Luke 42240 Posted July 25, 2018 Posted July 25, 2018 Can you try restarting the server after doing that? thanks.
igrgic 0 Posted July 25, 2018 Posted July 25, 2018 I am trayed restarting Emby server but unfortunately no change. I am trayed restarting QNAP server but unfortunately no change.
Luke 42240 Posted July 25, 2018 Posted July 25, 2018 Ok I would suggest trying again with the next release of emby server as it should perform better with your CPU. Thanks !
TTuna99 1 Posted July 28, 2018 Posted July 28, 2018 Ok I would suggest trying again with the next release of emby server as it should perform better with your CPU. Thanks ! I have the same problem, and it persists.... When will this next update be released? Thank you
Luke 42240 Posted September 21, 2018 Posted September 21, 2018 Emby server 3.6 will perform dramatically faster. You can always jump on the beta channel if you like. Thanks.
igrgic 0 Posted September 21, 2018 Posted September 21, 2018 I can not install beta. Installation package is incompatible. Use the correct package.
PenkethBoy 2068 Posted September 21, 2018 Posted September 21, 2018 Without information on what Qnap model you have What firmware (QNAP) you are running What package you tried etc Cant help you
igrgic 0 Posted September 21, 2018 Posted September 21, 2018 Information of hardaware is in post #44 I tried install official package x64, Arm x41, 31, 19... but unsuccessful
igrgic 0 Posted September 21, 2018 Posted September 21, 2018 Same problem in topic: https://emby.media/community/index.php?/topic/61788-qnap-ts-328/&do=findComment&comment=609296
PenkethBoy 2068 Posted September 21, 2018 Posted September 21, 2018 Looks like your processor type is not supported or incorrectly detected The devs will have to work on that
igrgic 0 Posted September 21, 2018 Posted September 21, 2018 No, I tried install your official package without qmono.
Luke 42240 Posted September 21, 2018 Posted September 21, 2018 Ok please try the updated instructions on our website: https://emby.media/nas-server.html Thanks.
igrgic 0 Posted September 21, 2018 Posted September 21, 2018 Type Date Time Users Source IP Computer name Content Error 2018/09/21 21:15:41 System 127.0.0.1 localhost [App Center] Failed to install Emby Server 3.6.0.39. Installation package is incompatible. Use the correct package.
Luke 42240 Posted September 21, 2018 Posted September 21, 2018 Ok, we may have work to do to support that cpu. thanks.
