s.zoli89 0 Posted April 17, 2018 Posted April 17, 2018 (edited) i would love to use emby server, if it working properly...I cant use Emby, because it crashing all the time. When i start a movie-after stop, then start other, the server is crashing.I tried playing this movies whit Plex and worked, but i dont like Plex. PLZ help me to use this awsome server!! My system: DietPi distribution on Raspberry pi 3, Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.4 (stretch) Release: 9.4 Codename: stretchEmby Version: Version 3.3.1.0ffmpeg version: ffmpeg version 3.2.10-1~deb9u1+rpt1Mono runtime version: Mono JIT compiler version 5.10.1.20I see this on ssh session terminal, when crash is coming: Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.036759] Internal error: Oops: 17 [#10] SMP ARM Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.107391] Process Threadpool work (pid: 7323, stack limit = 0xb5f72210) Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.111531] Stack: (0xb5f73d98 to 0xb5f74000) Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.115609] 3d80: 00007f38 806d1600 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.119741] 3da0: 00082dcf b5f73ec0 b25757c0 00082dcf b5f73e54 b5f73dc0 806d1620 806ce01c Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.123787] 3dc0: 00007f38 801ed940 b3f06a6c b6fc814c 80c069c4 80d0a08c 80c049c0 b5f72000 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.127845] 3de0: 00000000 90a5e05c 00000001 00000000 00000001 00000000 00010000 00000000 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.131922] 3e00: 00000001 b2575910 0000054d 00000000 00000121 00007f38 7fffffff b5f73e28 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.135949] 3e20: 801235c4 801e0000 b25757c0 b25757c0 00202436 b5f73ec0 00000121 80108224 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.139882] 3e40: b5f72000 00000000 b5f73e74 b5f73e58 806d214c 806d1324 806d2114 b25757c0 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.143890] 3e60: 00000000 931c4fc0 b5f73e94 b5f73e78 806fe240 806d2120 802aa224 802aa178 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.147846] 3e80: 00000000 00000000 b5f73ea4 b5f73e98 80657950 806fe204 b5f73f8c b5f73ea8 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.151730] 3ea0: 80658aa0 80657938 b5f73ec8 80c82021 fffffff7 00000001 6de206f2 00202436 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.155590] 3ec0: 00000000 00000000 00000001 00082dcf 0017f667 b5f73eb8 00000001 801ee188 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.159462] 3ee0: 00000000 00000000 00000000 b5f73ef8 80101850 80123188 b5f73f00 b6802e00 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.163284] 3f00: 00000001 00400040 80c02d00 0002f04e 0000000a 80c918c0 80c823f0 80c03d68 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.167115] 3f20: 80b84378 80c02080 b5f73ef8 00000000 8017a470 80b8c92c 00000000 00000000 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.170902] 3f40: 00000001 b6804180 00202436 8012377c b5f73f6c b5f73f60 8012377c 80184560 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.174608] 3f60: b5f73f94 b5f73f70 801754d8 801236e0 b5f73fb0 76412d80 00000000 6de206f2 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.178380] 3f80: b5f73fa4 b5f73f90 80658af0 806589e4 00000000 00000000 00000000 b5f73fa8 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.182084] 3fa0: 80108080 80658ad4 76412d80 00000000 00000021 6de206f2 00202436 00000000 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.185758] 3fc0: 76412d80 00000000 6de206f2 00000121 00000000 01feac80 00380ee0 6f12a820 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.189398] 3fe0: 00000000 6f12a7a8 00000000 76e2b984 80000010 00000021 00000000 00000000 Message from syslogd@DietPi-Kodi at Apr 17 11:31:28 ... kernel:[ 2226.218091] Code: e155000c 03a05000 e2117902 1a000039 (e5d50028) AND when i check emby status, after crash: ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; disabled; vendor preset: enabled) Active: failed (Result: exit-code) since Tue 2018-04-17 11:29:23 CEST; 7s ago Process: 6922 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS) Process: 6673 ExecStart=/usr/bin/emby-server start (code=exited, status=134) Main PID: 6673 (code=exited, status=134) Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: Native stacktrace: Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: Debug info from gdb: Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: mono_gdb_render_native_backtraces not supported on this platform, unable to find gdb or lldb Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: ================================================================= Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: Got a SIGABRT while executing native code. This usually indicates Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: a fatal error in the mono runtime or one of the native libraries Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: used by your application. Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: ================================================================= Apr 17 11:29:23 DietPi-Kodi systemd[1]: emby-server.service: Unit entered failed state. Apr 17 11:29:23 DietPi-Kodi systemd[1]: emby-server.service: Failed with result 'exit-code'. THX! ServerLog.txt FFmpegLog.txt reinstalled_ffmpegLog.txt reinstalled_serverLog.txt MorningServerLog_2018_04_18.txt Edited April 18, 2018 by s.zoli89
Luke 42245 Posted April 17, 2018 Posted April 17, 2018 Hi, what you could do is try uninstalling and then reinstall using our newer installation package that is on our website. Please let us know if this helps. Thanks.
