asofakinghigh 0 Posted October 20, 2018 Posted October 20, 2018 Hi Guys, I know this is a bit of an old topic but I am having trouble installing the emby package on my DS213j. No matter what I do it doesn't show up. I read the instructions on the main website but I am still having trouble getting the package to install. Can someone point me in the right direction or help me with this?
Luke 42241 Posted October 21, 2018 Posted October 21, 2018 Hi there, can you tell us what happens when you try to install? thanks !
asofakinghigh 0 Posted October 22, 2018 Author Posted October 22, 2018 Hi there, can you tell us what happens when you try to install? thanks ! when following the steps mentioned on https://emby.media/nas-server.html I cant seem to get to step 3. The source will add but the package wont show up in the community tab.
Luke 42241 Posted October 22, 2018 Posted October 22, 2018 Ok, we'll see what @@solabc16 thinks. Thanks !
solabc16 379 Posted October 22, 2018 Posted October 22, 2018 Hello @@asofakinghigh Everything appears ok from this side, we have plenty of using installing/updating 'Armada370' based systems. See https://www.synology.com/en-uk/knowledgebase/DSM/tutorial/General/What_kind_of_CPU_does_my_NAS_have for model/pkgarch lookup. Is your machine able to connect reliably to the Internet and has working name resolution (DNS)? Best - James
asofakinghigh 0 Posted October 22, 2018 Author Posted October 22, 2018 Hello @@asofakinghigh Everything appears ok from this side, we have plenty of using installing/updating 'Armada370' based systems. See https://www.synology.com/en-uk/knowledgebase/DSM/tutorial/General/What_kind_of_CPU_does_my_NAS_have for model/pkgarch lookup. Is your machine able to connect reliably to the Internet and has working name resolution (DNS)? Best - James I can connect to the net with no problem. I’m not sure how to configure the DNS for emby. How would you do this?
solabc16 379 Posted October 23, 2018 Posted October 23, 2018 (edited) Hello @@asofakinghigh If you can SSH to your machine, you could try and ping synology.emby.media - that should give a good idea as to whether you're system is configured ok. This isn't Emby specific, but problems with connectivity are the most likely cause for not seeing the package appear in Package Center. e.g. login as: admin admin@192.168.236.200's password: admin@JFK:~$ admin@JFK:~$ sudo -i Password: root@JFK:~# ping synology.emby.media PING synology.emby.media (67.205.150.221) 56(84) bytes of data. 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=1 ttl=51 time=84.8 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=2 ttl=51 time=84.2 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=3 ttl=51 time=85.1 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=4 ttl=51 time=84.4 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=5 ttl=51 time=85.1 ms ^C --- synology.emby.media ping statistics --- 5 packets transmitted, 5 received, 0% packet loss, time 4005ms rtt min/avg/max/mdev = 84.271/84.754/85.154/0.442 ms root@JFK:~# Best - James Edited October 23, 2018 by solabc16
asofakinghigh 0 Posted October 26, 2018 Author Posted October 26, 2018 Hello @@asofakinghigh If you can SSH to your machine, you could try and ping synology.emby.media - that should give a good idea as to whether you're system is configured ok. This isn't Emby specific, but problems with connectivity are the most likely cause for not seeing the package appear in Package Center. e.g. login as: admin admin@192.168.236.200's password: admin@JFK:~$ admin@JFK:~$ sudo -i Password: root@JFK:~# ping synology.emby.media PING synology.emby.media (67.205.150.221) 56(84) bytes of data. 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=1 ttl=51 time=84.8 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=2 ttl=51 time=84.2 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=3 ttl=51 time=85.1 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=4 ttl=51 time=84.4 ms 64 bytes from synology.emby.media (67.205.150.221): icmp_seq=5 ttl=51 time=85.1 ms ^C --- synology.emby.media ping statistics --- 5 packets transmitted, 5 received, 0% packet loss, time 4005ms rtt min/avg/max/mdev = 84.271/84.754/85.154/0.442 ms root@JFK:~# Best - James I am a bit confused on how to SHH to my machine. Is there a tutorial on how to do this? If so where can I find it? Also do I need putty?
solabc16 379 Posted October 27, 2018 Posted October 27, 2018 (edited) Hello @@asofakinghigh Just to be sure, can you confirm your system is a DS213j, not a DS213+. To enable SSH on your Synology system : DSM -> Control Panel -> Terminal & SNMP -> Enable SSH Service For details on how to connect, see this Synology article : https://www.synology.com/en-global/knowledgebase/DSM/tutorial/General/How_to_login_to_DSM_with_root_permission_via_SSH_Telnet If you don't normally or are not comfortable with having this enabled, then I suggest disabling again once you've run the above. Best - James Edited October 27, 2018 by solabc16
