Guest Posted November 3, 2018 Posted November 3, 2018 I have re-installed Emby server using new plugin mechanism in FreeNAS 11.2 RC1. I recreated my library (adding folders) from scratch. I can see the media and movie posters just fine on the web interface. However, when I start to playback any videos, they never starts. This happen both on Chrome browser and Android app. I have ran Emby server on this server many years, including reinstallig a few time. This has never happened before. Log
Luke 42239 Posted November 3, 2018 Posted November 3, 2018 Hi, is your system configured for quarterly packages or for latest packages?
Guest Posted November 4, 2018 Posted November 4, 2018 Hi, is your system configured for quarterly packages or for latest packages?Hi Luke, where can I find that out? I looked everywhere in the server dashboard. All I can tell is I am running version 3.5.3.0 Sent from my Pixel 2 XL using Tapatalk
MRobi 161 Posted November 4, 2018 Posted November 4, 2018 Hi Luke, where can I find that out? I looked everywhere in the server dashboard. All I can tell is I am running version 3.5.3.0 Sent from my Pixel 2 XL using Tapatalk Take a look at /etc/pkg/FreeBSD.conf you'll see from the URL in that file if you're set to latest or quarterly
Guest Posted November 4, 2018 Posted November 4, 2018 Hi, is your system configured for quarterly packages or for latest packages?On FreeNAS host, it is set to latest. In the Emby iocage jail, it is set to quarterly. Sent from my Pixel 2 XL using Tapatalk
Guest Posted November 4, 2018 Posted November 4, 2018 Take a look at /etc/pkg/FreeBSD.conf you'll see from the URL in that file if you're set to latest or quarterlyThanks, @@MRobi ! Sent from my Pixel 2 XL using Tapatalk
GUNNERDOG 0 Posted November 4, 2018 Posted November 4, 2018 @@chrisada i am having the same issue. Did you find a fix?
riccote 2 Posted November 4, 2018 Posted November 4, 2018 (edited) I had this issue before and this was the fix. I am also having the same problem now. Old ffmpeg log attached. 18352 Legendary Posted 02 January 2017 - 02:23 PM @riccote I see similar errors all the time when I choose to rebuild ffmpeg for the plugin. The plugin should have all libraries in /usr/pbi/emby-amd64/lib but since this is not normally searched they need to be linked to a standard location (/usr/local/lib). The 'external-links' file does that during the PBI build process. https://github.com/j.../external-links I see that my plugin jail came with the 'libiconv' package already installed, so that is probably why I didn't need to add that link for the plugin's ffmpeg to work. Either this user deleted packages from their plugin jail, or the plugin jail has been updated and no longer comes with this package. A workaround is either to install libiconv, or to run.. ln -s /usr/pbi/emby-amd64/lib/libiconv.so.3 /usr/local/lib ffmpeg-transcode-ebbb850c-222f-4bd8-9ef9-883099f148f1.txt Edited November 4, 2018 by riccote
GUNNERDOG 0 Posted November 4, 2018 Posted November 4, 2018 hmm... running ln -s /usr/pbi/emby-amd64/lib/libiconv.so.3 /usr/local/lib did not fix the issue for me... how can in install "libiconv"?
riccote 2 Posted November 4, 2018 Posted November 4, 2018 hmm... running ln -s /usr/pbi/emby-amd64/lib/libiconv.so.3 /usr/local/lib did not fix the issue for me... how can in install "libiconv"? That's not going to work now.
Luke 42239 Posted November 4, 2018 Posted November 4, 2018 We've submitted a patch to freebsd ports: https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=232966 Hopefully that is merged quickly. thanks guys.
skullitor13 1 Posted November 8, 2018 Posted November 8, 2018 Is there a manual way to fix this in the mean time until the plugin is fixed?
