Very unstable 3.5.3.0-18
I tried it.
The first volume (/volume1/Filme) has worked and it shows me the films below. (Screen1)
The second volume (/volume2/Filme2) didn't work (Screen2). It skips back (Screen3).
I hope I express myself correctly ;-)
Oh I'm very very sorry... Can't explain why this happend. Thanks for your help!
Now the media scan is running.
Hello @@jfk1987
No problem at all. Thanks to you and @@mr_curator (and I'm sure others along the way), we may finally be getting to the bottom this issue; which is being caused by the 'new' image processing library.
Once the media scan completes, can you send the logs over again so I can take a look.
We've been working on this for quite some time, and you can see from the figures I posted back in October last year why it's important: https://emby.media/community/index.php?/topic/52160-improved-image-processing-performance/
Best
- James
Edited by solabc16
sendlogs_Mediastation_synology_evansport_214play_20181122T133010UTC.tgz
Done :-)
Thanks for the logs @@jfk1987, looks much better. Let's touch base again in 24 hours and see how you're getting on.
Best
- James
Everything seems to be going well :-)
Thanks for your help!!!
