FrostByte 5453 Posted September 28, 2018 Author Posted September 28, 2018 @SamES said he already added his patch to the next release. Did that not make it then?
Luke 42242 Posted October 7, 2018 Posted October 7, 2018 This will be resolved in a future update to the app. thanks ! 1
IceBoosteR 10 Posted October 27, 2018 Posted October 27, 2018 This will be resolved in a future update to the app. thanks ! Luke, is there anything I can do to support you to get this fixed as soon as possible? Starting with a feature request on Github or somothing else. I would really like to see this "fixed". -Ice
someperson 3 Posted December 25, 2018 Posted December 25, 2018 Any updates? I've been manually converting DTS tracks to AAC each time I encounter them to work around this, but this is annoying and not ideal.
Luke 42242 Posted December 25, 2018 Posted December 25, 2018 It's resolved for the next update to the app. Thanks. 1
someperson 3 Posted December 26, 2018 Posted December 26, 2018 It's resolved for the next update to the app. Thanks. Do we have any ETA on this? I'm wondering if I should run a script to go through and convert every file in my library that has a DTS track to something else. Not a fan of the idea since it'll degrade the quality a bit, but it would at least put an end to this madness for now.
Luke 42242 Posted December 26, 2018 Posted December 26, 2018 As soon as it gets through Samsung review.
someperson 3 Posted December 26, 2018 Posted December 26, 2018 As soon as it gets through Samsung review. How long does that typically take? Like, if it's within the next few days, I'll just wait. But if it's going to be a month or more, I'm more inclined to go through with the conversion.
Luke 42242 Posted December 26, 2018 Posted December 26, 2018 Hopefully something in between, but it will definitely be more than a few days. Thanks. 1
Eselter 7 Posted December 27, 2018 Posted December 27, 2018 What must happen for the application to appear in the Polish region?
Luke 42242 Posted December 27, 2018 Posted December 27, 2018 You can follow this topic: https://emby.media/community/index.php?/topic/41315-emby-europe/ Thanks.
FrostByte 5453 Posted January 8, 2019 Author Posted January 8, 2019 Just a head up that 2019 sets will NOT support DTS either. Samsung is really getting cheap. https://developer.samsung.com/tv/develop/specifications/media-specifications/2019-tv-video-specifications Important The DTS Audio codec is not supported on 2019 TVs. For smooth playback, if a DTS Audio track is part of your manifest, make sure other audio tracks can be selected. If keying off the Tizen version for the fix then you will want to check for version 5.0. Or, I guess 4.0 or > for both 2018 and 2019 sets https://developer.samsung.com/tv/develop/specifications/tv-model-groups
SamES 1084 Posted January 8, 2019 Posted January 8, 2019 Great, thanks for the info ! @@SamES Currently we do >=4.0 so it should be fine. 1
matf 3 Posted January 12, 2019 Posted January 12, 2019 (edited) Maybe I'm misunderstanding here, but if the DTS fix is keying off the Tizen version, does that mean that fix won't work for those of us who have Samsung TVs that support DTS, but want to force DD as it's a nightmare to have to go into TV settings anytime you have a video with a different audio codec. Thats what I'm trying to avoid as it's totally not user friendly. Was hoping for a manual setting. Could someone clarify? (don't have .53 yet, still on .45, 2017 TV) Edited January 12, 2019 by matf
Luke 42242 Posted January 12, 2019 Posted January 12, 2019 Yes that's different and manual settings are planned for the future. thanks. 1
easywolf 0 Posted January 19, 2019 Posted January 19, 2019 Yes that's different and manual settings are planned for the future. thanks. Thanks. In the market to buy a new 65" TV, following this thread. Found it on the first page of which tv brands support DTS. I think my current 2014 model H6350, 6360 actually, might have DTS support..hoping the same with the Q7FN.
FrostByte 5453 Posted January 19, 2019 Author Posted January 19, 2019 Thanks. In the market to buy a new 65" TV, following this thread. Found it on the first page of which tv brands support DTS. I think my current 2014 model H6350, 6360 actually, might have DTS support..hoping the same with the Q7FN. Your 2014 H-series set does support DTS, the 2018 Q7FN does NOT. That's why the patch to convert DTS to AC3 on the fly in the next version. Samsung has dropped DTS support in all TV sets in 2018 onward. It won't even pass through to a receiver using ARC.
Emp0ri0 0 Posted January 21, 2019 Posted January 21, 2019 Your 2014 H-series set does support DTS, the 2018 Q7FN does NOT. That's why the patch to convert DTS to AC3 on the fly in the next version. Samsung has dropped DTS support in all TV sets in 2018 onward. It won't even pass through to a receiver using ARC. So you are telling me that my Q65FN will play dts after next update by converting it to ac3 in real time? Did I understanded you correctly? SI this confirmed info? Any idea on timeline?
SamES 1084 Posted January 21, 2019 Posted January 21, 2019 So you are telling me that my Q65FN will play dts after next update by converting it to ac3 in real time? Did I understanded you correctly? SI this confirmed info? Any idea on timeline? That's correct. Timing is based on Samsung release of the next version so I can't confirm that.
