rsvp 0 Posted January 14, 2019 Posted January 14, 2019 Well these last tips got Emby finally working on XBOX and android. Unfortunately broke all my kodi devices i use for TV. The hours spent on this , or months now has made me realize emby on freenas platform is not working for me.. I need to stop hosting on freenas. Seems this is where all the issues have started. First with waiting for Freenas 11.2 to rollout and not be broken just to put emby in there that is broken. . Add up the months its sizable time comittement with little success.. I am giving up on freenas before I give up on emby.
makarai 109 Posted January 14, 2019 Posted January 14, 2019 (edited) Well these last tips got Emby finally working on XBOX and android. Unfortunately broke all my kodi devices i use for TV. The hours spent on this , or months now has made me realize emby on freenas platform is not working for me.. I need to stop hosting on freenas. Seems this is where all the issues have started. First with waiting for Freenas 11.2 to rollout and not be broken just to put emby in there that is broken. . Add up the months its sizable time comittement with little success.. I am giving up on freenas before I give up on emby. Have you installed the kodi addon for emby, in emby ? without it it wont work. I am running freenas with emby in a native jail, with all the clients and casting devices possible behind a reverse proxy, and it works like a charm! Edited January 14, 2019 by makarai
gbarone123 4 Posted January 14, 2019 Author Posted January 14, 2019 RSVP, what are your issues with freenas? I’ve been hosting Emby for well over a year now without issue on freenas. There were very few issues along the way. I wrote this thread after solving the only playback issues I have had. I was running Plex and Emby in tandem for the first few months, and stayed with Emby, dumping Plex. If you detail your specific issues, I can probably help you solve them. My freenas box is pretty much set it and forget it.
rsvp 0 Posted January 14, 2019 Posted January 14, 2019 Well old version of freenas didn't update the plugin. And all Apps stopped working. Freenas updated to 11.2.. All apps didnt work with the IOCAGE plugin. With this beta version.. Having problems with always asking to sign in the app in kodi. And it has problems refreshing when library gets new items. So all in all I would say its been close to a year of problems.
rsvp 0 Posted January 14, 2019 Posted January 14, 2019 Yes I have kodi companion.. I even went to v18. that had problems went back to 17 and it worked ok.
gbarone123 4 Posted January 15, 2019 Author Posted January 15, 2019 Rsvp, A few questions. What plugins are you running? What kind of hardware are you running on? Did you make any changes to the base os?
stuartsjg 2 Posted February 21, 2019 Posted February 21, 2019 (edited) Hello, I used this post and successfully updated. However, i still had issues with ffmpeg and i spotted this thread which shown promise. However the process failed at the "make install clean" which i felt was due to being on freenas 11.1 not 11.2. I upgraded to 11.2-U2 but now emby wont load at the IP address. Ive tried to install a new emby 3.5.3.0 via the plugin GUI i get this error: If i try the above instructions, the portsnap fails: [root@[member="freenas"] ~]# jls JID IP Address Hostname Path 2 emby-server /mnt/iocage/jails/emby-server/root [root@[member="freenas"] ~]# jexec 2 # portsnap fetch extract Looking up portsnap.FreeBSD.org mirrors... none found. Fetching snapshot tag from portsnap.FreeBSD.org... failed. No mirrors remaining, giving up. # I tried a fresh CLI install based upon the emby home page instructions, however when i run sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw i get the message coming back Sorry, user root is not allowed to execute '/usr/sbin/pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw' as root on freenas.stuartjgraham.com. [root@[member="freenas"] ~]# sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw So perhaps my permissions are mucked up somewhere and thats stopping things from working. I only get a few hours a month to work on this due to work and family commitments and i wish i had never upgraded as it was such a simple thing back in October.... Edited February 21, 2019 by stuartsjg
gbarone123 4 Posted February 22, 2019 Author Posted February 22, 2019 Stuart, There are some issues being ironed out with 11.2u2 with iocage jails, apparently. That being said, seems like you have the jail networking issues worked out. Other threads have pointed out that unchecking and re-checking the auto button on DHCP for the jails somehow allows it to function again properly. Also, there were autostart on boot issues for iocage jails in u2. As for the permission issues, are you using ssh or the GUI? I’d recommend trying the GUI shell instead of ssh. There are also threads you could read about editing the sudoers file. Not sure why root would not be elevated privileges already, but u2 seems to have some bugs. Worth a read through of the threads. For starters though, try the GUI shell.