Luke 42239 Posted November 8, 2018 Posted November 8, 2018 You can always try our new package that we have for testing: https://emby.media/community/index.php?/topic/60728-new-freebsd-package-for-testing/
skullitor13 1 Posted November 9, 2018 Posted November 9, 2018 So I think I might be missing something, or maybe I have another problem I installed version Version 3.6.0.61 by running the following command pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.6.0.61/emby-server-freebsd_3.6.0.61_amd64.txz But I still get this error in the logs when I try and watch live tv. *** Error Report *** Version: 3.6.0.61 Command line: /usr/local/opt/emby-server/system/EmbyServer.exe -os freebsd -ffmpeg /usr/local/opt/emby-server/bin/ffmpeg -ffprobe /usr/local/opt/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Nov 1 07:23:24 UTC 2018) Processor count: 16 Program data path: /var/db/emby-server Application directory: /usr/local/opt/emby-server/system System.Exception: System.Exception: Error running ffprobe for "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/9b830176a1334ac4ad1498b648b7d85e/stream.ts" - Shared object "libx264.so.152" not found, required by "libavcodec.so.58"
makarai 109 Posted November 9, 2018 Posted November 9, 2018 So I think I might be missing something, or maybe I have another problem I installed version Version 3.6.0.61 by running the following command pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.6.0.61/emby-server-freebsd_3.6.0.61_amd64.txz But I still get this error in the logs when I try and watch live tv. *** Error Report *** Version: 3.6.0.61 Command line: /usr/local/opt/emby-server/system/EmbyServer.exe -os freebsd -ffmpeg /usr/local/opt/emby-server/bin/ffmpeg -ffprobe /usr/local/opt/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Nov 1 07:23:24 UTC 2018) Processor count: 16 Program data path: /var/db/emby-server Application directory: /usr/local/opt/emby-server/system System.Exception: System.Exception: Error running ffprobe for "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/9b830176a1334ac4ad1498b648b7d85e/stream.ts" - Shared object "libx264.so.152" not found, required by "libavcodec.so.58" roll back to 60, 61 has included outdated libraries pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.6.0.60/emby-server-freebsd_3.6.0.60_amd64.txz cheers
FreeBSD_Lover 14 Posted November 9, 2018 Posted November 9, 2018 Take a look at /etc/pkg/FreeBSD.conf you'll see from the URL in that file if you're set to latest or quarterly True, but some of us run our own package respository, like Synth, and that configuration would seem to trump /etc/pkg/FreeBSD.conf. On my machine: $ less /etc/pkg/FreeBSD.conf # $FreeBSD: releng/11.2/etc/pkg/FreeBSD.conf 333474 2018-05-10 23:58:33Z gjb $ # # To disable this repository, instead of modifying or removing this file, # create a /usr/local/etc/pkg/repos/FreeBSD.conf file: # # mkdir -p /usr/local/etc/pkg/repos # echo "FreeBSD: { enabled: no }" > /usr/local/etc/pkg/repos/FreeBSD.conf # FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/quarterly", mirror_type: "srv", signature_type: "fingerprints", fingerprints: "/usr/share/keys/pkg", enabled: yes } But here we see otherwise, that its set to latest. pkg -vv (omitted a bunch of output) Repositories: Synth: { url : "file:///var/synth/live_packages", enabled : yes, priority : 0 } FreeBSD: { url : "pkg+http://pkg.FreeBSD.org/FreeBSD:11:amd64/latest", enabled : yes, priority : 0, mirror_type : "SRV", signature_type : "FINGERPRINTS", fingerprints : "/usr/share/keys/pkg" }
skullitor13 1 Posted November 10, 2018 Posted November 10, 2018 That fixed it makarai! roll back to 60, 61 has included outdated libraries pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.6.0.60/emby-server-freebsd_3.6.0.60_amd64.txz cheers
FreeBSD_Lover 14 Posted November 10, 2018 Posted November 10, 2018 I'm gonna wait until its posted in the FreeBSD ports tree.
Guest Posted November 10, 2018 Posted November 10, 2018 That fixed it makarai! Yup. Rolling back to 3.6.0.60 fixed it for me as well. Thanks, @@makarai !
Luke 42239 Posted November 11, 2018 Posted November 11, 2018 Latest beta 3.6.0.63 has updated libraries to hopefully resolve this for everyone. Thanks.
makarai 109 Posted November 12, 2018 Posted November 12, 2018 Yes updated to 63, everything runs great
