bernux 0 Posted November 5, 2018 Posted November 5, 2018 Hello, since maybe friday, I got some problem for video playback. it's working without problem on some device (phone) and failed on other (nvidia shield, chromecast) depending on video type (it seems) When it fails, I can read this in ffmpeg-transcode-*.txt /usr/local/lib/emby-server/lib/libavcodec.so.58: Undefined symbol "x264_bit_depth" if I execute the same command taken from the log file directly in command line, it seems to work, temp file are creating etc etc If i downgrade to 3.5.2 it works as expected. FreeBSD: 11.2 Emby-server: 3.5.3 (from ports)
Luke 42239 Posted November 6, 2018 Posted November 6, 2018 Hi, please see here: https://emby.media/community/index.php?/topic/64833-playback-does-not-start/ Thanks.
bernux 0 Posted November 6, 2018 Author Posted November 6, 2018 I saw it but the error described is not the same (the other post is about libiconv.so.3) and there are no mention on working playback on some device. That's why I opened this one, but if for you it's linked I can close it Thanks Hi, please see here: https://emby.media/community/index.php?/topic/64833-playback-does-not-start/ Thanks ibiconv.so.3
labatt50@hotmail.com 0 Posted November 9, 2018 Posted November 9, 2018 Hi, I have the playback problem. Tried to update to version 3.6.0.61 on Freenas 11.2 following the instruction linked in this topic. Nothing work. I'm new to Freebsd and english isnt my first language, so I may misunderstood things. So if someone can explain step by step(like to explain to your grand mother) how to have a usefull Emby server, I'll appreciate. I'd install it using the plugin section in Freenas because the instruction here https://emby.media/community/index.php?/topic/60971-new-freenas-package-for-testing/ wasnt working for me. It worked once when I'd remove vnet=on but get the same playback error. Tried many way to install Emby, none was working. Here is the log that seem to refer to the problem. The video file is just an video made with my cell phone. 2018-11-08 23:22:31.076Application version: 3.6.0.61http://192.168.1.21:8096/emby/videos/6229/live.m3u8?DeviceId=e104f506b320c80d30418f17117c7b48353ef4e3&MediaSourceId=8f5c60e7e264f823c3a2b7c8d3362719&VideoCodec=h264&AudioCodec=aac&VideoBitrate=59808000&AudioBitrate=192000&PlaySessionId=d74cb0a469df49ba9f9007a34f93ad99&api_key=6268e206854348c1991de43ee6db7e96&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&TranscodeReasons=VideoCodecNotSupported{"Protocol":"File","Id":"8f5c60e7e264f823c3a2b7c8d3362719","Path":"/media/Video maison/20131221_124343.mp4","Type":"Default","Container":"mp4","Size":0,"Name":"20131221_124343","IsRemote":false,"ReadAtNativeFramerate":false,"DiscardCorruptPts":false,"FillWallClockDts":false,"IgnoreDts":false,"IgnoreIndex":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[],"Formats":[],"RequiredHttpHeaders":{}}User policy for emby_DB: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True/usr/local/opt/emby-server/bin/ffmpeg -f mp4 -i file:"/media/Video maison/20131221_124343.mp4" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 59808000 -bufsize 119616000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/2e6e5afe0b39a3015c9d8999a1ef16e3/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/db/emby-server/transcoding-temp/2e6e5afe0b39a3015c9d8999a1ef16e3.m3u8" -y "/var/db/emby-server/transcoding-temp/2e6e5afe0b39a3015c9d8999a1ef16e3%d.ts"Shared object "libx264.so.152" not found, required by "libavcodec.so.58" Thanks for the help. I hope I havent paid my lifetime premiere key for nothing best regards
Luke 42239 Posted November 9, 2018 Posted November 9, 2018 We are looking into this issue, thanks guys.