gbarone123 4 Posted February 22, 2019 Author Posted February 22, 2019 Stuart, Having read the code lines more carefully, it looks like you are running the install command from the base OS?? Root@@freenas??? Big no no. Create a new jail and run the commands inside the jail.
stuartsjg 2 Posted February 23, 2019 Posted February 23, 2019 (edited) Hi, Yes - thanks, after some mucking about with the IP address settings i was able to access emby. Theres a good amount on the bug at this freenas post. I am not clear what you mean by running commands inside the jail, this doesnt work either as in either the existing emby (plugin installed) jail i get a "sudo: command not found" and likewise if i create a new jail from scratch and run the sudo command first. This is where i thought it had to be ran from outside the jail so looked about and found if i run without "sudo" (suggested here) i.e. just "pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw" Then i get mismatches (package 1102000, kernel 1101001 (i say Y) and things then appear to go well. I reboot emby and still no resolution to playback issues. But now the steps above appear to work and i dont get errors after portsnap fetch extract. Things then go wrong when i follow the ffmpeg steps: # cd /usr/ports/multimedia/ffmpeg # make install clean ===> Building/installing dialog4ports as it is required for the config dialog ===> Cleaning for dialog4ports-0.1.6 ===> Skipping 'config' as NO_DIALOG is defined /!\ ERROR: /!\ Ports Collection support for your FreeBSD version has ended, and no ports are guaranteed to build on this system. Please upgrade to a supported release. No support will be provided if you silence this message by defining ALLOW_UNSUPPORTED_SYSTEM. *** Error code 1 Stop. make[3]: stopped in /usr/ports/ports-mgmt/dialog4ports *** Error code 1 Stop. make[2]: stopped in /usr/ports/ports-mgmt/dialog4ports ===> Options unchanged /!\ ERROR: /!\ Ports Collection support for your FreeBSD version has ended, and no ports are guaranteed to build on this system. Please upgrade to a supported release. No support will be provided if you silence this message by defining ALLOW_UNSUPPORTED_SYSTEM. *** Error code 1 Stop. make[1]: stopped in /usr/ports/multimedia/ffmpeg *** Error code 1 Stop. make: stopped in /usr/ports/multimedia/ffmpeg # /usr/ports/x11-toolkits/fltk-devel/ looks like i need to find a different version? Edited February 23, 2019 by stuartsjg
stuartsjg 2 Posted February 23, 2019 Posted February 23, 2019 For reference, i rebooted freenas in 11.1 RC1 boot environment and got the same error when i tried I did notice i was not on 11.2 RC2 as the post above suggests but a newer version. Will try with RC2.
gbarone123 4 Posted February 23, 2019 Author Posted February 23, 2019 Stuart, Ok, let's start from scratch. Delete the plugin jail you created and create a new iocage jail via the GUI. Once you have done so, mount your storage (folder where your media is located) to the /media folder of the jail. I can give detailed instructions if you aren't sure how to do this. Note, you'll have to stop the jail to add the storage, then restart it before going on. Then go into the shell of the jail. From within the shell of the jail run the following commands. Also, forget sudo, you are root. No need, and unless you've installed sudo and edited the config file, not sure it would work anyway, which is why you keep getting command not found errors. pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.2.0/emby-server-freebsd_4.0.2.0_amd64.txz sysrc emby_server_enable="YES" service emby-server start That should do it. Also, I would stick with 11.2u1 for now. There are some bugs with u2 and u3 will be out next month (3 weeks I've read).
