Luke 42217 Posted November 8, 2018 Posted November 8, 2018 Hi, please stay tuned to our blog for release announcements: https://emby.media/community/index.php?/blog/1-emby-blog/ Thanks.
Crestj 68 Posted January 5, 2019 Posted January 5, 2019 (edited) Quick update, since uninstalling the CoverArt plugin I've had no crashes at all. 3 weeks so far. Shame because I liked the CoverArt styling. Edited January 5, 2019 by Crestj
Luke 42217 Posted January 5, 2019 Posted January 5, 2019 Thanks for the info. The new release of the server will be available soon.
larsonDigital 7 Posted January 7, 2019 Author Posted January 7, 2019 Thanks for the update! I may have to try that while we're waiting for the next release.
Luke 42217 Posted January 7, 2019 Posted January 7, 2019 It will be any day now, sorry, broken record I know
JoeWar 0 Posted January 19, 2019 Posted January 19, 2019 (edited) Hi Luke, after endless months of waiting for a major Emby Server release I installed 4.0.0.2 hoping it will fix the issue from my initial post. Unfortunately, I have to state that the most recent release didn’t help and I still face the Emby Server crash when I scroll down the homepage and hit some empty artworks. I was optimistic at the beginning as I do not experience the problem when accessing the Emby via the server itself. Nevertheless, the issue appears when I access it through the LAN. See the LOG attached. Thx Josef Log.txt Edited January 19, 2019 by JoeWar
Crestj 68 Posted January 19, 2019 Posted January 19, 2019 FYI Updated to the same version after having the same issue with CoverArt. Reinstalled CoverArt and have been accessing my library using the web site, emby theatre and the android emby app without a crash or missing art work. Hopefully it will not appear again as it has for you.
Luke 42217 Posted January 19, 2019 Posted January 19, 2019 Apologies that you're still having an issue. Can you scan your directories as well as the server metadata folder for any zero byte image files? Thanks.
JoeWar 0 Posted January 24, 2019 Posted January 24, 2019 (edited) Hello, thx for the feedback. I searched the media drive for any zero byte images but didn’t find any. The weird thing is that when I access the Emby via the server, all the artworks are visible and all seems to be working normally. But it is not the case when I access it via a remote machine or TV despite the problematic artwork files are present. For now, I am considering uninstalling the Emby server; manually deleting all artwork and .nfo files; and installing/configuring the Emby server again. Is this worth to try or is there anything else I can try? Thx Josef Edited January 24, 2019 by JoeWar
Crestj 68 Posted January 24, 2019 Posted January 24, 2019 Have you tried uninstalling the CoverArt plugin? Before the v4 update this solved all the connection and crashing issues I had.
JoeWar 0 Posted January 24, 2019 Posted January 24, 2019 Actually, I checked list of my plugins right after reading your hint but didn’t see CoverArt listed. I haven’t installed any additional plugins. Should CoverArt be installed by default or was supposed to be before version 4? Josef
Luke 42217 Posted January 25, 2019 Posted January 25, 2019 No, CoverArt is an optional plugin you would have to install from the catalog.
Masterz 2 Posted January 27, 2019 Posted January 27, 2019 In the middle of playback. EmbyServer_20190127_01.zip
Luke 42217 Posted January 28, 2019 Posted January 28, 2019 Can you attach the emby server log as well? Thanks !
JoeWar 0 Posted February 2, 2019 Posted February 2, 2019 (edited) Hi Luke, in the end I performed the server reinstall including deleting all the metadata files and reconfiguring my library folders. I was happy for a week as all was functioning normally, but now the problem has started to occur again. What I can see now is that the problem is related to viewing the home page only. Attached log should capture the following scenario: server starts - entering library #1 and playing movie #1 - going to homepage - entering library #2 and playing movie #2 which has a visible artwork here - going back to homepage - scrolling down to a point where I see some blank artworks to include the movie #2 which has suddenly no artwork here - server crashes. Emby is fine and I am considering to by an Emby Premium, but it has to prove to be reliable first. Please, do not make me to try and leave for Plex! Fixing the issue takes too long! Any help would be appreciated Josef Log.txt Edited February 2, 2019 by JoeWar
Luke 42217 Posted February 3, 2019 Posted February 3, 2019 Yea the problem is coming in the image processing library we are using. Since this is a fresh install if you could try the beta server and let me know how that compares, that would be helpful. thanks.
JoeWar 0 Posted February 3, 2019 Posted February 3, 2019 (edited) Luke, thank you for your response. I’m optimistic for now as after a quick test, the server v4.1.0.5b seems to be resolving the issue. I will report back to you if I see a problem. Thanks a lot Josef Edited February 3, 2019 by JoeWar
