balasankarc 0 Posted July 6, 2018 Posted July 6, 2018 I have a collection of a local tv show that runs daily (on weekdays). Suppose it's name is "Something Else", the episodes are named in the following order 1. Somthing_Else_0001.mkv 2. Somthing_Else_0002.mkv 3. Somthing_Else_0003.mkv . . . I checked out https://github.com/MediaBrowser/Wiki/wiki/TV%20naming#by-date and saw that they could be handled if I name them in the following order 1. Somthing_Else_2015-12-14.mkv 2. Somthing_Else_2015-12-15.mkv 3. Somthing_Else_2015-12-16.mkv . . . However, when I tried that, Emby collected all of them inside an "Unknown Season" season. How do I inform Emby that there is no concept of "Seasons" with this show, but only a sequential list of episodes ?
balasankarc 0 Posted July 6, 2018 Author Posted July 6, 2018 Personally I would prefer if Emby had another format for denoting shows with sequential episodes. Similar to sXXeYY, format for shows in season-episode format, have #xxxx for shows with sequential episodes (ones without the concept of seasons).
Happy2Play 9802 Posted July 6, 2018 Posted July 6, 2018 (edited) Do you have specific examples as I just tested with a daily soap and everything worked fine. Are these shows on TVDB? Edited July 6, 2018 by Happy2Play
balasankarc 0 Posted July 6, 2018 Author Posted July 6, 2018 Are these shows on TVDB? No, since this is one in a regional language in India. It is in themoviedb and imdb, though. PS: I am yet to figure out how to add it to tvdb.
Happy2Play 9802 Posted July 6, 2018 Posted July 6, 2018 No, since this is one in a regional language in India. It is in themoviedb and imdb, though. PS: I am yet to figure out how to add it to tvdb. Can you provide a specific example I can test with?
balasankarc 0 Posted July 6, 2018 Author Posted July 6, 2018 Can you provide a specific example I can test with? https://www.imdb.com/title/tt6650508/ Available in youtube at the playlist https://www.youtube.com/playlist?list=PLo6nvUgrCYlxgru7yILYCUIiRhoUvAT4V (Uploaded by the TV channel themselves. Not pirated or anything)
Spaceboy 2573 Posted July 6, 2018 Posted July 6, 2018 Do you have specific examples as I just tested with a daily soap and everything worked fine. Are these shows on TVDB? already been done h2p, I’ll find the thread
Happy2Play 9802 Posted July 6, 2018 Posted July 6, 2018 https://www.imdb.com/title/tt6650508/ Available in youtube at the playlist https://www.youtube.com/playlist?list=PLo6nvUgrCYlxgru7yILYCUIiRhoUvAT4V (Uploaded by the TV channel themselves. Not pirated or anything) Emby will never use IMDB directly, but there is no information on provider sites. With this example you will have to provide all metadata. IMDB 2 episodes TMDB 1 episode TVDB not listed.
Happy2Play 9802 Posted July 6, 2018 Posted July 6, 2018 (edited) @@balasankarc Unless you plan on adding all these episode to TMDB or TVDB I would place all of them in a Season 1 folder (as IMDB and TMDB list as Season 1) and on the Series select edit metadata and change "Display order:" to Absolute. You can use whatever sequential naming scheme you like as there is currently no real metadata provider. But if the series was full added you would want to name accordingly. example "Uppum Mulakum 429" (set to Absolute) Edited July 6, 2018 by Happy2Play
Spaceboy 2573 Posted July 6, 2018 Posted July 6, 2018 Here you go @@Happy2Play https://emby.media/community/index.php?/topic/57095-dvr-filenames/
Solution Luke 42211 Posted July 7, 2018 Solution Posted July 7, 2018 @@balasankarc Currently in Emby there is always a season layer in the presentation, so you will always see a season folder. If there truly is no internet metadata available, then we should probably find something better to say than "Season Unknown". We can probably have them all just say Season 1. That's in the short term at least. Longer term we should obviously not display the season folder at all when it's not needed, that's just going to take a bit more work. Please let me know if this answers your questions in this topic. Thanks. 1
balasankarc 0 Posted July 7, 2018 Author Posted July 7, 2018 Currently in Emby there is always a season layer in the presentation, so you will always see a season folder. @@Luke If we could mention this in the wiki, it would be great. That's in the short term at least. Longer term we should obviously not display the season folder at all when it's not needed, that's just going to take a bit more work. Agreed. Please let me know if this answers your questions in this topic. Thanks. Kinda. It clears my doubt of why a "Season" appears where it shouldn't. I'll go ahead and mark this as solved. Thanks everyone for the help.
