embytal 3 Posted August 21, 2018 Posted August 21, 2018 (edited) Hi all, I have installed 3.6.0.2 using the recommended method here https://emby.media/freebsd-server.html in a jail using iocage on 11.2-RELEASE. I pull the latest packages in the jail before installing the recommended list of packages. Then I finally install the emby-server one from github. What I am not sure to understand is why I get the following: root@emby:~ # /usr/local/opt/emby-server/bin/ffmpeg Shared object "libavdevice.so.58" not found, required by "ffmpeg" root@emby:~ # /usr/local/opt/emby-server/bin/ffprobe Shared object "libavdevice.so.58" not found, required by "ffprobe" root@emby:~ # ls -lai /usr/local/opt/emby-server/bin/ffmpeg 122204 -r-xr-xr-x 1 root wheel 256720 Jul 17 13:33 /usr/local/opt/emby-server/bin/ffmpeg root@emby:~ # ls -lai /usr/local/opt/emby-server/lib/libavdevice.so* 122213 lrwxr-xr-x 1 root wheel 23 Jul 17 13:32 /usr/local/opt/emby-server/lib/libavdevice.so -> libavdevice.so.58.3.100 122214 lrwxr-xr-x 1 root wheel 23 Jul 17 13:32 /usr/local/opt/emby-server/lib/libavdevice.so.58 -> libavdevice.so.58.3.100 122215 -rw-r--r-- 1 root wheel 68944 Jul 17 13:33 /usr/local/opt/emby-server/lib/libavdevice.so.58.3.100 I ended finding this as I got the following error message during library scanning on the first run on all files, mkv, avi etc... 2018-08-20 21:18:31.282 Error App: Error in ffprobe *** Error Report *** Version: 3.6.0.2 Command line: /usr/local/opt/emby-server/system/EmbyServer.exe -os freebsd -ffmpeg /usr/local/opt/emby-server/bin/ffmpeg -ffprobe /usr/local/opt/emby-server/bin/ffprobe -programdata /var/db/emby-server -restartexitcode 3 -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.2.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.47 (5.10.1.47 Thu Aug 16 09:13:16 UTC 2018) Processor count: 16 Program data path: /var/db/emby-server Application directory: /usr/local/opt/emby-server/system System.Exception: ffprobe failed for file:"/mnt/Media/Movies/movie.avi" - streams and format are both null. at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x001d4] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x0036f] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo+<ProbeVideo>d__16`1[T].MoveNext () [0x00170] in <303fb07acaa24c3badedfc98f3b86825>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.Manager.MetadataService`2+<RunCustomProvider>d__39[TItemType,TIdType].MoveNext () [0x000d9] in <303fb07acaa24c3badedfc98f3b86825>:0 System.Exception at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x001d4] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x0036f] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo+<ProbeVideo>d__16`1[T].MoveNext () [0x00170] in <303fb07acaa24c3badedfc98f3b86825>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.Manager.MetadataService`2+<RunCustomProvider>d__39[TItemType,TIdType].MoveNext () [0x000d9] in <303fb07acaa24c3badedfc98f3b86825>:0 And similar issue while trying to play a movie: 018-08-20 21:42:16.331 Error HttpServer: Error processing request *** Error Report *** Version: 3.6.0.2 Command line: /usr/local/opt/emby-server/system/EmbyServer.exe -os freebsd -ffmpeg /usr/local/opt/emby-server/bin/ffmpeg -ffprobe /usr/local/opt/emby-server/bin/ffprobe -programdata /var/db/emby-server -restartexitcode 3 -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.2.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.47 (5.10.1.47 Thu Aug 16 09:13:16 UTC 2018) Processor count: 16 Program data path: /var/db/emby-server Application directory: /usr/local/opt/emby-server/system System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService+<StartFfMpeg>d__76.MoveNext () [0x007c4] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService+<ProcessRequest>d__5.MoveNext () [0x0023c] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<GetTaskResult>d__3.MoveNext () [0x00081] in <fc63de2bb724454ebfdbc0c7f7e39a46>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__13.MoveNext () [0x001c2] in <fc63de2bb724454ebfdbc0c7f7e39a46>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__56.MoveNext () [0x009f2] in <fc63de2bb724454ebfdbc0c7f7e39a46>:0 System.Exception at Emby.Server.MediaEncoding.Api.BaseStreamingService+<StartFfMpeg>d__76.MoveNext () [0x007c4] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService+<ProcessRequest>d__5.MoveNext () [0x0023c] in <007474d957df47adb99af6c19f1cc163>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<GetTaskResult>d__3.MoveNext () [0x00081] in <fc63de2bb724454ebfdbc0c7f7e39a46>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__13.MoveNext () [0x001c2] in <fc63de2bb724454ebfdbc0c7f7e39a46>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__56.MoveNext () [0x009f2] in <fc63de2bb724454ebfdbc0c7f7e39a46>:0 Let me know if I have missed something obvious somewhere or if you need more information - I am not sure if this is expected as I know emby uses mono but I haven't got much experience troubleshooting such a setup. Edited August 21, 2018 by embytal
Luke 42239 Posted August 21, 2018 Posted August 21, 2018 Did you run the command to install the dependencies?
