a11an 2 Posted March 11, 2018 Posted March 11, 2018 Hi, I am migrating my media server across from Window to a Linux box running LibreElec. So far it's been going great, running really well. But then I went and spoilt it all by attempting to setup live tv !! I have added the TVHeadend plugin on emby and it's working fine streaming to my android phone. But, when I attempt to use it via the web frontend, on play, It goes to a black screen and is stuck on the rotating loading circle. I get a similar issue on the Android TV client. I get the "Giving up, too many errors' message. Would anyone be able to offer some advice? The logs below is at the point it dies. Is this enough information or should I attached the full logs? Thanks for looking. 2018-03-11 20:57:26.166 Info App: /storage/.kodi/addons/service.emby/bin/ffmpegx -analyzeduration 3000000 -f mpegts -i "http://localhost:9981/stream/channelid/1133581758?ticket=37EB0BEF305FED79A1EDDE6078BE36D4D71DCEFA" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 5000000 -bufsize 10000000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/b0b68ed60fb19954e6744c973e938148/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/media/sdb1-ata-TOSHIBA_DT01ACA2/Transcode/transcoding-temp/b0b68ed60fb19954e6744c973e938148.m3u8" -y "/var/media/sdb1-ata-TOSHIBA_DT01ACA2/Transcode/transcoding-temp/b0b68ed60fb19954e6744c973e938148%d.ts" 2018-03-11 20:57:26.296 Info App: /storage/.kodi/addons/service.emby/bin/ffmpegx -analyzeduration 3000000 -f mpegts -i "http://localhost:9981/stream/channelid/1133581758?ticket=37EB0BEF305FED79A1EDDE6078BE36D4D71DCEFA" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 5000000 -bufsize 10000000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/b0b68ed60fb19954e6744c973e938148/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/media/sdb1-ata-TOSHIBA_DT01ACA2/Transcode/transcoding-temp/b0b68ed60fb19954e6744c973e938148.m3u8" -y "/var/media/sdb1-ata-TOSHIBA_DT01ACA2/Transcode/transcoding-temp/b0b68ed60fb19954e6744c973e938148%d.ts" 2018-03-11 20:57:26.432 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.34.0 Command line: /storage/.kodi/addons/service.emby/Emby.Mono/MediaBrowser.Server.Mono.exe -programdata /storage/.kodi/userdata/addon_data/service.emby -ffmpeg /storage/.kodi/addons/service.emby/bin/ffmpegx -ffprobe /storage/.kodi/addons/service.emby/bin/ffprobex Operating system: Unix 4.11.12.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.4.1.6 (tarball Thu Nov 9 19:51:07 GMT 2017) Processor count: 4 Program data path: /storage/.kodi/userdata/addon_data/service.emby Application directory: /storage/.kodi/addons/service.emby/Emby.Mono System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService+<StartFfMpeg>d__72.MoveNext () [0x007b8] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.MediaEncoding.Api.BaseStreamingService+<StartFfMpeg>d__72.MoveNext () [0x007ab] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService+<ProcessRequestAsync>d__6.MoveNext () [0x00243] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService+<ProcessRequest>d__5.MoveNext () [0x00078] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<Execute>d__2.MoveNext () [0x0013b] in <e8a19581117c4782a9bf4f1232d76098>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__15.MoveNext () [0x0014c] in <e8a19581117c4782a9bf4f1232d76098>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__72.MoveNext () [0x006f4] in <e8a19581117c4782a9bf4f1232d76098>:0 System.Exception at Emby.Server.MediaEncoding.Api.BaseStreamingService+<StartFfMpeg>d__72.MoveNext () [0x007b8] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.MediaEncoding.Api.BaseStreamingService+<StartFfMpeg>d__72.MoveNext () [0x007ab] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService+<ProcessRequestAsync>d__6.MoveNext () [0x00243] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService+<ProcessRequest>d__5.MoveNext () [0x00078] in <d5624611b4fa4cc8b361775cba69e033>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<Execute>d__2.MoveNext () [0x0013b] in <e8a19581117c4782a9bf4f1232d76098>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__15.MoveNext () [0x0014c] in <e8a19581117c4782a9bf4f1232d76098>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9b03d1af40a7418693f6646cc848990f>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <9b03d1af40a7418693f6646cc848990f>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__72.MoveNext () [0x006f4] in <e8a19581117c4782a9bf4f1232d76098>:0 2018-03-11 20:57:26.432 Info HttpServer: HTTP Response 500 to 192.168.1.12. Time: 1308ms (slow). http://192.168.1.8:8096/emby/videos/f0eb48ad5f6cc498878a7e294ec190fe/live.m3u8?DeviceId=ef4fcf739e660b5914c57da3b3b8bc284de331ab&MediaSourceId=0&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=1&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=8ea08c8c13264d648166e6b5d8f06000&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_41c95b6de5174f82acbc56fe82d0a2f8_0&CopyTimestamps=false&TranscodingMaxAudioChannels=2&EnableSubtitlesInManifest=false&RequireAvc=true&RequireNonAnamorphic=false&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true
Luke 42244 Posted March 11, 2018 Posted March 11, 2018 Hi, this is an old version of emby server. Are you able to update?
a11an 2 Posted March 12, 2018 Author Posted March 12, 2018 Thanks Luke. I have managed to update to version 3.3.1.0 via the instructions found here https://emby.media/community/index.php?/topic/49451-emby-server-for-libreelec/?p=522822 This update subsequently triggered the TVHeadend to update. But now TVHeadend does not show on the Devices page of Live TV in settings as before. LiveTV is still available on the web frontend, but, if I attempt to play I now get the message 'Playback Error, No compatible streams are currently available'. Any ideas? Is it time to wipe all my config and try again? Latest log attached from a reboot and attempting to stream a channel from the web frontend. Log.txt
a11an 2 Posted March 12, 2018 Author Posted March 12, 2018 (edited) I think the issue is fixed. It seems that the version installed from the LibreElec repositories not only has an old version of Emby but ffmpeg is also out of date. Transcode logs had 'crf' option unrecognized error. So I have now updated FFmpeg from the static builds here -https://johnvansickle.com/ffmpeg/ and live tv seems to be working fine. Live TV is still missing information about the TVHeadedend plugin service. See screenshot, is this normal? But it's working! Edited March 12, 2018 by a11an
