Kodi 18 Beta 1 - 3.1.18a No sync
Angelblue05
I'll just assume your pm is faulty for some reason. Can you try this build. I'm trying to see if the import order fixes it. For some reason, python is not seeing the objects from temp/emby and it's strange to me.
Provide a new log.
plugin.video.emby-3.1.20a.zip
Here is the log:
BTW my PM seems to be working now.
Edited by nhsman
Angelblue05
Made no difference. Alas I have to call it a night. I will do some research. So far you are the only one with this issue. It's like python is not behaving correctly. Maybe a permission issue? I don't understand it yet. We'll probably have to go through trial and error with this.
  • Like 1
The custom build you provided allowed my initial sync to complete. Going to watch a few episodes to see if it stays in sync.
  • Like 1
@@Angelblue05
I think I have it sorted. I had to delete Kodi user folder and start from scratch. Once recreated I have installed addon from repo and it seems to work and sync just fine.
Thanks for your time and help.
  • Like 1
Angelblue05
@@Angelblue05
Thanks for keeping me posted. Glad you resolved it! It must have been some conflict in your environment. (Thank god because I did a lot of reading and could not figure out what could cause python to ignore a specified folder) Edited by Angelblue05
hi
im on 3.1.21 on kodi 18 having same issue as above tired 14,a 17a and still having issue
reset database
also emby is verrrry slow
Guest