embytal 3 Posted August 21, 2018 Author Posted August 21, 2018 I ran this according to the installation guide on the emby website for FreeBSD sudo pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi Then ran: pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.6.0.2/emby-server-freebsd_3.6.0.2_amd64.txz Here is the list of what is installed: root@emby:~ # pkg info ca_root_nss-3.38 Root certificate bundle from the Mozilla Project cairo-1.14.8_2,2 Vector graphics library with cross-device output support cmocka-1.1.1_1 Unit testing framework for C with support for mock objects emby-server-3.6.0.2_1 Emby Server is a personal media server with apps on just about every device expat-2.2.5 XML 1.0 parser written in C fontconfig-2.12.6,1 XML-based font configuration API for X Windows freetype2-2.9.1 Free and portable TrueType font rendering engine fribidi-0.19.7 Free Implementation of the Unicode Bidirectional Algorithm gamin-0.1.10_9 File and directory monitoring system gettext-runtime-0.19.8.1_1 GNU gettext runtime libraries and programs giflib-5.1.4 Tools and library routines for working with GIF images glib-2.50.3_5,1 Some useful routines of C programming (current stable version) gmp-6.1.2 Free library for arbitrary precision arithmetic gnutls-3.5.19 GNU Transport Layer Security library graphite2-1.3.11 Rendering capabilities for complex non-Roman writing systems harfbuzz-1.8.8 OpenType text shaping engine iconv-2.0_4 Charset conversion library and utilities indexinfo-0.3.1 Utility to regenerate the GNU info page index jansson-2.11 C library for encoding, decoding, and manipulating JSON data jbigkit-2.1_1 Lossless compression for bi-level images such as scanned pages, faxes jpeg-turbo-2.0.0 SIMD-accelerated JPEG codec which replaces libjpeg lcms2-2.9 Accurate, fast, and small-footprint color management engine libX11-1.6.5_1,1 X11 library libXScrnSaver-1.2.3_1 The XScrnSaver library libXau-1.0.8_4 Authentication Protocol library for X11 libXdamage-1.1.4_4 X Damage extension library libXdmcp-1.1.2_1 X Display Manager Control Protocol library libXext-1.3.3_2,1 X11 Extension library libXfixes-5.0.3_1 X Fixes extension library libXft-2.3.2_2 Client-sided font API for X applications libXrender-0.9.10_1 X Render extension library libXxf86vm-1.1.4_2 X Vidmode Extension libarchive-3.3.2,1 Library to create and read several streaming archive formats libass-0.14.0 Portable ASS/SSA subtitle renderer libdrm-2.4.93,1 Userspace interface to kernel Direct Rendering Module services libffi-3.2.1_2 Foreign Function Interface libiconv-1.14_11 Character set conversion library libidn2-2.0.5 Implementation of IDNA2008 internationalized domain names libinotify-20180201 Kevent based inotify compatible library liblz4-1.8.2,1 LZ4 compression library, lossless and very fast libogg-1.3.3,4 Ogg bitstream library libpciaccess-0.13.5 Generic PCI access library libpthread-stubs-0.4 This library provides weak aliases for pthread functions libsunacl-1.0.1 Wrapper providing SunOS NFSv4 ACL API libtasn1-4.13 ASN.1 structure parser library libtheora-1.1.1_7 Theora video codec for the Ogg multimedia streaming system libunicode-0.4_11 Library for manipulating Unicode characters and strings libunistring-0.9.10 Unicode string library libunwind-20170615 Generic stack unwinding library libva-2.2.0_1 VAAPI wrapper and dummy driver libvorbis-1.3.6,3 Audio compression codec library libx264-0.155.2917 H.264/MPEG-4 AVC Video Encoding (Library) libxcb-1.13 The X protocol C-language Binding (XCB) library libxml2-2.9.7 XML parser library for GNOME libxshmfence-1.2_3 Shared memory 'SyncFence' synchronization primitive libzvbi-0.2.35_3 Routines to access raw VBI capture devices lzo2-2.10_1 Portable speedy, lossless data compression library mesa-libs-18.1.5 OpenGL libraries that support GLX and EGL clients mono-5.10.1.47_8 Open source implementation of .NET Development Framework nettle-3.4 