riverboat2001 20 Posted April 3, 2018 Posted April 3, 2018 Not sure if this is the right place to post, so please move if needed. I've successfully used a Harmony remote with WMC and Emby for years, I still find the WMC nice and clean, but it doesn't seem to get the love that it once had Am I correct in thinking the web app (http://192.168.1.64:8096/web/home.html) is the most current way to view our content on a htpc I'm thinking of putting and Android tv box and a firestick running Emby around the house and in order to have a more streamlined experience perhaps it's time to move up/over to the web app. BUT the big thing that has stopped me switching is the Harmony One doesn't move around in the way the app is designed.For example it doesn't moved left and right through the epg. Am I missing a setting or do I need to buy a new kind of remote. Thanks
serpi 82 Posted April 3, 2018 Posted April 3, 2018 Am I correct in thinking the web app (http://192.168.1.64:8096/web/home.html) is the most current way to view our content on a htpc I'm thinking of putting and Android tv box and a firestick running Emby around the house and in order to have a more streamlined experience perhaps it's time to move up/over to the web app. I would say, for Windows it's best to use Emby Theater, for an Android Box there's Emby for Android TV and then there's Emby for Amazon Fire TV. All should work pretty well with a remote, I'm using the same remote with Emby Theater that I used with Emby for WMC (also I had to remap some buttons, to get more/full functionality). Ciao, Alfred
Luke 42208 Posted April 3, 2018 Posted April 3, 2018 If you want to use it with the web app you can do that with the emby theater web app Http://tv.emby.media
riverboat2001 20 Posted April 10, 2018 Author Posted April 10, 2018 I would say, for Windows it's best to use Emby Theater, for an Android Box there's Emby for Android TV and then there's Emby for Amazon Fire TV. All should work pretty well with a remote, I'm using the same remote with Emby Theater that I used with Emby for WMC (also I had to remap some buttons, to get more/full functionality). Ciao, Alfred Any Idea what you needed to remap? As you know it needs unplugging and testing each time you make changes....Very time consuming!
serpi 82 Posted April 10, 2018 Posted April 10, 2018 Any Idea what you needed to remap? As you know it needs unplugging and testing each time you make changes....Very time consuming! Well, I have an MCE compatible remote connected to the USB port and all information about remapping the functions can be found here. My Harmony remote is more or less configured as standard Microsoft Mediacenter Remote, as the remapping happens on the windows box running emby theater. All keyboard shortcuts that are supported by ET (and other apps) are described here, so you just take this list and map all functions you want/need to whatever buttons you like. Hope this helps. Ciao, Alfred