s.zoli89 0 Posted April 17, 2018 Author Posted April 17, 2018 (edited) Hi, what you could do is try uninstalling and then reinstall using our newer installation package that is on our website. Please let us know if this helps. Thanks. Thank you for reply! I tried reinstall with offical installation package, but i got same result. It most stable, but i can to cause crash. I upload the server log to the first post... How to restart Emby with this package? Edited April 17, 2018 by s.zoli89
Luke 42245 Posted April 17, 2018 Posted April 17, 2018 ffmpeg is exiting with status code 255. I haven't heard that one before so I'll try to research what that means, as these things are unfortunately poorly documented.
s.zoli89 0 Posted April 17, 2018 Author Posted April 17, 2018 ffmpeg is exiting with status code 255. I haven't heard that one before so I'll try to research what that means, as these things are unfortunately poorly documented. i think that cause my kill command.... after the emby crash, ffmpeg process was still worked
Luke 42245 Posted April 18, 2018 Posted April 18, 2018 Does the rest of the server appear to be operating normally?
s.zoli89 0 Posted April 18, 2018 Author Posted April 18, 2018 (edited) It seems the rest of the server is working fine, but last night i got a new error (i not used server):I upload new serverlog... emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Wed 2018-04-18 06:05:27 CEST; 4h 11min ago Process: 13729 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=ABRT) Main PID: 13729 (code=killed, signal=ABRT) Apr 17 22:52:47 DietPi-Kodi emby-server[13729]: Info App: Default journal_mode for /var/lib/emby/data/sync14.db is wal Apr 17 22:52:47 DietPi-Kodi emby-server[13729]: Info App: PRAGMA synchronous=1 Apr 17 22:52:47 DietPi-Kodi emby-server[13729]: Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0800602 seconds Apr 17 22:52:47 DietPi-Kodi emby-server[13729]: Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint Apr 17 22:52:47 DietPi-Kodi emby-server[13729]: Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0054907 seconds Apr 17 22:52:47 DietPi-Kodi emby-server[13729]: Info App: All entry points have started Apr 18 06:05:27 DietPi-Kodi emby-server[13729]: *** Error in `/opt/emby-server/system/EmbyServer': double free or corruption (fasttop): 0x6e8b5f58 *** Apr 18 06:05:27 DietPi-Kodi systemd[1]: emby-server.service: Main process exited, code=killed, status=6/ABRT Apr 18 06:05:27 DietPi-Kodi systemd[1]: emby-server.service: Unit entered failed state. Apr 18 06:05:27 DietPi-Kodi systemd[1]: emby-server.service: Failed with result 'signal'. Edited April 18, 2018 by s.zoli89
bokiroki 0 Posted April 18, 2018 Posted April 18, 2018 Hi, i have the same problem like op.. I installed emby yesterday on dietpi system on raspberry pi 3 trough dietpi-software menui saw in terminal before emby was installed, ffmpeg was installed first.. in transcode menu i put /usr/bin/ffmpeg because it didn't let me save transcode settings..emby version is 3.3.1.0..mono version is 5.10.1.20in some threads you posted that mono is the issue, in this thread you did't mentioned monoI get this when i type ffmpeg -version ffmpeg version git-2017-04-18-6108805 Copyright © 2000-2017 the FFmpeg developers built with gcc 4.9.2 (Raspbian 4.9.2-10) configuration: --prefix=/usr --enable-static --enable-gpl --enable-libx264 --enable-pthreads --enable-nonfree --enable-omx --enable-omx-rpi --enable-libfdk-aac --enable-libmp3lame libavutil 55. 61.100 / 55. 61.100 libavcodec 57. 93.100 / 57. 93.100 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 84.101 / 6. 84.101 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 So when i start movie, and exit and start another i get spinning circle (in htop i don't see emby anymore), or when i start movie and jump to another scene i get spinning circe also (emby is missing again in htop)all movies i played were direct play or direct stream.. here are logs before crash and after Log.txt Log (1).txt