Low-level cryptographic library openjpeg-2.3.0_1 Open-source JPEG 2000 codec openldap-client-2.4.46 Open source LDAP client implementation opus-1.2.1 IETF audio codec p11-kit-0.23.13 Library for loading and enumerating of PKCS#11 modules pciids-20180812 Database of all known IDs used in PCI devices pcre-8.42 Perl Compatible Regular Expressions library perl5-5.26.2 Practical Extraction and Report Language pixman-0.34.0 Low-level pixel manipulation library pkg-1.10.5_1 Package manager png-1.6.34 Library for manipulating PNG images popt-1.16_2 Getopt(3) like library with a number of enhancements, from Redhat py27-dnspython-1.15.0 DNS toolkit for Python py27-iso8601-0.1.11 Simple module to parse ISO 8601 dates py27-pillow-5.0.0 Fork of the Python Imaging Library (PIL) py27-setuptools-40.0.0 Python packages installer py27-tkinter-2.7.15_6 Python bindings to the Tk widget set (Python 2.7) python27-2.7.15 Interpreted object-oriented programming language readline-7.0.3_1 Library for editing command lines as they are typed samba48-4.8.4 Free SMB/CIFS and AD/DC server and client for Unix sqlite3-3.24.0_1 SQL database engine in a C library talloc-2.1.14 Hierarchical pool based memory allocator tcl86-8.6.8 Tool Command Language tdb-1.3.16,1 Trivial Database tevent-0.9.37 Talloc based event loop library tiff-4.0.9_1 Tools and library routines for working with TIFF images tk86-8.6.8_2 Graphical toolkit for Tcl tpm-emulator-0.7.4_2 Trusted Platform Module (TPM) emulator trousers-0.3.14_2 Open-source TCG Software Stack v4l_compat-1.6.3_1 Video4Linux IOCTL header files webp-1.0.0_1 Google WebP image format conversion tool xcb-util-0.4.0_2,1 Module with libxcb/libX11 extension/replacement libraries xcb-util-renderutil-0.3.9_1 Convenience functions for the Render extension xorgproto-2018.4 xorg protocol headers
Luke 42239 Posted August 21, 2018 Posted August 21, 2018 Ok we'll have to do some digging around. Unfortunately I don't know the answer to this as it looks more operating system related as opposed to a problem with the Emby package.
embytal 3 Posted August 21, 2018 Author Posted August 21, 2018 Ok we'll have to do some digging around. Unfortunately I don't know the answer to this as it looks more operating system related as opposed to a problem with the Emby package. Fair enough. I will try again as it looks surprising to me. Since it is in a FreeBSD jail, I will try out in multiple jails to see if I can reproduce the behaviour.
embytal 3 Posted August 25, 2018 Author Posted August 25, 2018 I can reproduce the problem on 3.5.2 so I am a bit puzzled as I could get emby working fine before. I am looking into the system itself but the jail within which it is running is destroyed and re-created so there is no left over (I assume). I am investigating more as it looks like a system problem although not entirely sure what could cause that.
embytal 3 Posted August 25, 2018 Author Posted August 25, 2018 So I have made some progress and start understanding a bit more. I have setup two jails: emby and emby2, exact same jail specs and just different name and ip address (both based on 11.2-RELEASE). I have emby set up with the instructions from the wiki meaning I have done this: pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi ffmpeg imagemagick It triggers 141 packages: root@[member="emby"]:~ # pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus samba48 sqlite3 libtheora libva libvorbis webp libx264 libzvbi ffmpeg imagemagick The package management tool is not yet installed on your system. Do you want to fetch and install it now? [y/N]: y Bootstrapping pkg from pkg+http://pkg.freebsd.org/FreeBSD:11:amd64/latest, please wait... [emby] Installing pkg-1.10.5_2... [emby] Extracting pkg-1.10.5_2: 100% Updating FreeBSD repository catalogue... pkg: Repository FreeBSD load error: access repo file(/var/db/pkg/repo-FreeBSD.sqlite) failed: No such file or directory [emby] Fetching meta.txz: 100% 944 B 0.9kB/s 00:01 [emby] Fetching packagesite.txz: 100% 6 MiB 6.8MB/s 00:01 Processing entries: 100% FreeBSD repository update completed. 