Small Patch
When starting Kodi on my Windows 10 computer I get a message saying  "Kodi will now restart to apply a small patch for your Kodi version"
Kodi then closes and when I restart I just get the message again
Any ideas?
LOG.zip
Edited by Glyde62
  • Like 1
Log is required in this case.
Added
Sry, wrong one. Kodi log.
Noel Grassy
I'm getting the same thing on all of my android devices. Restart the same message. The app never updates. Fine on my windows 10 machine though.
Mine was the opposite, Updated fine on my Shield my windows 10 machine no go
Had one problem with shield though, One of my collections (My tv Shows) was showing empty
Had to end up deleting it  and re adding it on Emby Dashboard
  • Like 1
Noel Grassy
That is strange. It pops up so fast on mine I can't capture a log. The only option is ok and the n it shuts off.
Angelblue05
I think I found a solution around the problem. Give me a few minutes to put things together. I'll make you a custom build to test.
Angelblue05
Does it sync now? Sorry, I want to push the build because there are other fixes :)
Install this version, let me know if the issue goes away.
That seems to have done the trick, Installed and did database reset and all is back to normal
Thanks
  • Like 1
Yes all good
  • Like 1
Angelblue05
3.1.07a is on the way (or as usual, available now via side loading).
Thanks for helping get to the bottom of this.
No problem...…….Happy to get my copy working again
  • Like 1
rterblanche
Might also be helpful to ask if you want to reboot now and apply patch. Mine also doing it but can't get into add-ons quickly enough to disable emby
Sent from my Pixel 2 XL using Tapatalk
Angelblue05
Yep, I'm sorry about that. :( That's why I stated alpha/beta. So you are in a position to help test these kinds of bugs.
I've already put safeguards in place since then. The restart has gone (it's only needed the first time).
Are you able to access your Kodi folder?
Edited by Angelblue05
rterblanche
Where can I download 3.1.07a to side load
rterblanche
No problem. Like testing betas.
Disabled for now. So can get in to edit something or where can I download 3.1.07a package.
  • Like 1
rterblanche
Thanks. Busy applying/testing
  • Like 1
Noticed another problem,After watching a show it's not offering to delete.
Checked settings and that option is on.
Sent from my HTC_M10h using Tapatalk
Guest