stuartsjg 2 Posted February 24, 2019 Posted February 24, 2019 Hello I changed version to 11.2u1 (that was an interesting experience but i got there). Installed emby OK using the method you describe but then i do a rsync to copy the server data over and then i only get this site cant be reached, but i can ping. (my rsync is "rsync -vrlpogth /mnt/iocage/jails/emby-server/root/var/db/emby-server/ /mnt/iocage/jails/emby-mediaserver/root/var/db/emby/" ) "emby-server" jail is 4.1.0.8 but with the playback issues. "emby-mediaserver" is the install per your method which did work, then didnt after the sync. So, the routes are either fix the playback issues, or find a way to import the data without killing the new install. I done that before but cannot replicate it. Again i tried the proposed fix above, but the "make install clean" fails with the "ports collection support for your FreeBSD version has endee" message - i had wondered if this may work with u1 where it didnt on rc1
gbarone123 4 Posted February 24, 2019 Author Posted February 24, 2019 The new version of Emby (beyond 3.5.3.0) comes packaged with a working version of ffmpeg. This fix was a short term in response to version control issues between Emby and freenas and which release was being used. At this point, you may be able to try installing via plugin, then from the Emby jail run “pkg install libraw” and then run the upgrade command “pkg add -f...” from previous response, then restart the jail. This would get you to the newest version with the appropriate ffmpeg. I can test this later to be sure (I’m on u1 currently). Haven’t tried doing the plugin since RC2.
gbarone123 4 Posted February 24, 2019 Author Posted February 24, 2019 Also, what exactly are you trying to copy over with rsync? Is it users? You should just add the libraries again and after a scan, you should be back to normal. As long as you don’t have a ton of users, I’d recommend just re-creating their accounts once you have everything up and running.
stuartsjg 2 Posted February 24, 2019 Posted February 24, 2019 I've been using emby for 3 years so I have playback history, playlists, tweeked meta data etc, not to mention all the content such as thumbnails which comes is in the GBs whilst I'm on metered 4G connection (direct fibre to house a few months away yet) which I don't want to download again. I am going to try and upgrade the freshly installed jail and then again try and copy the files over. I'll have a dig further to see what I done which allowed it to work the last time.
gbarone123 4 Posted February 25, 2019 Author Posted February 25, 2019 If you are premiere, you could also run the config backup plugin. Then update and refresh from it.
makarai 109 Posted February 25, 2019 Posted February 25, 2019 (edited) Hello I changed version to 11.2u1 (that was an interesting experience but i got there). Installed emby OK using the method you describe but then i do a rsync to copy the server data over and then i only get this site cant be reached, but i can ping. (my rsync is "rsync -vrlpogth /mnt/iocage/jails/emby-server/root/var/db/emby-server/ /mnt/iocage/jails/emby-mediaserver/root/var/db/emby/" ) "emby-server" jail is 4.1.0.8 but with the playback issues. "emby-mediaserver" is the install per your method which did work, then didnt after the sync. So, the routes are either fix the playback issues, or find a way to import the data without killing the new install. I done that before but cannot replicate it. Again i tried the proposed fix above, but the "make install clean" fails with the "ports collection support for your FreeBSD version has endee" message - i had wondered if this may work with u1 where it didnt on rc1 Please check the Path in your destination folder! (my rsync is "rsync -vrlpogth /mnt/iocage/jails/emby-server/root/var/db/emby-server/ /mnt/iocage/jails/emby-mediaserver/root/var/db/emby-server/" ) Also If you install a new jail try the easy method first, dont use the very outdated plugin installation from freenas. This Installation method will create a Jail that is fully configurable via the FreeNAS GUI LATEST STABLE (4020) cd /tmp wget https://raw.githubusercontent.com/ma-karai/iocage-plugin-emby/master/emby-server.json iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server.json --branch 'master' LATEST BETA (4.1.0.10) cd /tmp wget https://raw.githubusercontent.com/ma-karai/iocage-plugin-emby/beta/emby-server-beta.json iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server-beta.json --branch 'beta' Edited April 26, 2019 by makarai