32474 packages processed. All repositories are up to date. Updating database digests format: 100% The following 141 package(s) will be affected (of 0 checked): New packages to be INSTALLED: mono: 5.10.1.47_8 libass: 0.14.0 fontconfig: 2.12.6,1 freetype2: 2.9.1 fribidi: 0.19.7 gnutls: 3.5.19 iconv: 2.0_4 opus: 1.2.1 samba48: 4.8.4 sqlite3: 3.24.0_1 libtheora: 1.1.1_7 libva: 2.2.0_1 libvorbis: 1.3.6,3 webp: 1.0.0_1 libx264: 0.155.2917 libzvbi: 0.2.35_3 ffmpeg: 4.0.2_2,1 ImageMagick: 6.9.9.28_1,1 ca_root_nss: 3.38 python27: 2.7.15 readline: 7.0.3_1 indexinfo: 0.3.1 libffi: 3.2.1_2 gettext-runtime: 0.19.8.1_1 py27-pillow: 5.0.0 tk86: 8.6.8_2 libXrender: 0.9.10_1 xorgproto: 2018.4 libX11: 1.6.6,1 libxcb: 1.13 libXdmcp: 1.1.2_1 libXau: 1.0.8_4 libxml2: 2.9.7 libpthread-stubs: 0.4 libXext: 1.3.3_2,1 libXScrnSaver: 1.2.3_1 libXft: 2.3.2_2 expat: 2.2.5 tcl86: 8.6.8 py27-tkinter: 2.7.15_6 py27-setuptools: 40.0.0 openjpeg: 2.3.0_1 tiff: 4.0.9_1 jpeg-turbo: 2.0.0 jbigkit: 2.1_1 png: 1.6.34 lcms2: 2.9 giflib: 5.1.4 libinotify: 20180201 harfbuzz: 1.8.8 graphite2: 1.3.12 cairo: 1.14.8_2,2 xcb-util-renderutil: 0.3.9_1 xcb-util: 0.4.0_2,1 pixman: 0.34.0 mesa-libs: 18.1.5 libxshmfence: 1.2_3 libXxf86vm: 1.1.4_2 libXfixes: 5.0.3_1 libXdamage: 1.1.4_4 libdrm: 2.4.93,1 libpciaccess: 0.13.5 pciids: 20180812 libunwind: 20170615 glib: 2.50.3_5,1 perl5: 5.26.2 pcre: 8.42 libiconv: 1.14_11 libfontenc: 1.1.3_2 font-util: 1.3.1 trousers: 0.3.14_2 tpm-emulator: 0.7.4_2 gmp: 6.1.2 p11-kit: 0.23.13 libtasn1: 4.13 nettle: 3.4 libidn2: 2.0.5 libunistring: 0.9.10 libsunacl: 1.0.1 cmocka: 1.1.1_1 openldap-client: 2.4.46 py27-dnspython: 1.15.0 tevent: 0.9.37 talloc: 2.1.14 py27-iso8601: 0.1.11 popt: 1.16_2 jansson: 2.11 gamin: 0.1.10_9 tdb: 1.3.16,1 libarchive: 3.3.2,1 lzo2: 2.10_1 liblz4: 1.8.2,1 libogg: 1.3.3,4 v4l_compat: 1.6.3_1 libunicode: 0.4_11 xvid: 1.3.5,1 x265: 2.8_1 libvpx: 1.7.0_1 libvdpau: 1.1.1_1 libv4l: 1.6.3_2 opencv-core: 3.4.1_2 libSM: 1.2.2_4,1 libICE: 1.0.9_2,1 libXt: 1.1.5_1,1 ghostscript9-agpl-x11: 9.23_1 ghostscript9-agpl-base: 9.23_1 libpaper: 1.1.24.4 libijs: 0.35_5 cups: 2.2.8_1 avahi-app: 0.7_1 gnome_subr: 1.0 libdaemon: 0.14_1 gobject-introspection: 1.50.0_1,1 dbus-glib: 0.108 dbus: 1.10.16_1 gdbm: 1.13_1 poppler-data: 0.4.9 jbig2dec: 0.14 libidn: 1.34 fftw3: 3.3.8_1 libwmf: 0.2.8.4_15 librsvg2: 2.40.20 pango: 1.42.0 xorg-fonts-truetype: 7.7_1 font-misc-meltho: 1.0.3_3 mkfontscale: 1.1.3_1 mkfontdir: 1.0.7 font-misc-ethiopic: 1.0.3_3 font-bh-ttf: 1.0.3_3 encodings: 1.0.4_4,1 dejavu: 2.37 libcroco: 0.6.12 gdk-pixbuf2: 2.36.11 libXi: 1.7.9_1,1 shared-mime-info: 1.8 jasper: 1.900.1_17 libgsf: 1.14.41 libraw: 0.18.13_1 liblqr-1: 0.4.2 pkgconf: 1.4.2,1 libltdl: 2.4.6 Number of packages to be installed: 141 The process will require 921 MiB more space. 204 MiB to be downloaded. I added ffmpeg and imagemagick because the freebsd package (as in the one from from the package servers) shows dependency on ffmpeg and imagemagick pkg search -d emby-server emby-server-3.5.2.0 Comment : Home media server built using mono and other open source technologies Depends on : ffmpeg-4.0.2_2,1 mono-5.10.1.47_8 ImageMagick-6.9.9.28_1,1 sqlite3-3.24.0_1 However in this emby jail, I install the github package root@[member="emby"]:~ # pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.5.2.0/emby-server-freebsd_3.5.2.0_amd64.txz [emby] Fetching emby-server-freebsd_3.5.2.0_amd64.txz: 100% 16 MiB 5.5MB/s 00:03 [emby] Installing emby-server-3.5.2.0_1... ===> Creating groups. Creating group 'emby' with gid '989'. ===> Creating users Creating user 'emby' with uid '989'. [emby] Extracting emby-server-3.5.2.0_1: 100% Looking at this output, it looks like a few things are missing: emby-server-3.5.2.0_1 