AYarter 3 Posted March 14, 2018 Posted March 14, 2018 Hello: I'm having no luck getting external subs to work on my KS 8000. Even emby downloaded subs don't display -- only embedded ones do. I've tried several srt files, including the emby downloading service. BTW:Thanks for all the hard work. Emby is really the best in class and has made my TV everything that I want it to be. Log.txt
Luke 42241 Posted March 14, 2018 Posted March 14, 2018 Hi are you using the app, and if so, what version?
AYarter 3 Posted March 14, 2018 Author Posted March 14, 2018 (edited) Luke: This is the Tizen Samsung app, Version 1.0.38. Edited March 14, 2018 by AYarter
shocker 135 Posted March 14, 2018 Posted March 14, 2018 @@AYarter I think you are heaving the same issues as described here: https://emby.media/community/index.php?/topic/56666-subtitles-are-out-of-sync-on-1037/
AYarter 3 Posted March 14, 2018 Author Posted March 14, 2018 @Shocker This is exactly the behavior that I'm seeing. It see,ms that'd an old post, so I'm guessing no subd movies for me for awhile =(
Nightreaver 10 Posted March 25, 2018 Posted March 25, 2018 I have to say, that I'm having the same issue for a while now... maybe 1/2 month. Before it was working nicely, now i always have to embed to make it work
AYarter 3 Posted April 3, 2018 Author Posted April 3, 2018 @@Luke is there anything that I can do to help you?
Luke 42241 Posted April 3, 2018 Posted April 3, 2018 Please try again with the next release of the app, which will be 1.0.40. Thanks.
AYarter 3 Posted April 13, 2018 Author Posted April 13, 2018 @@Luke Still no resolution in the new version.
AYarter 3 Posted April 13, 2018 Author Posted April 13, 2018 @@Luke Is there anything that I can do to help? The file in question is HEVC with DCA audio. Subtitle is named appropriately and is recognized by Emby. Nothing displays. Plex has a similar issue where DCA cannot be sent with streamed subtitles. Third party apps have worked around by 'downloading' the subtitles.
Luke 42241 Posted April 13, 2018 Posted April 13, 2018 So I guess this is a platform defect then right? That's what we tried to suggest in another topic but of course we were immediately challenged on that with everyone saying emby problem, emby problem. Yes I suppose we can try to work around it but at some point it ought to be reported to samsung.
AYarter 3 Posted April 13, 2018 Author Posted April 13, 2018 @@Luke Plex transcodes the audio to aac. It works from a USB key though. A third party app managed to work by not streaming the subtitles, but downloading. Transcoding doesn't work with 4k HEVC -- it kills my poor supermicro =(This is what is said in the support thread: With regards DCA to AAC audio transcoding when subtitles added, this was looked into by the development team and this explains what and why Enabling subtitles requires playback through Direct Streaming or Transcoding. We intend to support soft subtitles without direct stream Samsung uses HLS Protocol for Direct Stream/Transcoding DCA audio is not supported over HLS An alternative codec will be used to work with HLS and this is why the DCA is transcoded to AAC We do not believe users would detect audible difference between DCA and AAC So I am afraid this is what it is - because subtitles currently need Direct Stream / Transcoding.
gyrene2083 1 Posted April 13, 2018 Posted April 13, 2018 I'm having the same issue on a Samsung UN65KU7500. I was able to watch subbed Anime about two weeks ago, now I can't. So, I installed Emby on AppleTV to see if it would work, and it did. So for the time being I have an out. If you need help testing let me know, I'll help if you need me to.
gyrene2083 1 Posted April 14, 2018 Posted April 14, 2018 Ok after further playing, I downloaded the latest firmware for the Samsung, just came out 10 Apr 18 v1220.6, removed the emby app and still couldn't get it to work. So I figured I would try something else. I enabled the DLNA, and went to the Emby folders, into the Anime, which has the .ass files in the mkv container, and that seemed to work without a problem, with every anime show I threw at it, and movie. I hope that helps someone.
Luke 42241 Posted May 8, 2018 Posted May 8, 2018 Please try again with the next release of the app, thanks.
