Ruyiop 7 Posted December 8, 2018 Posted December 8, 2018 (edited) Hi developers I run latest beta emby server on windows server 2016 and use emby for Kodi for playback on nvidia shield. If I add 2 movies with group versions and one of them is in strm format , the one with strm format do not playback while the other version on mkv plays ok. This is normal behavior? Thank you. PS: The strm file plays ok if not inside group. Edited December 8, 2018 by Ruyiop
ntilagoa 12 Posted December 8, 2018 Posted December 8, 2018 Hello Have exactly the same problem. Don’t know if problem is with server or with emby for Kodi. Can anyone have a look? Thank you very much.
rapteev 20 Posted December 8, 2018 Posted December 8, 2018 Hi This behavior also happens to me. Angelblue , any idea? Thank you.
Luke 42238 Posted December 8, 2018 Posted December 8, 2018 In order for her to best help you, please make sure to see how to report a problem. Thanks ! 1
rapteev 20 Posted December 9, 2018 Posted December 9, 2018 (edited) Hello Here are log files from Kodi. The first one is with movie outside version group, and the movie (The golden Compass.strm) plays just fine. The second one is with movie part of a version group. In this case the same movie do not play back. Any other format plays just fine inside or outside a version group. Thank you https://paste.kodi.tv/ufebehazaf https://paste.kodi.tv/qevameniya PS: Emby server beta 3.6.0.74 running on windows server 2016, emby for Kodi running on Nvidia shield tv with latest nightly Kodi Leia. Edited December 9, 2018 by rapteev
Aleta 0 Posted December 9, 2018 Posted December 9, 2018 Hi This is really weird. I try to reproduce this. In fact the strm only plays if is not part of a group version. I do not have enough knowledge to point the problem. Maybe one of the developers can help you.
Angelblue05 4132 Posted December 10, 2018 Posted December 10, 2018 Thanks for posting your kodi log. Will get back to you on this.
Aleta 0 Posted December 10, 2018 Posted December 10, 2018 Angelblue05 . Thank you for looking into this.
rapteev 20 Posted December 29, 2018 Posted December 29, 2018 Hello Angelblue Wondering if you find a solution for this problem. Thank you
Angelblue05 4132 Posted January 17, 2019 Posted January 17, 2019 Sorry I couldn't fix this yet. It's still on my list. Will post back regarding this very soon.
rapteev 20 Posted January 17, 2019 Posted January 17, 2019 Hello Angelblue No worries. Take all the time that you need. I love your work on this amazing project. Thank you 1
Angelblue05 4132 Posted January 20, 2019 Posted January 20, 2019 Can you please give 3.1.45 a try? I have setup a test scenario, with a strm grouped with two other versions and the strm plays. Let me know.
rapteev 20 Posted January 20, 2019 Posted January 20, 2019 Hi Angelblue Do not work for me. Log attached. I try to play first a strm netflix movie outside a group version and it play just fine. When try to play a strm movie part of a group version, nothing happens. Thank you. Log: https://paste.kodi.tv/fexusehaqi 1
Angelblue05 4132 Posted January 21, 2019 Posted January 21, 2019 (edited) @@Luke After digging into the log some more. Emby seems to provide two different cases for strm using /playbackinfo. If it's a single strm file, the path contained inside the strm is returned as path value in the mediasource. But if the strm is part of grouped version, the path returned in the mediasource is the path to the strm file, which breaks playback. The strm in the grouped media sources should return what's contained within the strm. Edited January 21, 2019 by Angelblue05
Angelblue05 4132 Posted January 23, 2019 Posted January 23, 2019 @@Luke Just want to make sure you've seen this.
Aleta 0 Posted January 28, 2019 Posted January 28, 2019 Hi developers. Any update on this? Thank you very much.
Luke 42238 Posted January 28, 2019 Posted January 28, 2019 Thank you for your patience while this is investigated.
Luke 42238 Posted March 12, 2019 Posted March 12, 2019 I would suggest trying again with the latest release of emby server. thanks. 1
Angelblue05 4132 Posted March 12, 2019 Posted March 12, 2019 I can confirm this behaves correctly now. Thank you for the fix Luke.