Name : emby-server Version : 3.5.2.0_1 Installed on : Fri Aug 24 23:26:35 2018 EDT Origin : multimedia/emby-server-3.5.2.0 Architecture : FreeBSD:11:amd64 Prefix : /usr/local Categories : multimedia Licenses : UNKNOWN Maintainer : apps@[member="Emby.media"] WWW : UNKNOWN Comment : Emby Server is a personal media server with apps on just about every device Shared Libs required: libwebpmux.so.3 libX11.so.6 libzvbi.so.0 libtheoraenc.so.1 libxcb-shape.so.0 libxcb-xfixes.so.0 libopus.so.0 libfribidi.so.0 libfreetype.so.6 libvorbisenc.so.2 libx264.so.152 libxcb-shm.so.0 libwebp.so.7 libva-x11.so.2 libvorbis.so.0 libva-drm.so.2 libiconv.so.2 libfontconfig.so.1 libgnutls.so.30 libass.so.9 libxcb.so.1 libtheoradec.so.1 libva.so.2 libsmbclient.so.0 Shared Libs provided: libswscale.so.5 libavutil.so.56 libavfilter.so.7 libavcodec.so.58 libmp3lame.so.0 libSkiaSharp.so.60 libavdevice.so.58 libavformat.so.58 libswresample.so.3 libpostproc.so.55 Annotations : FreeBSD_version: 1102000 Flat size : 57.1MiB Description : Emby Server is a personal media server with apps on just about every device On the other hand, in the emby2 jail, simply install the package from FreeBSD servers: pkg install emby-server The package management tool is not yet installed on your system. Do you want to fetch and install it now? [y/N]: y Bootstrapping pkg from pkg+http://pkg.freebsd.org/FreeBSD:11:amd64/latest, please wait... [emby2] Installing pkg-1.10.5_2... [emby2] Extracting pkg-1.10.5_2: 100% Updating FreeBSD repository catalogue... pkg: Repository FreeBSD load error: access repo file(/var/db/pkg/repo-FreeBSD.sqlite) failed: No such file or directory [emby2] Fetching meta.txz: 100% 944 B 0.9kB/s 00:01 [emby2] Fetching packagesite.txz: 100% 6 MiB 6.8MB/s 00:01 Processing entries: 100% FreeBSD repository update completed. 32474 packages processed. All repositories are up to date. Updating database digests format: 100% The following 123 package(s) will be affected (of 0 checked): New packages to be INSTALLED: emby-server: 3.5.2.0 ffmpeg: 4.0.2_2,1 fontconfig: 2.12.6,1 expat: 2.2.5 freetype2: 2.9.1 gnutls: 3.5.19 trousers: 0.3.14_2 tpm-emulator: 0.7.4_2 gmp: 6.1.2 indexinfo: 0.3.1 p11-kit: 0.23.13 libtasn1: 4.13 ca_root_nss: 3.38 libffi: 3.2.1_2 nettle: 3.4 libidn2: 2.0.5 libunistring: 0.9.10 gettext-runtime: 0.19.8.1_1 xvid: 1.3.5,1 x265: 2.8_1 libx264: 0.155.2917 libvpx: 1.7.0_1 libvdpau: 1.1.1_1 xorgproto: 2018.4 libXext: 1.3.3_2,1 libXau: 1.0.8_4 libX11: 1.6.6,1 libxcb: 1.13 libXdmcp: 1.1.2_1 libxml2: 2.9.7 libpthread-stubs: 0.4 libva: 2.2.0_1 libXfixes: 5.0.3_1 v4l_compat: 1.6.3_1 mesa-libs: 18.1.5 libxshmfence: 1.2_3 libXxf86vm: 1.1.4_2 libXdamage: 1.1.4_4 libdrm: 2.4.93,1 libpciaccess: 0.13.5 pciids: 20180812 libunwind: 20170615 pixman: 0.34.0 libfontenc: 1.1.3_2 font-util: 1.3.1 python27: 2.7.15 readline: 7.0.3_1 perl5: 5.26.2 libv4l: 1.6.3_2 jpeg-turbo: 2.0.0 png: 1.6.34 libtheora: 1.1.1_7 libvorbis: 1.3.6,3 libogg: 1.3.3,4 opencv-core: 3.4.1_2 opus: 1.2.1 mono: 5.10.1.47_8 py27-pillow: 5.0.0 tk86: 8.6.8_2 libXrender: 0.9.10_1 libXScrnSaver: 1.2.3_1 libXft: 2.3.2_2 tcl86: 8.6.8 py27-tkinter: 2.7.15_6 py27-setuptools: 40.0.0 webp: 1.0.0_1 tiff: 4.0.9_1 jbigkit: 2.1_1 giflib: 5.1.4 openjpeg: 2.3.0_1 lcms2: 2.9 libinotify: 20180201 ImageMagick: 6.9.9.28_1,1 libSM: 1.2.2_4,1 libICE: 1.0.9_2,1 libXt: 1.1.5_1,1 ghostscript9-agpl-x11: 9.23_1 ghostscript9-agpl-base: 9.23_1 libpaper: 1.1.24.4 libijs: 0.35_5 cups: 2.2.8_1 avahi-app: 0.7_1 gnome_subr: 1.0 libdaemon: 0.14_1 gobject-introspection: 1.50.0_1,1 glib: 2.50.3_5,1 pcre: 8.42 libiconv: 1.14_11 dbus-glib: 0.108 dbus: 1.10.16_1 gdbm: 1.13_1 poppler-data: 0.4.9 jbig2dec: 0.14 libidn: 1.34 fftw3: 3.3.8_1 libwmf: 0.2.8.4_15 librsvg2: 2.40.20 pango: 1.42.0 xorg-fonts-truetype: 7.7_1 font-misc-meltho: 1.0.3_3 mkfontscale: 1.1.3_1 mkfontdir: 1.0.7 font-misc-ethiopic: 1.0.3_3 font-bh-ttf: 1.0.3_3 encodings: 1.0.4_4,1 dejavu: 2.37 harfbuzz: 1.8.8 graphite2: 1.3.12 cairo: 1.14.8_2,2 xcb-util-renderutil: 0.3.9_1 xcb-util: 0.4.0_2,1 fribidi: 0.19.7 libcroco: 0.6.12 gdk-pixbuf2: 2.36.11 libXi: 1.7.9_1,1 shared-mime-info: 1.8 jasper: 1.900.1_17 libgsf: 1.14.41 libraw: 0.18.13_1 liblqr-1: 0.4.2 pkgconf: 1.4.2,1 libltdl: 2.4.6 sqlite3: 3.24.0_1 Number of packages to be installed: 123 The process will require 802 MiB more space. 