tdiguy 99 Posted May 27, 2018 Posted May 27, 2018 I have the hdhr prime with cable card. With it connected up to emby everything comes across as .ts but when i look at the channel information from the hdhr prime on the HD channels it lists avc which from what i understand is .mp4. I dont suppose there is someone that can tell me what is really happening?
Luke 42240 Posted May 27, 2018 Posted May 27, 2018 They are both correct. Avc is the video codec, ts is the container.
nyplayer 90 Posted May 27, 2018 Posted May 27, 2018 I have the hdhr prime with cable card. With it connected up to emby everything comes across as .ts but when i look at the channel information from the hdhr prime on the HD channels it lists avc which from what i understand is .mp4. I dont suppose there is someone that can tell me what is really happening? That is the way it is H264 in a TS container. H264 is a codec mp4 is a container not the same.
Guest asrequested Posted May 27, 2018 Posted May 27, 2018 And just to add, that's what a remux is. Doesn't change the codec, just the container.
tdiguy 99 Posted May 27, 2018 Author Posted May 27, 2018 And just to add, that's what a remux is. Doesn't change the codec, just the container. So in emby terms thats what is happening when on the server dashboard it says direct streaming right ( as opposed to direct play which i believe means its not altering anything )
mastrmind11 722 Posted May 27, 2018 Posted May 27, 2018 So in emby terms thats what is happening when on the server dashboard it says direct streaming right ( as opposed to direct play which i believe means its not altering anything ) correct, a container swap to something stream friendly.
Guest asrequested Posted May 27, 2018 Posted May 27, 2018 This might help https://emby.media/community/index.php?/topic/48799-direct-play-vs-direct-streaming-vs-transcoding/
CBers 7554 Posted May 27, 2018 Posted May 27, 2018 This might help https://emby.media/community/index.php?/topic/48799-direct-play-vs-direct-streaming-vs-transcoding/ Just don't read beyond the first post though 1
tdiguy 99 Posted May 27, 2018 Author Posted May 27, 2018 Just don't read beyond the first post though lol, but ya i already did and i get your take on it but i like the direction emby took on it.