bernux 0 Posted November 9, 2018 Author Posted November 9, 2018 Hi, I have the playback problem. Tried to update to version 3.6.0.61 on Freenas 11.2 following the instruction linked in this topic. Nothing work. I'm new to Freebsd and english isnt my first language, so I may misunderstood things. So if someone can explain step by step(like to explain to your grand mother) how to have a usefull Emby server, I'll appreciate. I'd install it using the plugin section in Freenas because the instruction here https://emby.media/community/index.php?/topic/60971-new-freenas-package-for-testing/ wasnt working for me. It worked once when I'd remove vnet=on but get the same playback error. Tried many way to install Emby, none was working. Here is the log that seem to refer to the problem. The video file is just an video made with my cell phone. Thanks for the help. I hope I havent paid my lifetime premiere key for nothing best regards Can you use portdowngrade in freenas ?If yes, you could force installation of earlier version. Envoyé de mon SM-G935W8 en utilisant Tapatalk
Luke 42239 Posted November 11, 2018 Posted November 11, 2018 Latest beta 3.6.0.63 has updated libraries to hopefully resolve this for everyone. Thanks.
makarai 109 Posted November 11, 2018 Posted November 11, 2018 i tested it works like a charm, update as well as fresh install. Thanks @@Luke https://emby.media/community/index.php?/topic/60971-new-freenas-package-for-testing/page-7&do=findComment&comment=619899
labatt50@hotmail.com 0 Posted November 12, 2018 Posted November 12, 2018 Hi, make a fresh install of Emby in Freenas, minus the vnet=on option because it's not working when added in the command line. Same trouble, video dont start. The only difference that time no ffmpeg-transcode-*.txt fil is create, only a embyserver.txt. Some tips?
Luke 42239 Posted November 12, 2018 Posted November 12, 2018 As always, how to report a problem. Thanks.
makarai 109 Posted November 12, 2018 Posted November 12, 2018 Hi, make a fresh install of Emby in Freenas, minus the vnet=on option because it's not working when added in the command line. Same trouble, video dont start. The only difference that time no ffmpeg-transcode-*.txt fil is create, only a embyserver.txt. Some tips? When you use the vnet option which interface did you select?
labatt50@hotmail.com 0 Posted November 13, 2018 Posted November 13, 2018 Hi, thanks for the reply @@Luke and for the link about the rules. I'd attached the log tho this post. Let me know i I need to start a new thread. @@makarai : I'd tried to enable VNET in the jail edit section. I'd choose the vnet0 at the ipv4 interface and that does nothing unless that my Ubiquiti Unifi recognize my freenas box ad emby server with the good ip. But I still have my trouble. Best regards and thanks for your time embyserver.txt
makarai 109 Posted November 14, 2018 Posted November 14, 2018 (edited) Hi, thanks for the reply @@Luke and for the link about the rules. I'd attached the log tho this post. Let me know i I need to start a new thread. @@makarai : I'd tried to enable VNET in the jail edit section. I'd choose the vnet0 at the ipv4 interface and that does nothing unless that my Ubiquiti Unifi recognize my freenas box ad emby server with the good ip. But I still have my trouble. Best regards and thanks for your time In order to check if vnet works or not i would recommend to start a new jail the following way. cd /tmp wget https://raw.githubusercontent.com/ma-karai/iocage-plugin-emby-beta/master/emby-server-beta.json iocage fetch -P dhcp=on vnet=on bpf=yes -n emby-server-beta.json --branch 'master' This creates a new emby jails with the name emby-server-beta63 in DHCP mode with a full network stack. If this works nicely your startparameter for the original jail are not complete. This should be the easiest way to install. you can give it a try, and report back. Edited April 26, 2019 by makarai
labatt50@hotmail.com 0 Posted November 15, 2018 Posted November 15, 2018 @@makarai your way had work and the playback seem fine. But as I dont want a DHCP setting and that I dont understand what you mean by "full network stack", could you explain me what are all the difference between your way and the "official" way that I tried? I'm nes in Freebsd but I like to understand what I made wrong. If it's too much explanation, I'll ask you only one more thing, how to put that jail in static IP mode. thanks for the help and time best regards
makarai 109 Posted November 15, 2018 Posted November 15, 2018 First the easy part! Now that you succsessful created a jail that works, you stop it and hit the edit button and switch it from dhcp to an ip, make sure you select the same interface that the dhcp setup used. (most likely vnet0 or similar) If you post some screenshots i can help you along. I have nothing to do with networks but you can readabout it in the very outdated iocage documentation. Just for starters a full network stack means you have certain featuers now active on this virtual interface, one example that i thought is important is that you can be part of a multicast group. If you want livetv integrated you need it.