185 MiB to be downloaded. The package does not throw any required lib in the following output: pkg info emby-server emby-server-3.5.2.0 Name : emby-server Version : 3.5.2.0 Installed on : Fri Aug 24 23:09:50 2018 EDT Origin : multimedia/emby-server Architecture : FreeBSD:11:* Prefix : /usr/local Categories : multimedia Licenses : GPLv2 Maintainer : woodsb02@FreeBSD.org WWW : https://emby.media/ Comment : Home media server built using mono and other open source technologies Options : X11 : on Annotations : repo_type : binary repository : FreeBSD Flat size : 44.2MiB Description : Emby Server is a home media server built on top of other popular open source technologies such as Service Stack, jQuery, jQuery mobile, and Mono. It features a REST-based api with built-in documention to facilitate client development. We also have client libraries for our api to enable rapid development. WWW: https://emby.media/ The major difference is that I got playback working in emby2 with the FreeBSD package although the ScheduleDirectTV does not work (which is the reason why I looked at the github versions from the wiki). There is no way to get the playback running on emby using the github package as it seems to be missing some lib linkage and all error messages in the emby-server.txt file point to ffmpeg/ffprobe not being to run due to missing lib I suppose. The other thing I notice is the rc.d being different: With the github package: cat /usr/local/etc/rc.d/emby-server #!/bin/sh # PROVIDE: emby-server # REQUIRE: LOGIN # KEYWORD: shutdown # # Add the following lines to /etc/rc.conf.local or /etc/rc.conf # to enable this service: # # emby_server_enable: Set to yes to enable the emby-server service. # Default: no # emby_server_user: The user account used to run the emby-server daemon. # This is optional, however do not specifically set this to an # empty string as this will cause the daemon to run as root. # Default: emby # emby_server_group: The group account used to run the emby-server daemon. # This is optional, however do not specifically set this to an # empty string as this will cause the daemon to run with group wheel. # Default: emby # emby_server_data_dir: Directory where emby-server configuration # data is stored. # Default: /var/db/emby-server # emby_server_ffmpeg: Path of the ffmpeg binary. # Default: %%PEFIX%%/opt/emby-server/bin/ffmpeg # emby_server_ffprobe: Path of the ffprobe binary. # Default: %%PEFIX%%/opt/emby-server/bin/ffprobe . /etc/rc.subr name=emby_server rcvar=${name}_enable load_rc_config ${name} [ -z "${emby_server_user}" ] && emby_server_user=emby [ -z "${emby_server_group}" ] && emby_server_group=emby [ -z "${emby_server_data_dir}" ] && emby_server_data_dir=/var/db/emby-server [ -z "${emby_server_ffmpeg}" ] && emby_server_ffmpeg=/usr/local/opt/emby-server/bin/ffmpeg [ -z "${emby_server_ffprobe}" ] && emby_server_ffprobe=/usr/local/opt/emby-server/bin/ffprobe : ${emby_server_enable:="no"} : ${emby_server_user:="emby"} : ${emby_server_group:="emby"} : ${emby_server_data_dir:="/var/db/emby-server"} : ${emby_server_ffmpeg:="/usr/local/opt/emby-server/bin/ffmpeg"} : ${emby_server_ffprobe:="/usr/local/opt/emby-server/bin/ffprobe"} export LD_LIBRARY_PATH=/usr/local/opt/emby-server/lib pidfile="/var/run/emby-server.pid" procname="mono" command="/usr/sbin/daemon" command_args="-f -p ${pidfile} ${procname} /usr/local/opt/emby-server/system/EmbyServer.exe \ -os freebsd \ -ffmpeg ${emby_server_ffmpeg} \ -ffprobe ${emby_server_ffprobe} \ -programdata ${emby_server_data_dir} \ -restartexitcode 3 \ -updatepackage emby-server-freebsd_{version}_amd64.txz" start_precmd=emby_server_precmd emby_server_precmd() { [ -f ${pidfile} ] || install -g ${emby_server_group} -o ${emby_server_user} -- /dev/null ${pidfile} [ -d ${emby_server_data_dir} ] || install -d -g ${emby_server_group} -o ${emby_server_user} -- ${emby_server_data_dir} } stop_postcmd=emby_server_postcmd emby_server_postcmd() { rm -f ${pidfile} } run_rc_command "$1" With the FreeBSD package: cat /usr/local/etc/rc.d/emby-server #!