stuartsjg 2 Posted February 26, 2019 Posted February 26, 2019 Ok, gave this a quick bash... no luck. Something is against me. I created a folder via windows on a mapped drive, and added that folder as storage to the jail. This failed to backup: 2019-02-26 22:47:48.100 Error TaskManager: Error *** Error Report *** Version: 4.1.0.8 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Feb 7 10:13:31 UTC 2019) Processor count: 12 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/media/emby_backup/Emby Backup - 2019-02-26 10.47.48 - Auto" is denied. at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x0005e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.Directory.CreateDirectory (System.String path) [0x0008f] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.IO.ManagedFileSystem.CreateDirectory (System.String path) [0x0001b] in <da8ec2ecd86a4f4f8ecf1e860bebd672>:0 at MBBackup.ServerEntryPoint+<ExecuteBackup>d__61.MoveNext () [0x00199] in <b48c1b9ae14d440baa732016b620ddb8>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at MBBackup.Entities.ScheduledBackupTask+<Execute>d__8.MoveNext () [0x00085] in <b48c1b9ae14d440baa732016b620ddb8>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>d__68.MoveNext () [0x00188] in <da8ec2ecd86a4f4f8ecf1e860bebd672>:0 Source: mscorlib TargetSite: Void Throw() 2019-02-26 22:47:48.100 Info TaskManager: Configuration Backup Failed after 0 minute(s) and 0 seconds Thinking it was perhaps a permissions issue, before getting into that, i tried backing up to a folder within the jail, so i created (mkdir) a new folder in emby-server/root/backup which failed too: 2019-02-26 23:04:33.164 Error TaskManager: Error *** Error Report *** Version: 4.1.0.8 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Feb 7 10:13:31 UTC 2019) Processor count: 12 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/backup/Emby Backup - 2019-02-26 11.4.33 - Auto" is denied. at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x0005e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.Directory.CreateDirectory (System.String path) [0x0008f] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.IO.ManagedFileSystem.CreateDirectory (System.String path) [0x0001b] in <da8ec2ecd86a4f4f8ecf1e860bebd672>:0 at MBBackup.ServerEntryPoint+<ExecuteBackup>d__61.MoveNext () [0x00199] in <b48c1b9ae14d440baa732016b620ddb8>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at MBBackup.Entities.ScheduledBackupTask+<Execute>d__8.MoveNext () [0x00085] in <b48c1b9ae14d440baa732016b620ddb8>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>d__68.MoveNext () [0x00188] in <da8ec2ecd86a4f4f8ecf1e860bebd672>:0 Source: mscorlib TargetSite: Void Throw() 2019-02-26 23:04:33.164 Info TaskManager: Configuration Backup Failed after 0 minute(s) and 0 seconds I really don't get why its so hard when i am following the same commands others are doing with ease and success.
stuartsjg 2 Posted February 26, 2019 Posted February 26, 2019 Had another idea to try a smaller move of files from ../db/emby-server by copying my current working but not playback server to an intermediate location, then delete the folders in the new server, then move the 3 folders over and check they were all good: rsync -vrlpogth /mnt/iocage/jails/emby-server/root/var/db/emby-server/config/ /mnt/iocage/jails/emby-serverdb/config/ rsync -vrlpogth /mnt/iocage/jails/emby-server/root/var/db/emby-server/data/ /mnt/iocage/jails/emby-serverdb/data/ rsync -vrlpogth /mnt/iocage/jails/emby-server/root/var/db/emby-server/plugins/ /mnt/iocage/jails/emby-serverdb/plugins/ rm -rf /mnt/iocage/jails/emby-server_2/root/var/db/emby-server/config/ rm -rf /mnt/iocage/jails/emby-server_2/root/var/db/emby-server/data/ rm -rf /mnt/iocage/jails/emby-server_2/root/var/db/emby-server/plugins/ rsync -vrlpogth /mnt/iocage/jails/emby-serverdb/config/ /mnt/iocage/jails/emby-server_2/root/var/db/emby-server/config/ rsync -vrlpogth /mnt/iocage/jails/emby-serverdb/data/ /mnt/iocage/jails/emby-server_2/root/var/db/emby-server/data/ rsync -vrlpogth /mnt/iocage/jails/emby-serverdb/plugins/ /mnt/iocage/jails/emby-server_2/root/var/db/emby-server/plugins/ No luck either, just my regular message "This site can't be reached". There must be something in here which is mucking up the web server?
Luke 42239 Posted February 27, 2019 Posted February 27, 2019 Hello, I used this post and successfully updated. However, i still had issues with ffmpeg and i spotted this thread which shown promise. However the process failed at the "make install clean" which i felt was due to being on freenas 11.1 not 11.2. I upgraded to 11.2-U2 but now emby wont load at the IP address. Ive tried to install a new emby 3.5.3.0 via the plugin GUI i get this error: If i try the above instructions, the portsnap fails: [root@[member="freenas"] ~]# jls JID IP Address Hostname Path 2 emby-server /mnt/iocage/jails/emby-server/root [root@[member="freenas"] ~]# jexec 2 # portsnap fetch extract Looking up portsnap.FreeBSD.org mirrors... none found. Fetching snapshot tag from portsnap.FreeBSD.org... failed. No mirrors remaining, giving up. # I tried a fresh CLI install based upon the emby home page instructions, however when i run sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw i get the message coming back Sorry, user root is not allowed to execute '/usr/sbin/pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw' as root on freenas.stuartjgraham.com. [root@[member="freenas"] ~]# sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi libraw So perhaps my permissions are mucked up somewhere and thats stopping things from working. I only get a few hours a month to work on this due to work and family commitments and i wish i had never upgraded as it was such a simple thing back in October.... Now that we're back in freebsd ports, I would just install from there. Thanks.
