Genetik57 0 Posted November 28, 2018 Posted November 28, 2018 Hi, I have Emby Server (aarch64) on my Rock64 and the plugin Auto Box Sets does not work correctly There is no problem it works in my collection https://prntscr.com/lo9xny But it does not work in my movies folder https://prntscr.com/lo9xp9 I noticed this problem 2 months ago and today it still persists. Before everything was working properly and since then it's broken. I noticed this problem on a x64 dedicated server and on my Rock64 arm64 Best regards
Happy2Play 9814 Posted November 28, 2018 Posted November 28, 2018 This should have nothing to do with the plug in. There is a server setting Dashboard-Library-Display "Group items into collections". Do to pending updates in the next release you will not see this setting via app.emby.media. You will need to set it on a local connection.
Genetik57 0 Posted November 29, 2018 Author Posted November 29, 2018 (edited) This should have nothing to do with the plug in. There is a server setting Dashboard-Library-Display "Group items into collections". Do to pending updates in the next release you will not see this setting via app.emby.media. You will need to set it on a local connection. Hi, Thanks, but that does not solve my problem, it is always the disorder. Emby Server does not stop crashing on my aarch64, everytime I turn off and restart my rock64 ... Docker logs -> https://pastebin.com/hKSBneuE Emby Server Logs -> https://www.dropbox.com/sh/dry2z5chct03fg4/AABNJ1oLoFC94LNre2nj7svma?dl=0 Unable to retrieve Emby Server logs for the moment sorry ... @@Luke any idea please? Edited November 29, 2018 by Genetik57
Luke 42255 Posted November 29, 2018 Posted November 29, 2018 Please try removing these plugins and see it if makes a difference: Info App: Loading statistics, Version=2.0.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Statistics.dll Info App: Loading CoverArt, Version=4.0.90.0, Culture=neutral, PublicKeyToken=null from /config/plugins/CoverArt.dll Thanks. 1
Genetik57 0 Posted November 29, 2018 Author Posted November 29, 2018 Please try removing these plugins and see it if makes a difference: Info App: Loading statistics, Version=2.0.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Statistics.dll Info App: Loading CoverArt, Version=4.0.90.0, Culture=neutral, PublicKeyToken=null from /config/plugins/CoverArt.dll Thanks. Hi, I just added the logs (emby-server logs). You think that plugins are not yet compatible?
Luke 42255 Posted November 29, 2018 Posted November 29, 2018 At this point I don't know what the issue is so I'm just asking you to try it. Statistics is not ours, it is a community contribution from a community developer. Thanks.
Genetik57 0 Posted November 29, 2018 Author Posted November 29, 2018 At this point I don't know what the issue is so I'm just asking you to try it. Statistics is not ours, it is a community contribution from a community developer. Thanks. I uninstalled these plugins and restarted. I lost everything, everything is erased
Happy2Play 9814 Posted November 29, 2018 Posted November 29, 2018 Hi, Thanks, but that does not solve my problem, it is always the disorder. Emby Server does not stop crashing on my aarch64, everytime I turn off and restart my rock64 ... Docker logs -> https://pastebin.com/hKSBneuE Emby Server Logs -> https://www.dropbox.com/sh/dry2z5chct03fg4/AABNJ1oLoFC94LNre2nj7svma?dl=0 Unable to retrieve Emby Server logs for the moment sorry ... @@Luke any idea please? What is this topic about? What do you mean "it is always the disorder"? From the images in the first post you do not have "Group items into collections" enabled. The log shows you are on a beta server so the setting moved to a per library setting (select the three dot button next to filters).
Happy2Play 9814 Posted November 29, 2018 Posted November 29, 2018 I uninstalled these plugins and restarted. I lost everything, everything is erased You can't loose anything by removing plugins. How did you remove the plugins?
Genetik57 0 Posted November 29, 2018 Author Posted November 29, 2018 What is this topic about? What do you mean "it is always the disorder"? From the images in the first post you do not have "Group items into collections" enabled. The log shows you are on a beta server so the setting moved to a per library setting (select the three dot button next to filters). I will try again You can't loose anything by removing plugins. How did you remove the plugins? I restarted emby with docker and everything was cleared. I had the startwizard
Genetik57 0 Posted November 29, 2018 Author Posted November 29, 2018 (edited) Emby Server crashed again Process is terminating due to StackOverflowException. Aborted Edited November 29, 2018 by Genetik57
Luke 42255 Posted November 29, 2018 Posted November 29, 2018 Please try removing all plugins that you might have installed. Thanks.
Genetik57 0 Posted December 4, 2018 Author Posted December 4, 2018 (edited) Please try removing all plugins that you might have installed. Thanks. @@Luke Hi, Sorry I was traveling. I performed a clean installation of OMV + Emby Server with Docker (aarch64 beta) The problem arises each time. I launched Emby Server, I followed the wizard and once the wizard finished, I immediately turned off the server (I did not install a plugin, I did not launch a movie, I did not download a metadata, absolutely nothing) The container docker this stop automatically Docker logs -> https://pastebin.com/y1WCUmAg again and again : Process is terminating due to StackOverflowException. Best regards Edited December 4, 2018 by Genetik57
Luke 42255 Posted December 4, 2018 Posted December 4, 2018 Strange. Are you sure the aarch64 architecture is the right one for you?
Genetik57 0 Posted December 4, 2018 Author Posted December 4, 2018 Strange. Are you sure the aarch64 architecture is the right one for you? Yes sure root@rock64:~# uname -a Linux rock64 4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1 #1 SMP Mon Oct 22 20:59:41 UTC 2018 aarch64 GNU/Linux
Genetik57 0 Posted December 5, 2018 Author Posted December 5, 2018 Hi @@Luke any idea? Can I help you in any way? Emby Server does not have time to produce a log file as it goes shutdown
Genetik57 0 Posted December 5, 2018 Author Posted December 5, 2018 At the moment I'm not yet sure. This is very strange
Luke 42255 Posted December 6, 2018 Posted December 6, 2018 Do you know what version of libc is on the system?
Genetik57 0 Posted December 6, 2018 Author Posted December 6, 2018 (edited) Do you know what version of libc is on the system? libc6 is already the newest version (2.24-11+deb9u3). Edited December 6, 2018 by Genetik57
Genetik57 0 Posted December 9, 2018 Author Posted December 9, 2018 @@Luke Hi, I have the same problem with the Debian manually installation (https://emby.media/linux-server.html) with the Debian Arm64 (aarch64) - BETA I never really had any worries with Emby but now it's bothering me more and more. I also bought the subscription Emby Premiere Lifetime (I can send you my email address, the transaction number and the key by private message if you want proof) a few months ago and now I can not enjoy it because nothing works... What can I do to help you??? Best regards
Genetik57 0 Posted December 9, 2018 Author Posted December 9, 2018 Here are the logs, when I start my emby-server it tells me to wait and after then emby-server turns off Logs = https://pastebin.com/KNa46Dn2
Genetik57 0 Posted December 9, 2018 Author Posted December 9, 2018 What version of Debian? Here : https://github.com/ayufan-rock64/linux-build/releases I have this release stretch-openmediavault-rock64-0.7.11-1075-arm64.img.xz
Luke 42255 Posted December 9, 2018 Posted December 9, 2018 can you go here: /var/lib/emby/plugins Then delete the dll files for cover art and statistics and try again? thanks.