/bin/sh # $FreeBSD: head/multimedia/emby-server/files/emby-server.in 456852 2017-12-20 20:26:20Z woodsb02 $ # # PROVIDE: emby-server # REQUIRE: LOGIN # KEYWORD: shutdown # # Add the following lines to /etc/rc.conf.local or /etc/rc.conf # to enable this service: # # emby_server_enable: Set to YES to enable the emby-server service. # Default: NO # emby_server_user: The user account used to run the emby-server daemon. # This is optional, however do not specifically set this to an # empty string as this will cause the daemon to run as root. # Default: emby (or mediabrowser with UID 989 if it exists) # emby_server_group: The group account used to run the emby-server daemon. # This is optional, however do not specifically set this to an # empty string as this will cause the daemon to run with group wheel. # Default: emby (or mediabrowser with GID 989 if it exists) # emby_server_data_dir: Directory where emby-server configuration # data is stored. # Default: /var/db/emby-server (or /var/db/mediabrowser if it exists) . /etc/rc.subr name=emby_server rcvar=${name}_enable load_rc_config $name if [ "$(id -u mediabrowser 2>&1)" = "989" ] && ! [ -n "${emby_server_user}" ]; then emby_server_user=mediabrowser; emby_server_group=mediabrowser; fi if [ -d "/var/db/mediabrowser" ] && ! [ -n "${emby_server_data_dir}" ]; then emby_server_data_dir="/var/db/mediabrowser"; fi : ${emby_server_enable:="NO"} : ${emby_server_user:="emby"} : ${emby_server_group:="emby"} : ${emby_server_data_dir:="/var/db/emby-server"} pidfile="/var/run/emby-server.pid" command="/usr/sbin/daemon" procname="/usr/local/bin/mono" command_args="-f -p ${pidfile} ${procname} /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -os freebsd -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata ${emby_server_data_dir}" start_precmd=emby_server_precmd emby_server_precmd() { if [ ! -e "${pidfile}" ]; then install -g ${emby_server_group} -o ${emby_server_user} -- /dev/null "${pidfile}"; fi if [ ! -d "${emby_server_data_dir}" ]; then install -d -g ${emby_server_group} -o ${emby_server_user} -- "${emby_server_data_dir}"; fi } stop_postcmd=emby_server_postcmd emby_server_postcmd() { rm -f -- "${pidfile}" } run_rc_command "$1" As you can notice the exe file is different between the two install as well as the folder structure: root@[member="emby2"]:/usr/local/lib/emby-server # ls -l /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -rw-r--r-- 1 root wheel 46080 Aug 23 17:03 /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe root@[member="emby"]:~ # ls -lai /usr/local/opt/emby-server/system/EmbyServer.exe 130245 -rw-r--r-- 1 root wheel 61440 Jul 29 19:32 /usr/local/opt/emby-server/system/EmbyServer.exe I am not sure if anybody has reported the github version having playback running fine. I can consistently reproduce this not working for the playback only (the rest of the webapp behaves fine). The FreeBSD package version has the playback working fine however it does not have the fix for ScheduleDirectTV integrated. I can try whatever anybody may have in mind since I have easy step to get things brought up and torn down to make sure I always start from a clean jail. (I use iocage destroy which remove the ZFS dataset anyway) 1
Luke 42239 Posted August 25, 2018 Posted August 25, 2018 What if you just install the ones that it says are missing?