makarai 109 Posted February 27, 2019 Posted February 27, 2019 (edited) Now that we're back in freebsd ports, I would just install from there. Thanks. I agree with this. @stuartsjg if you encounter the bridge_cmd error please execute this from shell /bin/sh -c 'export JAILS="$(iocage list -h | cut -f 2)"; for jail in $JAILS; do iocage set vnet_default_interface=auto $jail; done; iocage set vnet_default_interface=auto default' Edited February 27, 2019 by makarai
stuartsjg 2 Posted February 27, 2019 Posted February 27, 2019 Hi - i appreciate your patience with this. I do a bit of C for embedded uProcessors so what some of this means is a mystery to me. I ran the command you suggested and it gave the following error, im not sure if i was supposed to change some of the arguements? "Please provide a valid NIC to be used with vnet Default Property: vnet_default_interface has been updated to auto jail 'default' not found!" I decided to try again with the plugin route, but when i try to install the plug in i get this message: "Install [EFAULT] Exception: RuntimeError: Stopped emby due to VNET failure occured, destroyed emby" If i manually set the IP address then the install does start (initially i just use DHCP for ease then swap out the address for the one i want to use). When i shut down my existing emby installation (so i could check the mount points for setting up the newly installed one) and i got this error on shutting down: RuntimeError Stopped emby-server due to VNET failure Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 542, in start iocage.start() File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1654, in start callback=self.callback File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__ self.__start_jail__() File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 481, in __start_jail__ _callback=self.callback) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit _callback(content, exception) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback raise callback_exception(message) RuntimeError: Stopped emby-server due to VNET failure """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1109, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1046, in _call return await self._call_worker(serviceobj, name, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1073, in _call_worker job, File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1004, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 989, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) RuntimeError: Stopped emby-server due to VNET failure So, i think the command has caused more issues... Any clue as to what went wrong?
stuartsjg 2 Posted February 27, 2019 Posted February 27, 2019 Been working on this a bit more to either fix the install which has all my libraries etc as i want them preserved, or move them over to another jail. Ive tried moving the contents of the ../var/db/emby-server folder over one folder at a time then starting to server to see when it fails to load but that was inconclusive. Ive also created a new jail (both by CLI (and then too, both from freenas shell method and GUI jail creation then jail CLI) and plugin install), copied the emby-server folder over (which breaks the new installs) then tried a few methods to reinstall in a hope the installation process repairs or puts right what the rsync process upsets - it doesn't. - - - - - This is the error i had hoped this thread would fix. 2019-02-27 23:26:22.162 Debug App: CodecValidation: FindVideoDecoder - MediaType: mpeg4, Mode: 0 2019-02-27 23:26:22.167 Debug App: CodecValidation: FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) 2019-02-27 23:26:22.168 Debug App: CodecValidation: FindVideoDecoder - Check successful - selecting 'Automatic software decoder' 2019-02-27 23:26:22.169 Debug App: CodecValidation: FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 0 2019-02-27 23:26:22.173 Error HttpServer: Error processing request *** Error Report *** Version: 4.0.