s.zoli89 0 Posted April 18, 2018 Author Posted April 18, 2018 Hi, i have the same problem like op.. I installed emby yesterday on dietpi system on raspberry pi 3 trough dietpi-software menu i saw in terminal before emby was installed, ffmpeg was installed first.. in transcode menu i put /usr/bin/ffmpeg because it didn't let me save transcode settings.. emby version is 3.3.1.0..mono version is 5.10.1.20 in some threads you posted that mono is the issue, in this thread you did't mentioned mono I get this when i type ffmpeg -version ffmpeg version git-2017-04-18-6108805 Copyright © 2000-2017 the FFmpeg developers built with gcc 4.9.2 (Raspbian 4.9.2-10) configuration: --prefix=/usr --enable-static --enable-gpl --enable-libx264 --enable-pthreads --enable-nonfree --enable-omx --enable-omx-rpi --enable-libfdk-aac --enable-libmp3lame libavutil 55. 61.100 / 55. 61.100 libavcodec 57. 93.100 / 57. 93.100 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 84.101 / 6. 84.101 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 So when i start movie, and exit and start another i get spinning circle (in htop i don't see emby anymore), or when i start movie and jump to another scene i get spinning circe also (emby is missing again in htop)all movies i played were direct play or direct stream.. here are logs before crash and after Hi, dont use dietpi-software installer for install emby, because this is older installer package from dietpi server..... Use instead official emby installer package from emby site. https://emby.media/linux-server.html
bokiroki 0 Posted April 18, 2018 Posted April 18, 2018 (edited) Thanks guys everything works well now..Deleted emby and ffmpeg with dietpi uninstall option, and installed emby trough website.. How emby update itself? do i need to do something trough time, or it will update itself? Edited April 18, 2018 by bokiroki
Luke 42245 Posted April 18, 2018 Posted April 18, 2018 You would just do the same process again on top of your existing install.
s.zoli89 0 Posted April 18, 2018 Author Posted April 18, 2018 (edited) My Emby installation is also seems to be working a day ago. Edited April 18, 2018 by s.zoli89
tdiguy 99 Posted April 22, 2018 Posted April 22, 2018 A couple of things got my attention on this, first the emby version Version 3.3.1.0 that is the current stable emby version i believe. But then i also noticed these: Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: Got a SIGABRT while executing native code. This usually indicates Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: a fatal error in the mono runtime or one of the native librariesApr 17 11:29:23 DietPi-Kodi emby-server[6673]: used by your application. Which seems like an issue with mono and i will say from my own experience that mono can be a pita. I dont know why mono is on your system personally but after i uninstalled mono from my ubuntu system ( its not a pi either ) emby was much more stable. Unless you are using mono for something else it might be worth considering uninstalling mono.