embytal 3 Posted August 25, 2018 Author Posted August 25, 2018 What if you just install the ones that it says are missing? Trying to identify the packages required. I am just surprised by the fact they are so many missing lib links. Will report if I can clear the required libs list.
embytal 3 Posted August 25, 2018 Author Posted August 25, 2018 What if you just install the ones that it says are missing? Well this is the problem - I checked for at least three lib and they are already installed root@emby:~ # pkg install libx264 Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. Updating database digests format: 100% Checking integrity... done (0 conflicting) The most recent version of packages are already installed root@emby:~ # pkg install libass Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. Checking integrity... done (0 conflicting) The most recent version of packages are already installed root@emby:~ # pkg install libx11 Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. Checking integrity... done (0 conflicting) The most recent version of packages are already installed Is there somebody behind the maintainer of the package: Maintainer : apps@Emby.media ? I am trying to understand if this package has been tested and reported as working successfully.
Luke 42239 Posted August 25, 2018 Posted August 25, 2018 Yes. See this topic: https://emby.media/community/index.php?/topic/60728-new-freebsd-package-for-testing/ So i guess the question would be how are others able to install and get up and running without running into this.
embytal 3 Posted August 25, 2018 Author Posted August 25, 2018 Yes. See this topic: https://emby.media/community/index.php?/topic/60728-new-freebsd-package-for-testing/ So i guess the question would be how are others able to install and get up and running without running into this. Shall I start linking my thread to this one? I am interested in assisting on this one. Do you know who built the package that is available on github? I am not sure whether this is the same maintainer as the FreeBSD package: woodsb02@FreeBSD.org. Any guidance is welcome as so far emby is super responsive in a jail when it works and integrates a lot of what I need.
Luke 42239 Posted August 25, 2018 Posted August 25, 2018 We did. It is produced by the Emby team. Thanks.
embytal 3 Posted August 27, 2018 Author Posted August 27, 2018 We did. It is produced by the Emby team. Thanks. Can you confirm the exact version of FreeBSD this package was created for?
Luke 42239 Posted August 27, 2018 Posted August 27, 2018 It was built on 11.2 but users have been able to run it on 11.1.
embytal 3 Posted August 28, 2018 Author Posted August 28, 2018 It was built on 11.2 but users have been able to run it on 11.1. One more question, how do you track fixes as it does not make a lot of sense to have the same version for v3.5.2 of the generic FreeBSD package and your version being v3.5.2 if you have a fix for the ScheduleDirect that is not in the generic FreeBSD package. Shouldn't there be a different version? Furthermore, there seems to be a very different structure to emby in your pkg vs the generic one on FreeBSD, is that track somewhere? Thanks
Luke 42239 Posted August 28, 2018 Posted August 28, 2018 We are going to be unifying them so they are both based on the newer package. That is on our to do list for the near future. Thanks.
Luke 42239 Posted August 30, 2018 Posted August 30, 2018 We have a new beta up, in case you'd like to try and see if it makes any difference with this issue. Thanks.
embytal 3 Posted August 31, 2018 Author Posted August 31, 2018 (edited) We have a new beta up, in case you'd like to try and see if it makes any difference with this issue. Thanks. Tried 3.6.0.31 in a fresh jail with the recommended packages on a 11.2-RELEASE and playback fails although ScheduleDirect works at least to the guide but LiveTv is broken because of the problem below root@emby:/usr/local/opt/emby-server/bin # ./ffmpeg Shared object "libavdevice.so.58" not found, required by "ffmpeg" No content can be played. Where is the log file located in that version? Is there a way to troubleshoot by launching the full command through Mono to see what might be failing for the playback? Tomorrow I am going to try a fresh FreeBSD install in a VM and deploy that version without jails to rule out any jail related issues. Edited August 31, 2018 by embytal
Luke 42239 Posted August 31, 2018 Posted August 31, 2018 The log file path is displayed on the front page of the emby server dashboard. thanks.
makarai 109 Posted August 31, 2018 Posted August 31, 2018 used the update iocage console emby-server-test service emby-server stop pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.6.0.31/emby-server-freebsd_3.6.0.31_amd64.txz service emby-server start worked, but kodi companion message pops up asking for a restart so 2.0.4 can be installed, which is persistent even after restart. uninstalling restart installing restart does not help either. logfile attached Log.txt 1
Luke 42239 Posted August 31, 2018 Posted August 31, 2018 Thanks @@makarai. Please report the plugin issue to the developer. Sounds like the plugin version is not tagged.
alucryd 318 Posted August 31, 2018 Posted August 31, 2018 @@embytal You can't just run the ffmpeg binary like that, our libraries are not in a standard directory so they won't be discovered unless you export LD_LIBRARY_PATH first. Of course the emby launcher script does that for you. export LD_LIBRARY_PATH=/usr/local/opt/emby-server/bin Are you able to manually run the ffmpeg binary after you do this?
