ago, voe said: How can I rewind a video? version 1.0.84 UE55NU7470, remote controller There is a feature request to add real chapter and visual seeking. You can add your desire for this there if you want. Otherwise, like serpi mentioned you either choose the chapter from the details beforehand or you just keep skipping 30 seconds at a time. I think you can just hold the button down, but this basically does the same and just sends multiple skips
Jibest 27 Posted September 29, 2020 Posted September 29, 2020 I've been having issues with rewind when playing tv recordings (.ts files). When I click left to rewind 10 seconds or click the rewind button using the GUI it actually forwards 10 seconds instead? The move forward 30 seconds works as expected. This behavior does not occur when playing media that is not a recording. I also do not get this behavior using the web or Android app. Is this a known issue? Tv is a RU7400 4K TV App Version is 1.0.82
