emveepee 133 Posted April 8, 2014 Posted April 8, 2014 It might help if you also sent the web.log* files from NextPVR since the might tell more info on what is being returned. Martin
bluemonkey07 590 Posted April 9, 2014 Posted April 9, 2014 https://www.dropbox.com/s/mj7trczchglhuvq/server-63532583997.log
bluemonkey07 590 Posted April 10, 2014 Posted April 10, 2014 Nm that issue seems to have been sorted out. I don't know if what I did fixed it but I was playing around with nextpvr settings and merged all channels with the same name and restarted the machine. Now my only issue is watching live tv
muehlberger 4 Posted April 11, 2014 Posted April 11, 2014 Hi to all, recording with NextPVR works like a charme, unfortunately LiveTV results in an error in the web.log: 2014-04-11 16:58:23.904 [ERROR][33] Unexpected error streaming channel: System.Net.Sockets.SocketException (0x80004005): Eine vorhandene Verbindung wurde vom Remotehost geschlossen bei System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) bei NShared.Streaming.StreamingHelper.StreamNative(Socket conn, Dictionary`2 parameters) any help would be appreciated. BTW - Streaming with NextPVR webinterface works on Firefox! -- muehlberger
WWWestern 94 Posted April 16, 2014 Posted April 16, 2014 All the time and when viewing or recording .ts transcoded to .webm. How can I get rid of transcoding?
Scot 27 Posted April 16, 2014 Posted April 16, 2014 Hi Luke, Any idea 'when' Live TV will be enabled/working in MBT? Even maybe a likely release for a Beta? I would happy to be a Alpha tester....just wondering if I should check back weekly, monthly etc. As soon as MBT has Live TV support and the iPad version has been released (even iPad version without Live TV would be okay) then I would consider the full swap away from XBMC/Plex and all the crap that I do to make my system functional. Thanks... -SM
fantaxp7 191 Posted April 18, 2014 Posted April 18, 2014 Has anyone setup hdhomerun prime with this yet? For un-encrypted channels of course. I have never used nextpvr and I am giving it a shot. Seems straightforward but I can't seem to get it going. Thanks
Scot 27 Posted April 18, 2014 Posted April 18, 2014 (edited) Yes, it works with a HDHomeRun...basically anything that works with NextPVR will be fine... What I would like to know is how we can actually enjoy Live TV on our "TV's" not via a web browser....maybe even a guesstimate on a Alpha Release of MBT that supports Live TV? Edited April 18, 2014 by Scot
KRA 39 Posted April 18, 2014 Posted April 18, 2014 Scot, I guess it depends on your setup. But I use web as a remote to watch live- TV in MBT Sent fra min LG-D802 via Tapatalk
fantaxp7 191 Posted April 18, 2014 Posted April 18, 2014 I think I have it setup correctly now, I just get a black screen though when attempting to view channels in nextpvr. I think this is now a codec issue.
paulcdb 5 Posted April 18, 2014 Posted April 18, 2014 I think I have it setup correctly now, I just get a black screen though when attempting to view channels in nextpvr. I think this is now a codec issue. I had this with HD channels but changing the H.264 video codec to "Microsoft DTV/DVD Video Decoder" fixed it in NextPVR. Not sure if it'll fix it in the web client as i'm still trying to get that side to work. This is the one feature i've been waiting for though and with the speed updates come i'm sure it won't be long before it's running like a dream.
Scot 27 Posted April 20, 2014 Posted April 20, 2014 KRA, I'd rather a simple solution that everything is in on the one interface (Live TV, Movies, TV Series, Photos etc.)...not everyone in the family has smart phones or tablets/iPad's etc.... The reason I would like to move away from Plex is having the above all in one interface with MBT....that's what I am hanging out for before making a change....
KRA 39 Posted April 20, 2014 Posted April 20, 2014 Scot, I was just pointing out that you can actually play live-tv in MBT, in case you didn't know. I guess the WAF is low, but imo the WAF is terrible in MBT anyway. I've started out with mythtv, then mediaportal, then xbmc, and when it comes to eyecandy and features it's allways been a step up, but when it comes to usability and live-tv support it's been one step down each time. And IMHO MBT is even worse, I know it's alpha state, but I fear eyecandy and cool factor takes focus over usability in development. That's why I'm trying to move along to thin/dump players that I can control remotely.
Spaceboy 2573 Posted April 26, 2014 Posted April 26, 2014 We are all desperate for live tv in MBT ;o) I can't wait, using wmc at the moment which is the gold standard for live tv but there are issues Sent from my iPad using Tapatalk
Luke 42239 Posted January 5, 2018 Author Posted January 5, 2018 We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge No plugin required. Thanks !