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Feb 7 10:13:31 UTC 2019) Processor count: 12 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.Exception: System.Exception: No video encoder found for 'h264' >>>>>> FindVideoDecoder - MediaType: mpeg4, Mode: 0 Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 0 at Emby.Server.MediaEncoding.Encoder.EncodingHelper.GetVideoEncoder (Emby.Server.MediaEncoding.Encoder.EncodingJobInfo state, MediaBrowser.Model.Configuration.EncodingOptions encodingOptions) [0x0005b] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService.GetCommandLineArguments (System.String outputPath, MediaBrowser.Model.Configuration.EncodingOptions encodingOptions, Emby.Server.MediaEncoding.Api.StreamState state, System.Boolean isEncoding) [0x00014] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetOutputFilePath (Emby.Server.MediaEncoding.Api.StreamState state, MediaBrowser.Model.Configuration.EncodingOptions encodingOptions, System.String outputFileExtension) [0x00016] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.BaseStreamingService+<GetState>d__81.MoveNext () [0x0082b] in <8d3c2eae278a44b89027f6e03c623f02>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService+<GetDynamicSegment>d__14.MoveNext () [0x000ee] in <8d3c2eae278a44b89027f6e03c623f02>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<GetTaskResult>d__3.MoveNext () [0x00081] in <5837600bbe23491d837720283845e3f2>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__14.MoveNext () [0x0023e] in <5837600bbe23491d837720283845e3f2>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__56.MoveNext () [0x00af1] in <5837600bbe23491d837720283845e3f2>:0 Source: mscorlib TargetSite: Void Throw() at Emby.Server.MediaEncoding.Encoder.EncodingHelper.GetVideoEncoder (Emby.Server.MediaEncoding.Encoder.EncodingJobInfo state, MediaBrowser.Model.Configuration.EncodingOptions encodingOptions) [0x0005b] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService.GetCommandLineArguments (System.String outputPath, MediaBrowser.Model.Configuration.EncodingOptions encodingOptions, Emby.Server.MediaEncoding.Api.StreamState state, System.Boolean isEncoding) [0x00014] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetOutputFilePath (Emby.Server.MediaEncoding.Api.StreamState state, MediaBrowser.Model.Configuration.EncodingOptions encodingOptions, System.String outputFileExtension) [0x00016] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.BaseStreamingService+<GetState>d__81.MoveNext () [0x0082b] in <8d3c2eae278a44b89027f6e03c623f02>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService+<GetDynamicSegment>d__14.MoveNext () [0x000ee] in <8d3c2eae278a44b89027f6e03c623f02>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<GetTaskResult>d__3.MoveNext () [0x00081] in <5837600bbe23491d837720283845e3f2>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__14.MoveNext () [0x0023e] in <5837600bbe23491d837720283845e3f2>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__56.MoveNext () [0x00af1] in <5837600bbe23491d837720283845e3f2>:0 I have used this set of commands to upgrade my existing working install to 4.0.2 in the hope the installation may fix the playback issue: root@emby-server:~ # service emby-server stop Stopping emby_server. Waiting for PIDS: 19140. root@emby-server:~ # pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.2.0/emby-server-freebsd_4.0.2.0_amd64.txz [emby-server] Fetching emby-server-freebsd_4.0.2.0_amd64.txz: 0% 120 KiB 122.[emby-server] Fetching emby-server-freebsd_4.0.2.0_amd64.txz: 19% 3 MiB 3.[emby-server] Fetching emby-server-freebsd_4.0.2.0_amd64.txz: 44% 7 MiB 4.[emby-server] Fetching emby-server-freebsd_4.0.2.0_amd64.txz: 65% 11 MiB 3.[emby-server] Fetching emby-server-freebsd_4.0.2.0_amd64.txz: 86% 14 MiB 3.[emby-server] Fetching emby-server-freebsd_4.0.2.0_amd64.txz: 100% 17 MiB 3.5MB/s 00:05 [emby-server] Installing emby-server-4.0.2.0_1... Newer FreeBSD version for package emby-server: To ignore this error set IGNORE_OSVERSION=yes - package: 1102000 - running kernel: 1101001 Allow missmatch now?[Y/n]: package emby-server is already installed, forced install ===> Creating groups. Using existing group 'emby'. ===> Creating users Using existing user 'emby'. [emby-server] Extracting emby-server-4.0.2.0_1: 100% root@emby-server:~ # pw groupmod emby -n emby -g 1101 root@emby-server:~ # pw usermod emby -n emby -u 1101 -g 1101 root@emby-server:~ # chown -R emby:emby /var/db/emby-server sysrc 'emby_server_user=emby' root@emby-server:~ # sysrc 'emby_server_user=emby' emby_server_user: emby -> emby root@emby-server:~ # service emby-server start Starting emby_server. There must be some way to fix the "No video encoder found for 'h264" issue, then i dont need to worry about trying to backup or transfer files over to another jail etc which also appears to fail.
Luke 42239 Posted February 28, 2019 Posted February 28, 2019 The server may think it's missing from the ffmpeg build.
