quakebox 0 Posted August 25, 2018 Posted August 25, 2018 Hello I managed to install NOOB lite and set eveything to run Emby but I can't seem to get to the folders each time emby tells me The path could not be found. Please ensure the path is valid and try again. please help I tried to set chmod permissions to emby user at the emby group with no luck, I really appreciate if you write the commands as I need some help in the Linux arena too. Thanks you
quakebox 0 Posted August 25, 2018 Author Posted August 25, 2018 (edited) I installed emby by following the instructions for Debian on the site wget the link then dpkg install then started the server I mounted the external HDD I can access it in root but still can't find any file in emby I need to understand permissions more as I don't really right now but help in giving exactly what is needed to 1-install properly 2-setup external HDD 3-point to a folder to the HDD 4-access my emby library via the Internet Edited August 25, 2018 by quakebox
Luke 42239 Posted August 29, 2018 Posted August 29, 2018 hi @@quakebox, i would suggest taking a look at this thread because there was a similar question: https://emby.media/community/index.php?/topic/62008-centos-unable-to-create-folder-path/ Please let us know if this helps. Thanks !