s.zoli89 0 Posted April 22, 2018 Author Posted April 22, 2018 (edited) A couple of things got my attention on this, first the emby version Version 3.3.1.0 that is the current stable emby version i believe. But then i also noticed these: Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: Got a SIGABRT while executing native code. This usually indicates Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: a fatal error in the mono runtime or one of the native libraries Apr 17 11:29:23 DietPi-Kodi emby-server[6673]: used by your application. Which seems like an issue with mono and i will say from my own experience that mono can be a pita. I dont know why mono is on your system personally but after i uninstalled mono from my ubuntu system ( its not a pi either ) emby was much more stable. Unless you are using mono for something else it might be worth considering uninstalling mono. Thank you. i will try uninstall mono; i dont use mono runtime. test it a few days and lets see what happens. Still with installed mono-runtime, today morning the emby server is stopped. emby-service status is: emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Sat 2018-04-21 16:44:05 CEST; 16h ago Process: 12257 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=SEGV) Main PID: 12257 (code=killed, signal=SEGV) Apr 21 09:25:27 DietPi-Kodi emby-server[12257]: Info App: Sqlite compiler options: COMPILER=gcc-6.4.1 20170707,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UP DATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Apr 21 09:25:27 DietPi-Kodi emby-server[12257]: Info App: Default journal_mode for /var/lib/emby/data/sync14.db is wal Apr 21 09:25:27 DietPi-Kodi emby-server[12257]: Info App: PRAGMA synchronous=1 Apr 21 09:25:27 DietPi-Kodi emby-server[12257]: Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0776036 seconds Apr 21 09:25:27 DietPi-Kodi emby-server[12257]: Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint Apr 21 09:25:27 DietPi-Kodi emby-server[12257]: Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0069298 seconds Apr 21 09:25:27 DietPi-Kodi emby-server[12257]: Info App: All entry points have started Apr 21 16:44:05 DietPi-Kodi systemd[1]: emby-server.service: Main process exited, code=killed, status=11/SEGV Apr 21 16:44:05 DietPi-Kodi systemd[1]: emby-server.service: Unit entered failed state. Apr 21 16:44:05 DietPi-Kodi systemd[1]: emby-server.service: Failed with result 'signal'. Edited April 22, 2018 by s.zoli89
Luke 42245 Posted April 22, 2018 Posted April 22, 2018 Try uninstalling mono and then let's go from there, thanks.
s.zoli89 0 Posted April 23, 2018 Author Posted April 23, 2018 Hi. The problem is still exist Emby server status:emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Mon 2018-04-23 16:10:34 CEST; 5h 38min ago Process: 14133 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=SEGV) Main PID: 14133 (code=killed, signal=SEGV) Apr 22 21:39:10 DietPi-Kodi emby-server[14133]: encoder : libebml v1.3.1 + libmatroska v1.4.2 Apr 22 21:39:10 DietPi-Kodi emby-server[14133]: creation_time : 2016-09-30T10:39:02.000000Z Apr 22 21:39:10 DietPi-Kodi emby-server[14133]: Duration: 00:48:18.58, start: 0.000000, bitrate: 641 kb/s Apr 22 21:39:10 DietPi-Kodi emby-server[14133]: Stream #0:0: Video: h264 (High), yuv420p(tv, bt709/unknown/unknown, progressi ve), 720x404 [sAR 1:1 DAR 180:101], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Apr 22 21:39:10 DietPi-Kodi emby-server[14133]: Stream #0:1(hun): Audio: aac (LC), 48000 Hz, stereo, fltp (default) Apr 22 21:39:10 DietPi-Kodi emby-server[14133]: Stream #0:2(hun): Subtitle: subrip Apr 22 21:39:10 DietPi-Kodi emby-server[14133]: Stream #0:3(eng): Subtitle: subrip Apr 23 16:10:34 DietPi-Kodi systemd[1]: emby-server.service: Main process exited, code=killed, status=11/SEGV Apr 23 16:10:34 DietPi-Kodi systemd[1]: emby-server.service: Unit entered failed state. Apr 23 16:10:34 DietPi-Kodi systemd[1]: emby-server.service: Failed with result 'signal'.
Luke 42245 Posted April 26, 2018 Posted April 26, 2018 When does this happen? Immediately on startup? Or sometime later?
s.zoli89 0 Posted April 29, 2018 Author Posted April 29, 2018 Im done with this. sorry, uninstall....
